Like Tree25Likes
Old 03-04-2017, 06:03 AM   #9451
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by jessele View Post
Thanks!!! I'll order some up now. Just out of curiosity do you happen what spur gear brands fit the spur gear holder?
Thanks!
I haven't tried other brands on the A700, but maybe other readers can answer.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 03-04-2017, 10:45 AM   #9452
daktulos's Avatar
To respond to Howard on the A700 a lot of spur choice is available. Take note that I am only running 64P gears so your mileage may vary...For 17.5 and USGT I play with a spur size of 78T to 84T but generally run 82T.
It also depends if you are running a spur dampener and/or witch version you run.
With no spur dampener you have a lot of choice but ultra slim spur or offset spur may be a problem with the placement of the locating pins.
I prefer machined spur with a flat surface all around with about 3mm of thickness on the the SD1 (also need to drill two 5mm holes)...PRS is the way to go if you are able to grab some. The SD1 is a good compromise but you are very limited on spur choice...maybe somebody can chime in on that. The ARC spur is flat but too thin and you need to be creative to make it work.
On the SD2 you can run almost any brand of spur gears but overtime the SD2 create some loose/wobble so I prefer a spur gear that have some thickness on the gear area like Robinson or Xenon VSS to limit the chance of stripping the gear.
If you run a higher wind motor class like USGT no real need to add the mass of a dampener
Whatever you run if you are able to find PRS spur gears grab some on carpet I am able to run the same PRS gear for a season!
My small list by preference...
- PRS...no SD OK SD1 OK SD2 OK (durable and perfectly straight)
- Xenon VSS...no SD OK SD1 not OK SD2 OK (durable and straight white so you see when the gear have debris inside)
- Robinson...no SD OK SD1 not OK SD2 OK (medium durable but cheap easy to find and straight)
- Axon...no SD OK SD1 not OK SD2 OK (on hand but never tried it seems durable and straight but on the soft side like the Robinson)
- ARC...no SD OK SD1 maybe OK SD2 OK (medium durable and not straight)
Short awnser go grab a PRS if you can get them or buy a Robinson lol
daktulos is offline   Reply With Quote
Old 03-04-2017, 09:35 PM   #9453
nexxus's Avatar
Trader Rating: 302 (100%+)
For 21.5 racing I was using a Robinson 48P 50T pinion, had to add a 0.5mm shim under the ffg brace to clear the pinion as we were geared around FDR 2.7
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 03-10-2017, 02:25 PM   #9454
Had a installation question about the Rear Floating Gear box. When I attached DT03 stepped bushing between AM81 and AM44-1, the gear box does not swivel left and right. Any ideas what I'm doing wrong?
jessele is offline   Reply With Quote
Old 03-10-2017, 03:21 PM   #9455
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Hi jesses
You are not doing any things wrong...the RFG doesn't swivel left and right
it only allow the rear chassis of the car to flex more thus increasing overall rear end grip/traction.
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 03-10-2017, 07:15 PM   #9456
Originally Posted by OVA View Post
Hi jesses
Thanks for the confirmation Frankie!
Sorry another question... instructions shows the use of p11 sleeve between the spur gear holder At20 and bevel gear G03. In doing so, I have tons of slop. If I remove it, everything is nice and perfect with no play at all. So do I not use P11 with the rear floating gearbox?
Old 03-10-2017, 11:01 PM   #9457
OVA
OVA's Avatar
Hey jesses
use the DT03 instead P11
Old 03-12-2017, 01:02 AM   #9458
Thanks for all the help Ova! One last question for now - I just purchased a new gear diff (GD2-S) and the normal din screw that goes in the output shaft were not included with the kit, but rather 2 small blue sponges in their place. Any idea where they are suppose to go?
Thanks in advance!
EDIT: figured it out - location was shown in the A800 manual.
Old 03-12-2017, 04:02 AM   #9459
OVA
OVA's Avatar
Thanks in advance!
Well I never got the Blue sponges came with GD2 in the nip
far as I can see the sponges suppose seal the oil
Old 03-13-2017, 09:26 AM   #9460
daktulos's Avatar
Sorry if I am late for the diff question but for buyers of the latest revision A700 or parts you can follow the Max Mächler Awesomatix A800X Build's Tips & Tricks
Awesomatix A800X - Max Mächler - Build's Tips & Tricks
Yes some parts are different but for the diff just build it like Max said and you should not have any issues
Old 03-15-2017, 04:19 PM   #9461
whats a good starting diff weight to use for asphalt?
on a side note, looks like my panaracer spur gear rubs the lower mm2 mount. What she spacer fits around the spur holder?
Old 03-15-2017, 07:09 PM   #9462
nexxus's Avatar
3k on the rear diff for spec classes 5k for modified
Old 04-03-2017, 03:16 PM   #9463
What's the minimum and maximum wheelbase on the Evo2?
Old 04-25-2017, 01:03 PM   #9464
Can you someone recommend a Final Drive to run? Im running a Muchmore 13.5 and have 89T Spur gear.
Thanks!
Old 04-29-2017, 05:44 PM   #9465
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Are parts still easy to obtain with the A700?
Drift_Buggy is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
