Like Tree13Likes
Old 05-14-2017, 10:58 PM   #9496
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Originally Posted by jessele View Post
Are the flexible castor blocks worth it? If so, do you run a set on the front and rear?
Hi Jesses
here are the things about the Flexible caster block
1. Adjustable caster flex level.
2. Simple camber adjusting without turning of the top turnbuckles.
3. Fixed caster mode is available.
4. Simple caster adjusting (in the fixed caster mode only) without turning of the top turnbuckles.
lock
getting them for you...I would save your money...
Come out this sat at the Seatac track..we are racing for sure...
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 05-22-2017, 02:09 AM   #9497
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Recently purchased a A700L2 and looking for help with setup.
Will be running at my local track (see pics below) and will be running in 21.5T class (will probably run 13.5T next year) Since it is outside track was going to run 48 pitch gearing. Do most brand 48p spurs fit or only certain brands? Only size I have on hand is 72T/80T & 81T so looking at any recommendations so I can do an order for pinions/spurs.
Was also going to rebuild diff & dampers and was going to run Arrowmax Fluids which are in CST. I use to run TLR Fluids in offroad which went via WT. Any recommendations on what CST to start off with in dampers and diff?
vivo quevas likes this.
Drift_Buggy is offline   Reply With Quote
Old 05-22-2017, 04:32 AM   #9498
howardcano's Avatar
Trader Rating: 35 (100%+)
I use the Robinson Racing machined spurs in 48 pitch; #1860 is a 60 tooth. For larger tracks and/or lower-revving motors, you may want to use the 55 tooth, #1855.
Drift_Buggy likes this.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 05-22-2017, 08:50 AM   #9499
Madulla's Avatar
Does your L2 even come with rebuildable dampers...
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 05-23-2017, 06:44 AM   #9500
Trader Rating: 14 (100%+)
Need some input. Crc black carpet which a700 suits this best
Evo with flex
L version but I still have the flex chassis on it
Does the front whole diff moving side to side the best a700 model to have
Rcforlife13 is offline   Reply With Quote
Old 05-29-2017, 08:38 AM   #9501
Need some help
Old 06-01-2017, 04:59 AM   #9502
howardcano's Avatar
Evo with flex
I haven't responded so far since I have only run carbon fiber chassis. But in my experience it would be best if you used whatever chassis gives the lowest center of gravity (CG).
Our local track recently changed from gray to black carpet, and my car became "tippy" to the point of being nearly undriveable, so I decided to get back to basics. I removed as much weight as I could from as high up as possible, including eliminating the top deck. Then I purchased a shorty LiPo, sacrificing some horsepower for lower weight. Finally I added a 1/4"x1/2"x5.72" piece of brass on the main chassis, securing it down the longitudinal centerline using the existing holes in the chassis. The brass adds rigidity in both torsion and bending, and significantly lowers the CG. All of this reduced my lap times by about 5%.
I have removed the floating front gearbox arrangement from all of my cars, and I'm quite happy with the results.
Howard Cano
Old 06-09-2017, 07:37 AM   #9503
patorz31's Avatar
Anyone have a mm2 they want to part with or a parts car with a mm2 on it?
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 06-13-2017, 11:20 AM   #9504
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Are there any steel replacement diff gears for A700? Will Tamiya TB04 steel diff gears work?
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 06-13-2017, 01:46 PM   #9505
The CG in the stock A700 is so low that it would be impossible to traction roll on crc carpet with properly glued front tires, and a ultra lightweight sweep stc6 body... I can't even traction roll my tc4 with that setup...lol.... A700 with every electronics mounted on the main chassis of course. I even have the top deck screws switched to aluminum...
bertrandsv87 is offline   Reply With Quote
Old 06-13-2017, 02:14 PM   #9506
howardcano's Avatar
Not rolling over, just tippy. With the mods I made, the car keeps all the tires down better, which prevents wheelspin on the inside tires. The maximum cornering speed (lateral acceleration) is increased due to the reduced weight transfer.
The result is similar to driving a 200mm pan car on high-grip carpet, then swapping over to a 235mm car. They both get around the track okay, but the 235mm car is simply faster due to the increased stability in the corners.
Howard Cano
Old 06-13-2017, 03:44 PM   #9507
JayL's Avatar
There used to be some ages ago, I think Shepard made them.
nobody ever ran them since even in mod the plastic ones work perfect and last.
Are you stripping them? change you shimming or try xray gears
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 06-13-2017, 05:14 PM   #9508
Understood..... I've reserved my A700 for asphalt Mod Racing: I guess it's a more forgiving surface.... Happy racing ......
Old 06-13-2017, 05:37 PM   #9509
G05ST 20T Steel Gear x 2 ? AWESOMATIX
G06ST 10T Steel Gear x 4 ? AWESOMATIX
Oleg Babich is offline   Reply With Quote
Old 06-23-2017, 04:21 AM   #9510
Got an L2 w/S2 chassis. What is best way to do tweak?
Read on Awesomatix site After a crash itís sometimes a bit tweaked. In this case we untighten all lower screws and tighten them from the center out to the ends.
Is this the best way of doing it?
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
tandman
