Old 01-01-2009, 03:30 PM   #1
nutsisneat's Avatar
Default Which mode on MuchMore Dicscharger?
I'm running 1/12 and therefore i still need Nimh batteries.
I'm using a MM CTX-D discharger and like to know which programme you guys are using.
Some battery matchers recommend deadshort, but i'm a bit scared to use that one.
Your thoughts?
BTW. topic is here because of most active users...
nutsisneat is offline   Reply With Quote
Old 01-01-2009, 03:40 PM   #2
bs6ef's Avatar
DO NOT what ever you do dead short your cells, you will very promtly kill them. Only discharge down to 0.9v per cell maximum..
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 01-01-2009, 03:48 PM   #3
tdu verney's Avatar
Several use a combination of Pulse and Linear. At the track between runs "Linear" and at the end of the day (at home) Pulse and then add in about 1800 mah's over the week.
tdu verney is offline   Reply With Quote
SEO by vBSEO 3.5.0
