Like Tree25Likes
Old 02-10-2017, 07:53 PM   #9436
helltank's Avatar
If anyone is interested I have a used A700 Evo to let go. PM to discuss shipping from Singapore. Used Awesomatix A700 Evo
Tamiya 419X (Prototype) | Smokem | Raceberry | Sanwa M12S
helltank is offline   Reply With Quote
Old 02-18-2017, 05:03 PM   #9437
Would servo would you guys go with? The awesomatix servo or ko propo bsx2 oneten response?
Thanks!
jessele is offline   Reply With Quote
Old 02-18-2017, 06:42 PM   #9438
Madulla's Avatar
Does anyone make an aftermarket chassis for the evo2? My carbon one has delaminated in the front. I race on black carpet so I was going to go aluminum.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 02-18-2017, 07:25 PM   #9439
http://shop.awesomatix.com/index.php?productID=1057
Oleg Babich is offline   Reply With Quote
Old 02-19-2017, 12:11 PM   #9440
Try a good CA glue to save the chassis...
bertrandsv87 is offline   Reply With Quote
Old 02-27-2017, 01:31 AM   #9441
S. Patchara with A700 Evo won non boost 17.5T class at TITC 2017.
Congratulations!
Awesomatix EP Touring Car (A700 Shaft Drive)-img_7086-s.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-img_7090-s.jpg
chiefj48 likes this.
Old 02-27-2017, 08:36 AM   #9442
Great win Patchara.....
Old 02-27-2017, 11:04 PM   #9443
Im looking at upgrading the ball ends and turnbuckles to titanium and all I can find are kits for A800. Do the a800 and a700 share the same length in turnbuckles? and are the quantity of ball ends the same (4.8mm -qty16 ; 5mm -qty8)? Sorry i dont have my A700 Evo 2 yet as it's still in enroute. Thanks!
Old 02-28-2017, 06:16 AM   #9444
It's been a while since I bought turnbuckles for my A700. From what I remember all links should be similar to the A800 except the steering links, the A700 will be shorter.
malkiy is offline   Reply With Quote
Old 02-28-2017, 11:15 PM   #9445
Hi,
Can the new servo holder AM24-8 be used in A700 lower deck (C01L2)?
BTW, I found the searching result at awesomatix.ch is quite strange, not all matching items are listed. You may try input "servo" or "deck" to see.
ricekwan is offline   Reply With Quote
Old 03-01-2017, 02:00 AM   #9446
Originally Posted by ricekwan View Post
Hi,
Yes, via two screws - same as old AM24.
Old 03-01-2017, 09:35 AM   #9447
What spur gear brands fit the a700? Also can you guys recommend a spur gear size and pinion set for just cruising around parking lots and a set for tight technical asphalt track?
Old 03-01-2017, 10:10 AM   #9448
howardcano's Avatar
Trader Rating: 35 (100%+)
I use the Robinson Racing "48P Pro Machined Spur Gear", 60 teeth, # 1860. With this 60T spur, a range of pinions from 27T to 34T covers all of the tracks where I race, small to big, in VTA, USGT, and 17.5 TC classes.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 03-01-2017, 05:24 PM   #9449
daktulos's Avatar
Once in awhile I take pictures of my rides and just want to share that one
Show me your A700!
daktulos is offline   Reply With Quote
Old 03-03-2017, 01:28 PM   #9450
Thanks!!! I'll order some up now. Just out of curiosity do you happen what spur gear brands fit the spur gear holder?
Thanks!
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
