Just wondering as it says in the manual its best to store the batteries at half charge. Whats the best way to know that they are half charged? i charge mine at 5 amps as thats the max my charger can go too and just wait till the charge curent drops to 2.5A? does this method method work?
Tamiya TA05MS/ KO Propo Helios/ LRP SPX/ Fantom ION 17.5/ SMC 5200/ Mazda 6
I do not believe that method will get you very close to 1/2 capacity. You can check the voltage of the battery and tell about how close you are. The obvious method is to discharge to cutoff and replace 1/2 the mah rating of the battery. Here is a voltage chart that will give a good idea of where it should be. (about 7.7V for 2S at 50%)
danny when will these 40c 's be available most of the online dealers are out of them. specifically the reinhard pack
Robitronic Team driver
www.IR-CR.com home of the best dirt anywhere and the REAL April Fools Classic
My blood runs red not blue...Tekin
I need some help. I have had 2 5200 swell. I charge at 10amps. Ran one in a 12 minute 17.5 touring car race and the other swelled in a 20 minute practice session in a 2 wheel drive 7.5 mod buggy. I temp the motor and esc they were fine. After letting them sit for a few days the swelling went down but now they both have a bad cell and won't take a charge.
Probably due to taking too much of the capacity out of the packs. 80% is the safe max.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
overdid it!!!! lol that pack is done for sure!!! a 5200 should only be charged at 5 amps, 6 tops. how did it not blow up on you is the ultimate question????
Charging a pack at 2C isn't very hard on it, and definitely won't kill it in one or two cycles. Overdischarging will.
-Nietzsche
if you read the instructions supplied with SMC 5200 40c batteries it outlines that you can charge at up to 3C, how ever this shortens it's life and to stick to 1-2C. So i think charging at 10 amps should be fine.
A 2 cell pack should never get below 6 volts for any extended period of time. If you were running for 12 minutes in a touring car and 20 minutes with a mod motor. The packs were most likely below that 6 volt threshold. If your speed control has a lipo cutoff built in set it to 2s if you are going to be running that long on one battery. There are some companies that make external cutoffs if you can't set it internally.
Well it did hit the cut off on the speedo. They both read 6.4. Since they are 2s2p. I believe that one off the 4 cells that make up the pack. 1 of the cells must have been a little low. I do balance the pack after 2 runs with a hyperion charger.
That's what happens when you push the limits. Still love my packs just won't push them that far again.
Joe, 6.4v measured on a resting pack after the run means the pack is like 99% discharged. Again, 80% is a good limit for long pack life.
-Nietzsche
