Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-09-2009, 09:13 PM   #391
Originally Posted by adamge View Post
Joe, 6.4v measured on a resting pack after the run means the pack is like 99% discharged. Again, 80% is a good limit for long pack life.
Joe Maxey is offline   Reply With Quote
Old 06-09-2009, 09:14 PM   #392
Old 06-09-2009, 09:16 PM   #393
I know that now. Lol. I thought it was just odd that only 1 cell swelled out of 4. It was the top cell in both packs.
Thanks,
Joe
Old 06-09-2009, 10:32 PM   #394
adamge's Avatar
Yeah, I have no explanation for that ;>
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 06-27-2009, 03:32 AM   #395
Benzaah's Avatar
I need some advice guys on new lipos for 17.5/10.5 tourer with a spx and lrp 10.5/17.5 I see nothing but good reports on these and we have a local retailer in australia i can get them from reasonably cheap. Ive had my intellect 25c and 35c 3800 packs go soft recently and im not sure if its from over use from being charged heaps while racing 2 classes(tourer/mini) or whether ive left them without enough charge or too much charge, I don't know. I want to ask, Is this charging in a day just bad for lipos or will quality lipos like these SMC ones stand up to the abuse of being balanced charged in the morning and re peaked after each of 3 heats and 3 finals in the one day? Or should i get 2 packs to run and let them rest a bit before being re peaked? How many Lipo packs would someone normally use on a club day with 3 heats and 3 finals.
Much appreciated, Benzaah
This Ain't no Chewbacca Defense
A.E.R.C.C.C #76
Xray CRC Tamiya Losi
Benzaah is offline   Reply With Quote
Old 06-27-2009, 03:42 AM   #396
Fast XXXS's Avatar
Trader Rating: 18 (100%+)
Benzaah- I run 17.5 with these packs. I am currently running two of these. It takes about 48mins to ballance charge these after a run with 17.5. I reckon you could get away with one (depending how many races are between your races) but i would recommend two packs, in my opinion i reckon its good to let the pack rest a bit before i put it back on charge. You won't be dissapointed with these packs, gained so much more compared to my IP 25C, not saying the IP's are bad packs but the bigger SMC's just have more power!
Tamiya TA05MS/ KO Propo Helios/ LRP SPX/ Fantom ION 17.5/ SMC 5200/ Mazda 6
Associated SC10/ Mamba 6900/ Futaba/ Intellect
Fast XXXS is offline   Reply With Quote
Old 06-27-2009, 12:16 PM   #397
DARKSIDE's Avatar
I just got my 4700 40c..Im using it in my TC3 for Trans-am class Sunday..cait wait to see it in action,..if it anything like my other SMC packs..I will laydown the competition with no problem..lol..thanks SMC
THUNDER TRANS-AM SERIES....
RD 2-Nov 22nd-Turkey Tag Race
RD 3-Dec 27th-Christmas Enduro -RD 4-Jan 17th-Thunder Jam Championship 2
RD 5-Feb 27 0r 28th-Trans-am Rally 1000 -FINAL RD-Mar 21st-On-road Finale
GOTO THUNDER.RC50.COM FOR MORE INFO
DARKSIDE is offline   Reply With Quote
Old 06-27-2009, 07:34 PM   #398
Benzaah's Avatar
Looks like ill have to get myself a battery brace for my xray then as i frickin hate taping batteries all day. We usually only run 4 classes with 1 heat of each in around 40mins a round. Being winter here at the moment as well as racing on an outdoor asphalt track in the hills the numbers drop. I usually run mini and stock so its race, marshal, race, marshal with not a lot of time to do bugger all in between. If we get a full field of stock i can usually get away with only marshaling after mini.
Also, Do you balance charge every time. I would only normally do that for the first charge of the day and then just peak it back up with a normal charge for the rest of the time. It does usually take around an hour and a half to balance when i do it that way but im not sure how much my packs are degraded.
Cheers Benzaah
A.E.R.C.C.C #76
Old 06-28-2009, 02:41 AM   #399
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
I use a velcro tie in my Yokomo... That way I don't have to worry about constantly re-taping
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
Kyosho STR(R) - RB TM728 (btw, I HATE pullstart! lol)
Traxxas Jato - Castle Creations Mamba Max 5700kV cog-o-matic
drperry is offline   Reply With Quote
Old 06-29-2009, 01:46 AM   #400
Fast XXXS's Avatar
Cheers Benzaah
Yes i balance charge every time i charge the packs. I only race stock and we have about 1hr 20min between races lol over 10 races per round most club meets, so i have plenty of time. It only takes about 50mins to balance charge my packs. Could be different for other packs not sure.
Old 06-30-2009, 11:36 AM   #401
espresso1967's Avatar
Trader Rating: 14 (100%+)
Does the pack have bumps on the bottom of case or is it flat?
Calandra CRC Gen X 10 - TC5R
espresso1967 is offline   Reply With Quote
Old 06-30-2009, 11:41 AM   #402
Also I have a Hyperion 0606i which balancing connector will I need?
Old 06-30-2009, 04:57 PM   #403
Fast XXXS's Avatar
On the black case packs they are flat. Not sure about the new blue packs.
Old 07-02-2009, 06:06 PM   #404
draggin87's Avatar
Trader Rating: 20 (100%+)
The blue 4700 packs have bumps. Im wanting to cut mine off, dose any body know if the bumps are solid or hallow?
Losi 8ight 2.0, O.S. v-spec, JP3
Losi 8ight-t 2.0, O.S. v-spec, JP1
Losi xxx-tcr, Novak brushless
Xray T2 008,Novak brushless, Orion lipos
Futaba 4PK
draggin87 is offline   Reply With Quote
Old 07-10-2009, 10:27 AM   #405
Default Blue 4700 40c pack
Hi
Does anyone know if the new blue 4700 40c packs fit directly in to an Xray 2008, ie without having to modifuy the car or the pack and also without having to use the lipos riser plates.
Are the packs 25 mm with or without the bumps?
mark
Bony85 is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
