Old 01-05-2009, 09:31 AM   #16
jkirkwood's Avatar
I add enough weight to get it balanced then a 1/4oz here and there to aid in the driving performance. If the club doesn't enforce a weight rule then I will run my car as light as possible. A lighter car has less tire wear, is less prone to breakage hitting stuff at speed, accelerates & stops faster, the list goes on an on. If you do run light then you need to know how to adapt your setups for the lesser weight.
If you plan on running regional and national events then you should practice at the weekly club races with your car setup to be legal for those events so you are use to how it performs at that weight.
jkirkwood is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45159 Today 01:34 PM
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 343 06-26-2014 04:44 AM
Indoor Carpet Racing @ RC Performance in Madison Associated-08 Wisconsin & Illinois Racing 3426 11-25-2010 03:03 PM
Slash vs SC10 vs Strike Wee-EDM Electric Off-Road 61 06-21-2010 08:15 PM
Balanced Chassis vs Minimum Weight Teehomo Electric On-Road 10 02-24-2009 05:25 AM
belt vs shaft Quietroit Nitro On-Road 112 07-14-2004 01:40 PM
SEO by vBSEO 3.5.0
