Old 10-07-2003, 09:55 AM   #1
Default Help W/ ESC
I have a powerpulse dynamite esc that has lost its breaks and reverse. It goes forward just fine but no more brakes. I adjusted the 2 little screws hoping for a solution but nope I know that its not my radio cause I tried a different one... am i just done with this esc or can I fix it somehow?
zoomin0074 is offline   Reply With Quote
Old 10-07-2003, 11:14 AM   #2
Cole Trickle's Avatar
Sorry to say, but it sounds like the brake/reverse FET's are turned into smoke.
However, to localize the problem, try move the servo plug into the ESC plug on the RX. If the servo works fine, it's quite sure your ESC is gone...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 10-07-2003, 02:01 PM   #3
popsracer's Avatar
Default Help W/ ESC
If you haven't already, try starting from scratch and going through the set-up proceedure again. I have seen certain ESC's lose their program at times (????) and need to be reprogramed to work properly.
popsracer is offline   Reply With Quote
Old 10-07-2003, 04:14 PM   #4
dpaton's Avatar
Send a message via AIM to dpaton
I'm gonna go with Cole on this one. I had the same thing happen to a couple of Tekins back in the day. It's unfortunate...
dpaton is offline   Reply With Quote
SEO by vBSEO 3.5.0
