Old 12-26-2008, 05:28 PM   #1
Default Differential question
I have an RS4 Pro 2.. How can i check to see if the differential is bad? When I drive it I like to powerslide or drift it alot and I have the HPI Stage D tires.. Sometime when the car does a 180 the car stops and the wheels struggle to turn like diff is free spinning... The car pushes big time in some turns and i hear a little clicking.. Is this a bad diff ? Or does my motor not have enough power to keep the wheels moving after a 180? Or is the chasis/ Diff designed to stop power to the wheels after a quick 180 type spin? The motor I have a a 27 turn P2K Trinity with SMC energ 4600 batts...
RS4Pro2GT is offline   Reply With Quote
Old 12-28-2008, 05:35 PM   #2
RFALLON's Avatar
Send a message via AIM to RFALLON
Have you tried rebuilding it? and if not make sure when you rebuild it if your holding both things the dog-bones go in (idk what they're called) the gear cant turn.
XRAY T2'009
Nexus Racing
JR racing
RFALLON is offline   Reply With Quote
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 09:03 AM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 08:22 AM
SEO by vBSEO 3.5.0
