Like Tree13Likes
Old 12-01-2011, 01:02 AM   #976
hana166's Avatar
Originally Posted by Mb3195 View Post
I didnt mean he wasn't, I just wanted to know if he had to add weight on to get to the weight.
Meaning........will the car be able to get down to 1350g for the UK weight.
I'm in the UK and have this car in standard trim
Orion 6500 285g
Xtreme Stock + fan
30mm fan for motor
Savox low profile servo
PF Speed 6 full weight
1332g with Sorex 28JB
Perfect really as Sorex 32 yellow and Sweep EXP30 weigh about 26g more
hana166 is offline   Reply With Quote
Old 12-01-2011, 01:23 AM   #977
Orion 6500 285g
Xtreme Stock + fan
30mm fan for motor
Cool, where do you race and how are you getting on with the car?
Mb3195 is offline   Reply With Quote
Old 12-01-2011, 02:19 AM   #978
Guys, I want to order one, but they are out of stock on their website and its not giving me the option to add to cart.
I have sent a couple of emails to the website email address over the past week but have heard nothing!!
Anyone got any contact details so I can place an order??
Old 12-01-2011, 02:48 AM   #979
1300g with no body? Did you add weight to get it to this? Legal limit in the uk is 1350g with body.
No problems at all mate this is a very light car standard, I'm running a 306g lipo, motor heatsink, slightly heavier Ti turnbuckles, LW speed 6 and 25g of ballast and i'm sitting at 1320g, i'm sure if i wanted I could get her down to 1250g lol. Check out my previous posts for more info.
MarkMcC is offline   Reply With Quote
Old 12-01-2011, 04:14 AM   #980
The only email I have for Oleg is support@awesomatix.com, he is usually quite quick to reply. Hope this helps.
Old 12-01-2011, 04:28 AM   #981
Velocitygt's Avatar
Just for the guys wondering which Bushings/Blades to use in the outdrives. Here is what we have found so far.
Square Brass Bushings - They wear out pretty quickly although do not wear the outdrives at all.
Round Steel Bushings - Zero wear on the bushing and Zero wear on the outdrives after about 30 runs! Awesome.
Cant see why you would use the plastic blades at all when you can use a bushing that doesnt wear and creates zero friction under load due to being able to roll in the outdrive.
We are hoping to find some 2x4x2 chrome steel bearings soon to try.
On the weekend just past Sandy Iavazzo (Awesomatix) won modified with Track record at quite a large event down here in AUS - I ended up fourth. Over 90 entries in total.
Very promising for a car that has only been in our hands for a couple of months.
Next stop is TITC!
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 12-01-2011, 05:26 AM   #982
Trader Rating: 23 (100%+)
Our limit here is 1380. I have 14grams of mid chassis weight, full size servos, heatsink + fan and DCD system mounted.
If I mount a lightweight body, Ill end up at 1385. The weight differential between my lightweight and regular bodies is about 15-22 grams
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 12-01-2011, 05:30 AM   #983
Next stop is TITC!
Found the exact results with the outdrive ends. Bearing replacements could be marginal above the steel bushings. Brian Kinwald developed those for the Losi cars that became known as the BK Bones. Pretty trick back in the day.
TEAMORCA.SHOP
Old 12-01-2011, 05:32 AM   #984
Next stop is TITC!
Cheers Tom, I've only run the brass in the front and plastic in the rear so far, the brass is staring to show some wear now after about 15 runs, so i'll change these out to the steel bushings all round. Let us know how you get on with the bearings!
Glad to hear the car is going as well on ashpalt as it is on carpet. Are there many of you running the A700? Maybe those great results in Oz are the reason the car is currently out of stock. lol.
Old 12-01-2011, 05:37 AM   #985
http://spbusa.thomasnet.com/item/met...earings/672zz?
vlad_vy is offline   Reply With Quote
Old 12-01-2011, 05:40 AM   #986
hana166's Avatar
I'm using the brass. Why didn't I think of it. So obvious once you put it like that
Old 12-01-2011, 07:14 AM   #987
hana166's Avatar
I'm down South, London/Herts/Essex..GMCC and HRCC
I'd say the car is promising because I'm not comfortable at all with the set up yet it produced very fast laptimes almost immediately.
Old 12-01-2011, 09:47 AM   #988
New editable A700 setup sheet at download section replaced with new release. Solved one problem with calculation of suspension stiffness by some PDF readers.
http://awesomatix.com/download/
Old 12-01-2011, 10:46 AM   #989
Don't bother, your current car looked pretty unbeatable last night
Bb
bucketboy is offline   Reply With Quote
Old 12-01-2011, 10:48 AM   #990
Bb
you know me, always like a challenge!
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
