Old 10-15-2003, 04:32 AM   #31
Cole Trickle's Avatar
Hmmm. Seems like a proper title of this thread would be "HPI Pro2 Fan Club"
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 10-15-2003, 04:34 AM   #32
Originally posted by Super Steve
what final gear ratio do you guys reccomend for a HOT 14T motor? (Either D5 / D6 / P97/ Kr / Pl / Ti)
Which motor do you guys like the most?
I was thinking of a Kr or Pl but i dunno what kind of final gear ratio i should be running at
I dont have experience with such motors. Stock class is what I'm into. But the usual rule of thumb is: Gear the motor, so the car reach top-end at 3/4 of the longest straight. For more technical tracks, go one tooth less on the pinion. For larger tracks, go one tooth up.
Old 10-15-2003, 04:36 AM   #33
also,
Should you run Just the super front oneway or super front oneway and adjustable middle oneway?
Will this make the car uncontrolable on ashphalt?
You wont gain any advantages by combining af middle one-way and a one-way diff. The adjustable wont be adjustable in this case, since the front one-way will over rule it.
Check this link out, it shold explain the whole story about one-ways: One-way
Old 10-15-2003, 05:12 AM   #34
Super Steve's Avatar
Send a message via AIM to Super Steve
well, having 2 oneways make the oneway action even smoother right? since the Super one way has 4 oneway bearing sinstead of 2, it probably has more friction. ADJ middle oneway can fine tune the smoothness? is there a norm,al middle oneway for pro 2?
Super Steve is offline   Reply With Quote
Old 10-16-2003, 12:56 AM   #35
I've tried running dual one-ways - you cant tell the difference. There's no friction problems in the super front one-way.
You dont need the normal center one-way, just loosen the adjustable one.
I'll strongly recommend you start out with the adjustable one-way alone, since it's very easy to loosen or tigthen. This way you'll get experience in the easy way.
Old 10-16-2003, 08:22 PM   #36
pro 2 is durable!!!
heck, it's more durable then my MT!
Hit the curb few times today...
It went through it all with just scratched wheels!
I have to do a maintence rebuild soon though, just to make sure. However, i might just screw it and do it after the saturday's race!
Old 10-16-2003, 10:02 PM   #37
b0n3z's Avatar
hi
I got a Pro2 i would like to ask you guys if anyone of you has a good setup guide. Are some of the parts from pro2 same with Tamiya TA04 cos here in the Philippines hobby shop doesn't import parts of Pro2 anymore. Thanks
b0n3z is offline   Reply With Quote
Old 10-17-2003, 02:22 AM   #38
Setup suggestions: Pro2 setups (Looks like Pro3, but scroll down and you'll find it)
General setup guide: Xray setup guide and RC Car Handling
Old 10-17-2003, 03:36 AM   #39
Trader Rating: 62 (100%+)
Originally posted by b0n3z
... Are some of the parts from pro2 same with Tamiya TA04 cos here in the Philippines hobby shop doesn't import parts of Pro2 anymore. Thanks
hi there b0n3z. have you tried ritchie ritz hobby shop near bf homes in paranaque? i used to get pro2 parts and hopups there a couple of years ago. maybe they still have some left.
marvi is offline   Reply With Quote
Old 10-18-2003, 05:41 PM   #40
Send a message via AIM to xaznriceracerx
ive got a pro 2 in the mail
http://cgi.ebay.com/ws/eBayISAPI.dll...ory=44020&rd=1
xaznriceracerx is offline   Reply With Quote
Old 10-18-2003, 10:39 PM   #41
icon's Avatar
Send a message via AIM to icon
I loved my Pro 2. Over the years i've had cars come and go, but i probably missed that the most and regret selling it.
But I do have an original 414... . I'm such a traitor! Good thing i dont treat women this way .
icon is offline   Reply With Quote
Old 10-19-2003, 11:07 AM   #42
what kind of settings should i have?
I run on a small/Medium (100feet groove they say but i think it's smaller) It is carpet Trioval course.
Right now i changed to 0degree front antisquat and 8 degree caster with 2 degree upper arm mount (can't find 0 degree upper arm mount) Trying to lay down the shocks as much as i can without using the C hole. Changed to 40Wt with #3 pistons all around.
The question is, should i run yellow front and blue back or blue back and yellow front?
It feels like the yellow ius stiffer then the blue.
Also, I was thinking front purple sway bar and rear no sway bar or pink?
Please help!
thank you
Old 10-19-2003, 11:11 AM   #43
What's a Trioval course?
Old 10-19-2003, 11:12 AM   #44
I dont think I'll ever sell mine Pro2 ! My wife ? Hmmm.... No, just joking !
Old 10-19-2003, 04:13 PM   #45
Trioval looks something like this.
Should i run no sway bar in the rear or pink or purple?
I don't have any greens.
Let me know!
