Old 12-10-2011, 08:51 AM   #1066
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Originally Posted by MDawson View Post
Vlad or Oleg - can you get back to OVA re: his order?
Ova - happy to share parts I might have to tie you over until your shipment shows up. I have a couple of spares of things. I am not supported by Awesomatix by any means but happy to get you going. LMK.
Hey Dawson
Oleg got to me today..Thanks
OVA is offline   Reply With Quote
Old 12-10-2011, 09:25 AM   #1067
OVA
OVA's Avatar
Originally Posted by Magnet Top View Post
My first aide kit was in a bag amongst all the rest of the kit parts. Regardless, it sounds like he has enough to build it and I have a few spares too if he should need anything. Franko ( Ova ) races at my local track. I guess I'm no longer unique around here. :roll eyes:
Jake D.
Sorry about that Jake.. But look at the bright side you are the team leader of the Awesomatix Team Driver for Pacific NW
Old 12-10-2011, 11:26 AM   #1068
Magnet Top's Avatar
Ha, well you seem to know something I don't know ! But thanks for the unofficial title !
I hope you enjoy your build. Mine took three days. I thought it took longer but I checked the time stamps on my pictures. I stayed up until my eyes stopped focusing two of three nights so it's all a blur now
Jake
Magnet Top is offline   Reply With Quote
Old 12-10-2011, 02:02 PM   #1069
Magnet Top's Avatar
Previously Mark showed his method to remove the free play in the damper-spring assembly using heat shrink. I hadn't actually done anything up until this point so I started applying heat shrink but didn't like the fact it required disassembly of the parts to get the heat shrink into place. So I just tried a small zip tie and it seems to be doing the job well ( on the bench ). I am a bit worried that it is not allowing enough free movement as it is designed to do but that just depends on how tight the zip tie is pulled and whether the particular brand and size used has fine enough teeth to adjust it to ones desire. Anyway, I thought I'd share this alternate method because it doesn't require bending or disassembly but a combination of both heat shrink and a zip tie might be optimal.
Jake D.
Old 12-10-2011, 04:00 PM   #1070
Velocitygt's Avatar
Anything holding those 2 parts together is going to cause friction which is worse than the play because it is likely to cause each corner to be slightly different. I can't see how the play is an issue as the wheel would have to be almost completely unloaded before getting to that play, at which point the suspension is not playing much of a part. In the 5 years of testing they did on the car, if it was an issue it would have been rectified. I wouldnt worry about it, the team drivers dont.
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 12-10-2011, 05:37 PM   #1071
Magnet Top's Avatar
Although I agree that it is of less concern than creating excessive friction I think that a tire that is largely unloaded still can create some havoc if still being "driven" while unsprung even if it is on the light side of the car. I do like to think of droop in respect of the right and left side of the car too, although primarily I think of it front to back and vice versa. Anyway I intend to continue to pursue getting that last couple percent out of the car even if it means going backwards for a bit. It is easy enough to test this back to back to see if the zip ties make an improvement ( or hinders it ! ). I admit a zip tie isn't a perfectly elegant solution, and thus maybe why it is not a part of the kit ( if warranted ). I believe anything can use improvement... anything ! It doesn't mean this isn't already the best chassis available !
Jake D.
Old 12-10-2011, 07:22 PM   #1072
OVA
OVA's Avatar
Jake D.
Hey jake
maybe you can use the plastic dip coating to fill the gap
Old 12-10-2011, 07:57 PM   #1073
John.C's Avatar
Trader Rating: 36 (100%+)
Another option worth considering is the use of O-rings to eliminate the play/slop. You'll only need to pop out the shock rod (ST05) from the arm hasp (P04) to slide the O-ring into place.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 12-10-2011, 09:31 PM   #1074
Trader Rating: 19 (100%+)
Great way to wrap up 2011 Carpet season!
The car was really good tonight. The car reset TQ through each round of qualifying even with a talented field trying to hunt down best time.
Won the main wire-to-wire. Thanks to the great team at Horsham Raceway for a great Toys For Tots event. A great cause helping the community and kids during the holidays. Awesome power from ORCA, OHP and support from Radiopost.
MDawson is offline   Reply With Quote
Old 12-10-2011, 11:14 PM   #1075
OVA
OVA's Avatar
Congrat your win mark..That's Awesome ....
Old 12-11-2011, 02:36 AM   #1076
hana166's Avatar
Agree, and no play if the car is built and set up right, as discussed earlier. This mechanical marvel attracts people with CDO. Its a bit like OCD, but the letters are in the correct alphabetical order
hana166 is offline   Reply With Quote
Old 12-11-2011, 02:53 AM   #1077
Magnet Top's Avatar
Nice win Mark ! Do you even remember the color of the car in second place
Cheers,
Jake
Old 12-11-2011, 03:30 AM   #1078
Magnet Top's Avatar
Thanks John ! An O-ring. Why didn't I think of that!? LOL
By the way, I noticed you put the O-ring near the end of SPR02. Likely you figured out this trick but I didn't initially : I didn't want to have to risk bending the spring possibly permanently deforming it, so rather than tweaking SPR01 to get SPR02 off I simply loosened or removed the set screw retaining SPR02 but instead of pulling SPR02 out completely I shoved it further in to the damper. This allowed it to disengage the spring without having to bend SPR01 out of the way.
Cheers,
Jake
Awesomatix EP Touring Car (A700 Shaft Drive)-screen-shot-2011-12-11-2.23.53-am.png
Old 12-11-2011, 03:55 AM   #1079
I like it, can I use it please.
Bb
bucketboy is offline   Reply With Quote
Old 12-11-2011, 07:20 AM   #1080
John.C's Avatar
Great run Mark!! Those are some nice looking hardware.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17197 Yesterday 02:20 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
