Old 12-17-2011, 05:08 AM   #1126
Bubblehead's Avatar
Originally Posted by MDawson View Post
Great way to wrap up 2011 Carpet season!
The car was really good tonight. The car reset TQ through each round of qualifying even with a talented field trying to hunt down best time.
Won the main wire-to-wire. Thanks to the great team at Horsham Raceway for a great Toys For Tots event. A great cause helping the community and kids during the holidays. Awesome power from ORCA, OHP and support from Radiopost.
Mark, which class were you racing boosted or non-boosted (blinky)?
Bubblehead is offline   Reply With Quote
Old 12-17-2011, 06:58 AM   #1127
Trader Rating: 19 (100%+)
Blinky. I have a boosted car but it will need a day of tweaking.
MDawson is offline   Reply With Quote
Old 12-18-2011, 05:55 AM   #1128
mazmo's Avatar
Default Screws too long
Got my A700, just started the build today.
In the first step (C-hubs / steering knuckles) noticed the 5mm screws and ball studs seem too long, hence bottoming out / not screwing all the way in.
Anyone else have this issue, if so how was it resolved?
Thanks in anticipation.
Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 12-18-2011, 07:16 AM   #1129
Alan
Hi Alan
This is ok, as long as the screws are corrrect there should be a bit resistance, the last mil or so, the holes are not tapped the whole way.
Hope this helps
Mark.
MarkMcC is offline   Reply With Quote
Old 12-18-2011, 07:23 AM   #1130
Alan
You can also use a .5mm or 1mm spacer to provide some extra shoulder to support the screw/ball studs.
Old 12-18-2011, 07:52 AM   #1131
In the first step (C-hubs / steering knuckles) noticed the 5mm screws and ball studs seem too long, hence bottoming out / not screwing all the way in...
Alan
The last turns of the lover ST03 Ball Studs and SB3x5 screws are tight.
Screw them with force.
Oleg Babich is offline   Reply With Quote
Old 12-18-2011, 12:25 PM   #1132
mazmo's Avatar
Originally Posted by MarkMcC View Post
Hi Alan
Hope this helps
Mark.
Thanks guys .. was just concerned about stripping the thread from over tightening.
Old 12-19-2011, 01:29 AM   #1133
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
hi Oleg,
letting you know that i have en counted a number of problems with the build
problems:
1.part am06 the shamfer on the hub is 0.4mm to much.x1 hub
2.part at13 shaft on hex 0.13mm to wide not allow bearing to slide on and all so on same part 0.2mm to short x1 hex.all these being out has allowed for major binding of wheel
3.parts pin02 missing from kit.kit needing 3 only have 1. so main drive cant be installed
its a little disappointing to have this as it would be something you expect from a much cheaper kit.but in saying that what was right was beautiful in fit and the car is a work of art.
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 12-19-2011, 06:07 AM   #1134
Originally Posted by P.I.M.P View Post
hi Oleg,
problems:
doesn't sound great though, excuses or not, we're paying $1000+ for this car, you expect it to be perfect! I've got one ordered, no idea when to expect it though!
Mb3195 is offline   Reply With Quote
Old 12-19-2011, 07:32 AM   #1135
Velocitygt's Avatar
Rest assured Oleg will express post any parts that need replacing and is taking every measure to get the factory up the highest standard possible. One can expect a few teething issues with such a massive amount of orders to have process in only the first few months of business.
The car is well worth the wait
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 12-19-2011, 12:36 PM   #1136
I hope it is
Old 12-19-2011, 01:58 PM   #1137
Hi P.I.M.P,
I don't quite understand what problems have you with AM06 and AT13 parts.
Could you please provide me some pictures to explain it.
Does this issue concerns all four AM06 and four AT13 parts?
We haven't received so far claims to those parts and more accurate description of your problem will be very helpful to us.
PIN02 - usually only one PIN02 uses on A700 car.
We put a set of two these pins in kits just in case.
This also applies to some other small parts which we give a few more than is necessary just in case.
Now we are going to increase qty of some others small parts for packing of kit.
We will send you additional pins and replacement parts right after receiving of your exact claim and your address on support@awesomatix.com
Old 12-19-2011, 02:29 PM   #1138
P.I.M.P's Avatar
Hi P.I.M.P,
Hi I will email picture later tonight
Vbc wildfire D06
clinton livingstone
Old 12-19-2011, 05:19 PM   #1139
P.I.M.P's Avatar
Hi P.I.M.P,
hi i think my problem maybe that the pins in the main drive shaft are not pre pressed in but not sure if i have to put them in.going off other shaft cars in the past there pre installed. maybe why im thinking im missing pins???
Vbc wildfire D06
clinton livingstone
Old 12-19-2011, 05:55 PM   #1140
Magnet Top's Avatar
My main drive shaft pins were pressed in at the factory . So, yes, it looks as though they forgot to do yours :-(. Bummer
Magnet Top is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17203 Today 04:17 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
