SMC 40C+  C-Max 7.4V Hardcase Lipos >
Old 12-14-2008, 01:07 PM
Company Representative
Danny/SMC's Avatar
Default SMC 40C+ C-Max 7.4V Hardcase Lipos
Were proud to release info on our new 40C+ C-Max Hardcase packs.
The first 2 packs will be available by the middle of January.
Part # 3240CM 3200mAh / 7.4V / 40C+
Retail: 140.00 Street Price 94.95
Size: L 136mm x W 46.5mm x H 20.5mm
Top exiting wire Black colored hardcase with 12 gauge wires and Deans connector.
Part # 5240CM 5200mAh / 7.4V / 40C+
Retail: 192.00 Street Price 124.95
Size: L 138.5mm x W 46.5mm x H 24.5mm
Were confident that our new 40C+ series will offer the best possible performance. Early tests shows that the IR of these new packs is 15% to 20% better than our closest competitors packs.
Here are numbers on four 5000 sample packs we received this week. Actual production packs will have a bit better runtime as were going with a slightly bigger case/cell to help capacity.
All packs were charged at 2C on a Hyperion Duo Balance charger. Packs discharged on a T35GFX/Lipo at 35 amps. Voltage sensing leads attached on the 12 gauge wires were the female Deans is soldered. Pack and room temp was 72 degrees. Packs below are sample packs and actual production packs will have 530+ runtime.
#1 505 - 7.43 - 5.7
#2 507 - 7.45 - 5.1
#3 512 - 7.45 - 5.5
#4 510 - 7.44 - 5.5
Danny/SMC is offline
Old 12-14-2008, 02:09 PM
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Sweet
ChristopherKee is offline
Old 12-14-2008, 02:26 PM
Tech Legend
Wild Cherry's Avatar
LoL !
Wild Cherry is offline
Old 12-14-2008, 03:18 PM
Gone Racin's Avatar
Default batterys
Can we pre-order them. if not who will be the first place to get them.Thanks,
Gone Racin is offline
Old 12-14-2008, 03:28 PM
Trader Rating: 14 (100%+)
Danny how about a 4s hard case 5000? or even a soft case 5000. I can special order a 4s 5000 40c soft case? Use 1/8th electric guys need these batteries.
Thanks for the help,
Joe
Joe Maxey is offline
Old 12-14-2008, 03:33 PM
Danny/SMC's Avatar
We don't sell directly but the usual places that stock our products will get them when the become available. I should have a better idea of the release date in a few weeks. Cells are in production now.
Old 12-14-2008, 03:35 PM
Danny/SMC's Avatar
Joe
Joe please look at this thread we are going to release a softcase 40C+ C-Max 5000/4S pack for the 8th scale guys.
http://www.rctech.net/forum/electric...fo-wanted.html
Old 12-14-2008, 03:52 PM
c1 racin's Avatar
Danny ..... on your other thread you stated that you are also going to have a new pack with 4mm built connectors for over seas. Do you have any numbers on this pack now? .... V - RT - IR and pack size .... Also, will it be available in the US ..... thanks
c1 racin is offline
Old 12-14-2008, 04:00 PM
Danny/SMC's Avatar
Your right we will release an EFRA based pack in the C-Max 40C+ series. This pack will also be sold in the US and other countries so it won't be exclusive to Europe.
As far as specs go the cells aren't done/ready yet. So I have no info except that we expect the capacity to be 4200+ and possibly as high as 4500. When doing a pack with inboard connectors you sacrifice cell size which reduces the capacity. The EFRA rules also means the case needs to be 1mm thinner than our 5000 case so that will also impact capacity.
I will post the info when I get it from our supplier.
Old 12-14-2008, 04:18 PM
c1 racin's Avatar
Thanks .... I'll keep checking back ..... a 4200+/- w/ 40C+/- in the case size of +/- 136mm x 46.5mm x 20.5mm is perfect ... IMO .... one more thing ....
Can you post a chart on your new (Part # 3240CM) 3200mAh / 7.4V / 40C+ and one on your (Part # 4028LD) 4000mah 28C Competition so I might compare the two .... or a link where I could find one ..... THANKS AGAIN ....
c1 racin is offline
Old 12-14-2008, 04:25 PM
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Will we see a saddle pack 40c? Lookin to power a B44 this summer.
SpraydbySprague is offline
Old 12-14-2008, 05:29 PM
Danny/SMC's Avatar
The EFRA pack should be 138.5 x 46.5 x 23
I will only have graphes once we receive our new packs.
Old 12-14-2008, 05:30 PM
Danny/SMC's Avatar
No plans to release a 40C+ saddle as our 4900/25C packs have been very popular and we beleive most racers race mod in 4wd so if more power is required all that is needed is a lower turn motor.
Old 12-14-2008, 09:06 PM
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
mrrcguy is offline
Old 12-16-2008, 06:03 AM
360rcspeedway's Avatar
Default Testing
I got a chance to run the new 40c pack. Since I really don't have any experience running two different lipo packs back to back I wasn't sure what the difference would be going to a higher C rate only. I did cycle the pack out on a GFX when I got it to compare to the 28C I have been running. Here are the numbers:
I used a friends GFX since mine is not updated for Lipo yet. He has it setup so that his leads all go to his Deans connector, meaning the main voltage leads and the small voltage sensing leads as well. I would assume with the voltage sensing leads going directly to the battery the numbers I got would be better for both packs? These cycles were done at 100dg.
my 28c
Runtime 510
Ave. v. 7.49
IR 4.6
new 40C
Runtime 513
Ave. V. 7.56
IR 3.2
I will try to get cycle numbers again with the voltage sensing leads hooked up the proper way.
Anyways from the cycle I'm thinking its not that big a deal going from the 28C to the 40C. I was wrong.
My plan was to run my 28C, then take the car off and recharge and then run again. Then, do the same with the 40C, so that both packs had a rerun on them as from what I've seen these lipo's always seem to run a lil better the more you run them in a day, and it would be a comparable test.
I got my runs done with the 28C so I had a good baseline. 9.1 hot lap with alot of 9.2's and 9.3's. This was on the 2nd run of the pack.
Then I put the 40C pack in to make its first run. 9.0 hotlap with a ton of 9.1's and a few 9.2's. Finished with a 9.1. It was a noticable difference, sort of like going up 2 teeth if you were undergeared. Rip from corner to corner was noticably better as well as top speed (which to me doesnt make much sense cause voltage its pretty close)
Now I am thinking man this is going to be really good on its 2nd run..and then I looked at the clock and had to leave..LOL. So i never got to do the 2nd run.
I'm going to try to do this test all over again either today or tomorrow if I have time, but the pack def. shows serious potential being it was better than my 28c pack even on its first and only run of the day.
All runs were done with the packs NOT heated. I never heat my packs and really only did it on the cycles cause A) the guy who's charger I was using had a lipo sack with the heater setup in it already B) Seems to be when people do cycle packs they heat them.
Well I hope this helps a lil if people were wondering about the new packs. Like I said I'll try to have more info up here either today or tomorrow.
-Donny Lia
360rcspeedway is offline
