Like Tree22Likes
Old 01-15-2012, 10:01 AM   #1366
Magnet Top's Avatar
Thanks Freddy!
I'm considering trying my "old" car again just to prove to myself it isn't just the car ! Nah, sometimes it is better to be ignorant !!!
edit :
ok, gotta share this I just read from the the race report :
" Stock TC was the Jake show, though not without some effort on the part of Brian, Lem, and Brett to stave off the inevitable. However, the Slavic Humor Sensation was simply too Awesomatix to be stopped, as he railed the north end S's like a pan car driver and left the fans gasping. "
Jake D.
Magnet Top is offline   Reply With Quote
Old 01-15-2012, 12:45 PM   #1367
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
question to jake
what weight diff oil are you useing ?
OVA is offline   Reply With Quote
Old 01-15-2012, 12:50 PM   #1368
Magnet Top's Avatar
1000 CST ( just fixed the setup sheet. thanks )
To be honest I haven't had much time to test anything other.
Jake D.
Old 01-15-2012, 12:58 PM   #1369
piper48
Guest
Posts: n/a
Jake, that car is on rails buddy. Hard entry, great mid corner speed, and awesome launch out. I've seen my fair share of smooth driving cars this ones the best so far. I gotta admit, I thought the car was all hype but you got that thing working great. Just for shits n giggles, you should break out the TC6 next time.
Old 01-15-2012, 01:10 PM   #1370
Jake,
Congratulations for winning!
Additional fixing of the middle bearing on the steering plate:
1. Remove by needle file or sandpaper the anodisation layer on the contact area of AM10 part under this bearing.
2. Remove the anodisation layers on the contact area of AM10 part and SH1.0 shim under SB3x6 screw.
2. Use Loctite threadlocker between inner ring of this bearing, SH1.0 shim and AM10.
Comment: Threadlocker can't stick to the anodized surface. So you must remove anodisation from contact areas.
Oleg Babich is offline   Reply With Quote
Old 01-15-2012, 01:24 PM   #1371
Magnet Top's Avatar
Thanks Oleg,
I will try this.
Jake D.
Old 01-15-2012, 02:04 PM   #1372
mazmo's Avatar
Default SRS II
I notice most set ups use SRS II for spring adjustment. Assume this makes the spring rate softer, just wondering if there were any other benefits apart from this.
Thanks Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 01-15-2012, 02:08 PM   #1373
Magnet Top's Avatar
Thanks Alan
One thing SRSII allows is heavier damper ratio vs. spring rate.
Jake D.
Old 01-15-2012, 02:39 PM   #1374
mazmo's Avatar
Jake D.
Thanks Jake... and congrats on your win
Old 01-15-2012, 03:15 PM   #1375
Trader Rating: 23 (100%+)
Originally Posted by FreddySudhoff View Post
To be honest I don't have a video. Maybe I can make one at next practice. The track had some hairpins but also long sweepers.
The dampening feels good. Nearly to normal shocks in standard cars and similiar to Ronalds Yokomo.
Here is a picture of the track:
http://www.odw-raceway.de/wp-content...1/IMG_0003.jpg
Thanks. How do you get 5mm in the front, guide dampner?
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 01-15-2012, 03:24 PM   #1376
Oleg,
Have you considered going from a 3 bearing steering plate to a 4 bearing steering plate?
At full-steering lock, tapping the board can derail the steering rack. Had a couple of occurrences past weekend.
Look forward to hearing your thoughts.
TEAMORCA.SHOP
Old 01-15-2012, 06:19 PM   #1377
jake95's Avatar
Trader Rating: 27 (100%+)
hi,
i have heard many great things about this car and im looking at getting one what parts should i buy additionally and also does option tunning parts come in the kit.
thanks,
jake
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 01-15-2012, 06:34 PM   #1378
OVA
OVA's Avatar
Originally Posted by jake95 View Post
hi,
thanks,
jake
- Awesomatix A700 - Mark Dawson - Nice-to-have parts -
PRIORITY 1 - GOOD TO HAVE DAY 1
1. A single complete universal (Page 5) - haven't worn one out or had any failures - typically like to have spares for essential drivetrain components.
2. 1 set of either bronze, round or c-clip bushings (Page 5)
3. SPR07 - E-ring. Very tiny and critical to keeping the clips/bushings in place
4. QTY 1 - C04 Arm - haven't broken one to date but a good just-in-case
5. QTY 1 - P04 Lower Hub Mount - could elongate on serious crash
6. QTY 1 - P01/P02 - Specialized to the A700 and critical to front/rear suspension
7. QTY 1 - Ball End Set - Not specialized for the A700, Kyosho offer similar and upgrade HARD ends.
8. QTY 1 - Long Turnbuckle - the suspension has to have some place to absorb collision. Have bent/broken one of these.
9. QTY 1 - Short Turnbuckle - same as above.
PRIORITY 2 - UNLIKELY YOU WILL NEED RIGHT AWAY - BUT IF IT GOES BAD, YOU ARE PREPARED
1. QTY 2 - B106RS Bearings - haven't worn one out or had any failures - typically like to have spares for essential drivetrain components.
2. QTY 1 - SPR01 - haven't bent one - could potential straighten if needed
3. QTY 1 - SPR02 - haven't bent one - could potential straighten if needed
4. QTY 1 - P09 - frequent changes to suspension might wear plastic part
5. QTY 1 - Gear Diff Rebuild Kit - follow Olegs modification instructions. Surely may not have to rebuild a rear-installed gear diff. But if you run a front gear diff with putty - it might wear faster than the rear.
6. QTY 1 - Extra Spool - haven't worn one out or had any failures - typically like to have spares for essential drivetrain components.
7. QTY 1 - AT04 - Drive Shaft - - haven't worn one out or had any failures - typically like to have spares for essential drivetrain components.
Old 01-15-2012, 07:06 PM   #1379
My revised suggested parts list.
1. A single complete universal (Page 5) - haven't worn one out or had any failures - typically like to have spares for essential drivetrain components.1 set of either bronze, round or c-clip bushings (Page 5)
2. SPR07 - E-ring. Very tiny and critical to keeping the clips/bushings in place
3. QTY 1 - P04 Lower Hub Mount - could elongate on serious crash
4. QTY 1 - P01/P02 - Specialized to the A700 and critical to front/rear suspension
5. QTY 1 - Ball End Set - Not specialized for the A700, Kyosho offers similar and upgrade HARD ends.
6. QTY 1 - Long Turnbuckle - the suspension has to have some place to absorb collision. Have bent/broken one of these.
7. QTY 1 - Short Turnbuckle - same as above.
1. QTY 1 - C04 Arm - haven't broken one to date but a good just-in-case
PRIORITY 3 CHECK TO REBUILD AFTER 1000 LAPS
TEAMORCA.SHOP
Old 01-15-2012, 07:39 PM   #1380
jake95's Avatar
hi,
thanks for fast reply ill go with priority list 1 ive only broke a hub all year in the xray in mod so that stuff should be alright then.also does it come with the tunning options with the kit
thanks,
jake
XRAY✯NOSRAM✯SANWA
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 09:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
