carpet body?
I have tried the search forum and could not find a good body for carpet?
What I'm using right now is dna1 and i have been out of commission for a couple of years. Any advice would be appreciated. |
DNA has too much steering for carpet. Try the PARMA MOHAWK OR PARMA ALFA ROMEO. They are more neutral. You will see a BIG difference.
Originally Posted by gonzo416
(Post 5097276)
Well if you are new to tc and you may be beating the car off the wall, go with the .30 because its thicker. However that means it heavier, so it up to how you are going to handle the body.
Originally Posted by GCT69
(Post 5097290)
would it be mohawk2, 0.30 or 0.20 mohawks?
You didn't mention if you're runnin foam tire or rubber tire on the rug... for foam, I'd also recommend the Mohawk2, if you're going to be running rubber, I like the Protofom Mazda 6 a lot.
Originally Posted by Trips
(Post 5098251)
I would say Mowhawk 2. (In the Thick version) It will last longer. Also i hear the R-9F is a pretty fast body for foam.
What about the R9-F with foam on carpet?
