Like Tree21Likes
Old 12-11-2011, 08:58 AM   #1081
Trader Rating: 23 (100%+)
Originally Posted by John.C View Post
Great run Mark!! Those are some nice looking hardware.
Thanks! How did your car come along?
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 12-11-2011, 11:14 AM   #1082
John.C's Avatar
Trader Rating: 36 (100%+)
Family 'stuff' came up and I ended up missing the TFTs race. I had the car already setup with 1 degree toe out in the front and the rear set to 2.5 degrees. I'll just have to wait till next Saturday to see how it goes.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 12-11-2011, 11:31 AM   #1083
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
Mark Dawson laid smack this weekend. Good work. You drove very well yesterday.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 12-11-2011, 01:05 PM   #1084
Where I can buy this car (please all possibilites, not only official shop).
alejandrospeed is offline   Reply With Quote
Old 12-11-2011, 01:08 PM   #1085
Thanks kid! I am beginning to like carpet Goal is to get rid of the asphalt specialist title!
TEAMORCA.SHOP
Old 12-11-2011, 01:53 PM   #1086
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Does this mean I will see you in IIC Las vegas 2012?
OVA is offline   Reply With Quote
Old 12-11-2011, 08:57 PM   #1087
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default anyone selling
Just wanted to see if anyone in the US might be looking to sell their Awesomatix.
drop me a PM if so.
I am digging the quality of the car. Love the machining of the parts.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 12-11-2011, 09:36 PM   #1088
OVA
OVA's Avatar
Default Awesomatix A700
Mark and jake
I'm all done...electronics and set up next step
Old 12-12-2011, 04:34 AM   #1089
hana166's Avatar
Good to see you went for it Did you receive the long links in the package?
hana166 is offline   Reply With Quote
Old 12-12-2011, 08:08 AM   #1090
OVA
OVA's Avatar
I think so..there's a long turnbuckles came with the kit...not sure what for..
Now I'm begining to understand about the car better than just reading the manual online ....lol
. after building the car ,it make more sense to me to see how the suspension work and set up the car...
I know some people are useing the Oring to hold the two parts together...imo
I think is okay to use the O ring as long they aren't too tight..cause when the lower arm goes up and down the two part slided together in and out..
Question to jake
On your hangar30 set up sheet..your spring load set up is max setting ,why is
that? ( too much rolled or too much steering into the turn)
will the sway help?
Old 12-12-2011, 08:40 AM   #1091
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Right now, that's the only place.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 12-12-2011, 11:22 AM   #1092
Magnet Top's Avatar
Originally Posted by OVA View Post
Question to jake
will the sway help?
Hey Franko,
Glad to see the build went quickly. I spent way too much time gazing at the parts. It took me three days ( according to the time stamps on the pictures ).
Yes, with soft spring rates the car rolled a bit more than I wanted through the chicane near the drivers stand. I wanted it to be more direct and confident through there since a crash there can really tear up a car... but more importantly the stiffer spring rate helped through the bumpy high speed sweeper. My feeling is the car compressed too much and bottoms out upon landing after the car "launched" from the big bump. The result is a snap oversteer. I also had to drive a very precise and smooth arc through the sweeper even with the stiffer spring rate or it would oversteer and I'd have to counter steer a bit ( again, all due to the bumps). That being said, with more track time I bet a softer than max setup is probably best, I just was using coarse "binary" adjustments to see what the car would do with extreme spring settings.
At Time Zone II there were fewer abrupt transitions and no bumps, so I was able to run softer spring rates. Of course I really haven't had adequate time to test and tune at the Hangar or at Time Zone II.
I haven't tried sway bars yet, that could help in the chicane for sure.
I haven't run Symmetrical Damper settings either, so maybe that will help in the bumps and allow softer spring rates. Also, I want to play with bump steer.
And by the way Franko, we will be moving the track position quite a bit this next race so hopefully the bump in the sweeper will be less of an issue. Then the new layout in January should remove these bumps from being as much of a problem. Thats a local thing so if you want to discuss that its probably better to PM me about that than bore everyone here !
Cheers,
Jake D.
Magnet Top is offline   Reply With Quote
Old 12-12-2011, 11:33 AM   #1093
Concerning methods to remove the free play in the damper-spring assembly...
Originally Posted by Velocitygt View Post
Anything holding those 2 parts together is going to cause friction which is worse than the play because it is likely to cause each corner to be slightly different. ....)
I totally agree.
But only lap times must be the evidence of truth.
Please compare it with and without any additional rings or tubes.
Oleg Babich is offline   Reply With Quote
Old 12-12-2011, 12:35 PM   #1094
OVA
OVA's Avatar
Originally Posted by Magnet Top View Post
Hey Franko,
Cheers,
Jake D.
Good point Jake...
Old 12-12-2011, 09:36 PM   #1095
OVA
OVA's Avatar
Here a pic of my A700
LRP SS V2 esc and 1251 Savox servo and 17.5 TP motor and still have alittle more room for PT as well ... but I decided put the PT right side of the chassis...
Awesomatix EP Touring Car (A700 Shaft Drive)-a700-awesomatix-2-001.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-a700-awesomatix-2-002.jpg
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
