Like Tree11Likes
Old 01-05-2012, 02:53 AM   #1246
JayBee's Avatar
Trader Rating: 31 (100%+)
Oleg, just ordered the kit & more You should have a PM from me as well. Thanks
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-05-2012, 03:18 AM   #1247
OK.
Thank you!
Oleg Babich is offline   Reply With Quote
Old 01-06-2012, 09:02 AM   #1248
Default spur gear installation
Hi, Oleg, I just receive the kits today and it is really a amazing car. I start reading the instruction manual detail and plan to build the car in transverse mode. I find that the spur gear got no pin to lock with the bevel gear...while it seems tightening the 12mm nut to smash the plastic spur gear into to the teeth of the metal bevel gear, is that design capable to handle high power motor such as 4T brushless motor?
tinngsmile is offline   Reply With Quote
Old 01-06-2012, 10:34 AM   #1249
Yes, this design capable to handle 4T motors.
Please use good 12mm wrench, tighten spur nut harder and check tightening of the nut periodically.
Old 01-06-2012, 10:46 AM   #1250
hana166's Avatar
I run transverse, when I fitted it I thought 'No way ever is this gonna work' the power will loosen the thread - its not even left handed..
Honestly I don't know how he got this to work with a right handed thread. But its never come loose even once
When time permits would like to try inline, to see how how it handles when the mass is more centralised
hana166 is offline   Reply With Quote
Old 01-06-2012, 11:55 AM   #1251
Originally Posted by hana166 View Post
Honestly I don't know how he got this to work with a right handed thread. But its never come loose even once......
The nut self-tightens during braking .
Old 01-06-2012, 12:31 PM   #1252
ShrewdRacer's Avatar
genius!
ShrewdRacer is offline   Reply With Quote
Old 01-06-2012, 12:41 PM   #1253
Trader Rating: 30 (97%+)
i saw this car in person and is really sweet, but really need a setup system to adjust the car and set it up, so i assume you all probably have the hudy setup system, or can you adjust it using a regular camber gauge, and rulers, or do you just built it to factory dimensions, and add or take ot shims for final setup.
zaraz is offline   Reply With Quote
Old 01-06-2012, 02:43 PM   #1254
hana166's Avatar
Originally Posted by ShrewdRacer View Post
genius!
Could not have put it better myself
Old 01-06-2012, 10:28 PM   #1255
you still need good setup tools with the other regular/conventionally designed cars if you want to have the same setup run after run. it doesn't have to be hudy mind you, but still, a good setup system is required (with any kit).
Old 01-07-2012, 01:33 AM   #1256
ropezz's Avatar
Tested yesterday the car at my local track (http://www.pistamelzo.it), immediatly found confidence with handling and pleased with set up. The track is very fast (designed for IC 1/8 and 1/10) with a smooth surface, which provides good grip even with low air temperatures. Here is my set up:
Oleg, You have designed a beautifull piece of machinery, congratulations again.
ropezz is offline   Reply With Quote
Old 01-07-2012, 11:44 AM   #1257
I am looking at the setup sheets, now for the chassis, if there is a red circle on the bottom do you have that screw removed or is it there and the others removed, and for the top deck, if there is a x is it cut or it is the one that is not cut thanks
Old 01-07-2012, 04:23 PM   #1258
John Doucakis's Avatar
Default A700 presentation
coming soon...
@ JD & RACING BLOG
John Doucakis is offline   Reply With Quote
Old 01-07-2012, 04:35 PM   #1259
JayBee's Avatar
Is this a forecast of my kit?
Old 01-07-2012, 06:08 PM   #1260
wow that machine work looks incredible. Im planning on buying one next month, it looks like such a great design
www.serpent.com
www.comedycomposite.com
http://www.rc-ride.co.jp/
Titanium is forever...?
Operator27 is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17212 03-22-2017 02:55 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
