Ep4600 Cell Size?
Are the EP4600 cells actually larger in diameter; or in length? Every where I've researched they are said to be a more "robust" cell. Is this just a marketing term or are they actually larger. I want to be sure they will fit my application.
Thanks. |
Hi , i had EP4200 in my HB cyclone and they fited fine , the 4200 i had where marvelous punchy and great cells , so the 4600 i think will be really good , but i have movd to ENERG cells .
The EP4600 are in diameter :22,80 mm and in lenght or hight :42,70 mm They are also 71,5 g in weight . hope it helps |
they are bigger in every dimention if you compare them to 3000s or 3300s, or older cells. but they are pretty much the same size as the 4200s, lasted gen 4600s are slightly longer but have more voltage
