Old 03-05-2012, 07:50 AM   #1771
Suteki's Avatar
Originally Posted by dr_hfuhuhurr View Post
Buy them here:
http://www.tqracing.com/rc_products.htm
Best wire ever!
Ok, this makes far more sense. I take it sensor cables are universal then. Ie. Those cable will work with my tekin esc and motors with both my rx8 and rs pro?
Also as aboce, seems to make sense to me to directly solder them.
Losi SCTE - Tekin RX8 / Pro4 4600 / Futaba ***** Mugen MBX6 Eco - Tekin RX8 / T8 1900 / Savox ***** Mugen MBX6TR - Eco / Tekin / Futaba ***** Emaxx - FLM / UE Supermaxx / Tekno hop ups ***** Axial SCX10 Honcho RTR (stock) ***** Losi 5ive T - Futaba / VRC / Rooster Tail 30.5cc / SNR
Suteki is offline   Reply With Quote
Old 03-05-2012, 08:14 AM   #1772
Super Moderator
Slo_E4's Avatar
Trader Rating: 57 (100%+)
Originally Posted by TryHard View Post
Ok, So which servo is that?
It looks trick, so gonna do that with my next install... already hitting up TQ for wire!!
I'm wondering the same. How you get that strip shiny?
Slo_E4 is offline   Reply With Quote
Old 03-05-2012, 10:11 AM   #1773
Trader Rating: 29 (97%+)
where can you buy new servo connectors you can crimp your self the tiny ones, in the front
zaraz is online now   Reply With Quote
Old 03-05-2012, 01:05 PM   #1774
I have never bothered to shorten a sensor wire - I just buy the length that I want (http://www.tqracing.com/sensor.htm)
As for the servo wires - I do shorten these but I normally shorten them from the servo end by opening the case, unsoldering the wire, cutting it to length and then soldering it back on. A little bit fiddly
Option 2 would be to shorten the wire from the connector end. To do this you need these: http://www.rc-mushroom.com/product_i...e-male-p-20166
Option 3 is to purchase a complete new servo wire (http://www.tqracing.com/TQ_2218_800x600.jpg) and then solder this to your servo after cutting to length.
There are some great examples in this forum of clean efficient wiring. Good work all.
Simon
Team_Krusty is offline   Reply With Quote
Old 03-05-2012, 01:38 PM   #1775
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Its a futaba 9551. I just re routed the wires out the other end of the servo so they don't have to hang off the chassis.
Some nice black vinyl, and a sharp exacto blade to cut it to fit. Only issue with it is its a finger print magnet lol.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 03-06-2012, 05:30 AM   #1776
TryHard's Avatar
Cheers for that, I'm deffiently going to give that a shot with the Savox when my TQ order turns up.
Anyway, latest install at the moment... waiting on a few more bits to arrive, but I am digging the red motor wire, matches the batt good (and only reason I used it was had run out of black!!)
Fan wire needs tidying up, but difficult to route... any ideas? Otherwise, ESC wire needs lengthening to allow better routing, but given it's a HW V3, once it's in the Rx, never needs to come out again as all programming is done via the front port! And the inbuilt switch (with back lit LED) is pimp!
Ed
Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-a700_v3_install.jpg
Last edited by TryHard; 03-06-2012 at 05:31 AM. Reason: helps to attach the pictures!
Old 03-06-2012, 06:33 AM   #1777
Ed
if no need to cross the A&C wires from motor to V3, it will be perfect.
mos-leung is offline   Reply With Quote
Old 03-06-2012, 06:54 AM   #1778
Suteki's Avatar
Simon
With soldering to the servo directly, how fiddly is this? I was considering soldering a whole new lead to my RX8 esc after it had become pinched so it would look a lot cleaner, but I was worried I could very easily stuff the esc itself. Same with my servo. Are these easy to do / what likely hood is there you'll stuff the entire esc or servo? Would you be better off / safer just cutting out the pinched area and just re-soldering that?
Also noticed since those cables are all black, how do you know which is positive negative?
Lastly, I noticed you can get Futaba / JR / Hitec connections, are these basically all the same? The JR looks basically like a Futaba connection minus the tab, they all work / insert the same yeh?
Old 03-06-2012, 07:03 AM   #1779
defcone's Avatar
Trader Rating: 15 (100%+)
You would stuff it I imagine, if you shorted the red and black, just make sure they aren't. It would definitely be easier to go the pin crimp route.
defcone is offline   Reply With Quote
Old 03-06-2012, 08:06 AM   #1780
Trader Rating: 22 (100%+)
It bugs the hell out of me that the white antanna tube get burned everytime I try to bend it. Need a new method.
HB hara D8 with Werks b5-----HB D8T with Werks b6
Xray 808e with Losi Bl W/ 5s lipo
Monster gt 8.0 with modded stock engine fully hopped up
4tec electric(first rc ever!)-----TA-05 hopped up and set for drifting
Brenda is offline   Reply With Quote
Old 03-06-2012, 08:51 AM   #1781
samshirley00's Avatar
dat antenna!
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 03-06-2012, 09:14 AM   #1782
Trader Rating: 39 (100%+)
What Method are you useing now?
I use a heat gun on the lowest setting and just get it warm enough to bend and then using a jig I made out of wood slowly bend it into the jig and then slowly back the heat away and let it cool
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 03-06-2012, 10:29 AM   #1783
I was using the lighter method. Ill give the heat gun a try. Now I just need to find it!!!
Old 03-06-2012, 10:56 AM   #1784
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default Clear bodies
Some of you guys setups need to driven in clear bodies.... lmao
sick wiring skills...
quick question: i have the 3rd hand jig i got from harbor freight for like 10 bucks best buy ever lol..... how tough is it to solder new black wires to the servo? Aslo what can you do to the sec's wires with out voiding it?
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 03-06-2012, 12:57 PM   #1785
Ed
Hi Ed,
Did you try unscrewing the fan and rotating in 180? Not sure if the A700 has enough room but doing it this way you may be able to run the fan wire under the front of the motor and then return it to the receiver down the centre of the car under the shaft.
Simon
Tamiya TA05 Touring Sedan kentech Electric On-Road 11396 03-16-2017 06:06 AM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
SMC 4000/25C/3.7V single cell Hardcase pack. Danny/SMC Electric On-Road 1022 03-10-2010 07:56 AM
