Old 12-26-2008, 01:32 PM   #1
Default TC5 Setup Help
Hi All,
I have recently got back into racing after a 8 year absence. I bought a TC5R and after spending a lot of time trying to setup the diff I finally got the car ready to test. I took the car to my local track and spent 2-3 hours setting the car up (7 laps or so, adjust and so on).
My problem is that the back end of the car is really unstable, its better than it was but still difficult to control. If I power too much out of a corner the car steps out, if I correct the direction down the straight to much the car starts to snake.
Any help in what may be wrong or what to look for would be appreciated.
jmaster is offline   Reply With Quote
Old 12-26-2008, 02:18 PM   #2
Jsaves's Avatar
I know this sounds bad, but it is a start.
Is this a new car right out of the box and did you build it?
Then you set it up like the directions?
Make sure the shocks are the same length
Do you have any set up tools, ie.. ride height, camber gauge, tweak station?
Or access to these tools?
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 12-26-2008, 05:06 PM   #3
islander360's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to islander360
Jmaster,
I recommend having at least 3 degrees of rear toe in. Also try going to the TC5 thread for more info.
JConcepts - BMI Racing - Speed Passion - KustomRCGraphics - Core R/C
islander360 is offline   Reply With Quote
Old 12-26-2008, 05:36 PM   #4
rcterp's Avatar
Trader Rating: 35 (100%+)
I've found that my TC5R likes a lot more camber than other cars. You'll also see a noticeable difference with droop settings.
Are you running a spool in front?
rcterp is offline   Reply With Quote
Old 12-26-2008, 05:42 PM   #5
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
If it's a TC5R, then it should have a slipper spool in the front. I would probably check there and see if it is loose. All my other ideas have been said already.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 12-26-2008, 07:05 PM   #6
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
before you do any of what was said above,( expect for checking the spool) find one of the local hotshots that is running a tc5 , make a setup sheet of their car, set yours up like it, and go from there.
loopedout is offline   Reply With Quote
Old 12-27-2008, 09:41 AM   #7
Maybell's Avatar
Jmaster,
Welcome back to racing!
What surface are you running on? If asphalt, try one of the setups from the 2007 Reedy Race that is posted on the AE site...These setups are very balanced and are a great starting point...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 12-28-2008, 10:32 AM   #8
Thanks for the feedback, to answer some of your questions
I'm racing on a carpet surface
I built the kit from scratch myself
I actually took the spool out of the front and that seemed to help, although I did make other changes at the same time. Should I generally have a spool diff in the front whenever I run Rubber?
I'll play around with the camber and droop setting and see if that makes any differance.
One more question, the pic below shows my tires after a day of setup, is this normal, I always used to run foam so am unsure is this kind of markings are normal for rubber on carpet?
Old 12-28-2008, 08:03 PM   #9
robk's Avatar
Trader Rating: 22 (100%+)
What tire are you running? That looks like you have a very soft tire on that car.
Old 12-28-2008, 08:22 PM   #10
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Take the tire off the car and scrub it with motor spray on a towel. That should take the gunk off, then, immediately after apply dope and let it sit. the next run your tires should be alot prettier and stickier.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 12-31-2008, 06:45 PM   #11
Jsaves's Avatar
Running rubber tires on carpet, I would start with a diff and then check out a one way. The one way is the fastest way, but it takes a different driving style.
You might have a problem with excess ware or breakage with the spools.
CRC GT-R
CRC WTF-1
Old 01-07-2009, 10:20 AM   #12
Hi i got a tc5r last october to get back into racing again after a 10yr break and i have had problems building the diffs on the car but have found that if you use a thrust bolt and screw out of an hpi it looks more or less the same as the tc5 original except the nut is allready in a plastic housing which makes it go together much easier
smithy1983136 is offline   Reply With Quote
Old 01-07-2009, 10:26 AM   #13
bigkoitat's Avatar
Trader Rating: 6 (88%+)
That's ecxactly the same thing I did Works like a champ
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 01-07-2009, 10:32 AM   #14
bigkoitat's Avatar
jmaster
I had the same problem with the rear end being unstable, with the new diff it needs to be broken in first and then adjust the diff to were it's loose-med setting. It woked for me
JAWS
Old 01-07-2009, 11:14 AM   #15
BobbyS's Avatar
The TC3 nut is encased in a (white) plastic housing and works like a direct replacement. Comes packaged with the white cap, with the white cap and long screw, or as part of a diff rebuild kit . The B4 part also works. (Can you tell that I didn't like the ones that came with the TC5?)
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
eXpress Motorsports Jon Williams Team and Company Discussions 18296 11-16-2016 03:17 PM
ADRENALINE R/C Raceway rc action Florida Racing 5387 11-04-2012 07:20 AM
Roll Centre and Camber Gain Calculator BobW Electric On-Road 181 12-31-2011 08:37 AM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 02:41 PM
Correct Droop Setting...Help! Terry M Electric On-Road 15 04-26-2008 12:20 AM
Loose TC5, Help! Victory Side Electric On-Road 17 10-05-2007 08:57 PM
