Like Tree25Likes
Old 12-11-2015, 03:53 AM   #9061
blarks's Avatar
Trader Rating: 29 (100%+)
Originally Posted by sg1735 View Post
They deteriorate over time, one will leak a little and then the feel corner to corner will not be the same. You can feel the difference if you remove them and rotate then in your hand. The d2 dampers are probaly the single best improvement to the car
Thanks sg, I know the d2's are the go, just trying to justify the cost of the upgrade, and avoid it if possible. But I will most probably get the d2 set.
blarks is offline   Reply With Quote
Old 12-13-2015, 12:00 AM   #9062
nexxus's Avatar
Trader Rating: 302 (100%+)
Picked up an older A700L with the traverse mount (as opposed to longtitude) and figured I'd give that a spin for a laugh, took half the races to get the spur / pulley to stop loosening off, but this thing makes a racket even compared to the std set up on the Evo. That bevel gear mesh is smooth but LOUD (perhaps a tooth is chipped)
Ended due to an issue with the motor / esc but it's interesting how far ahead even this is compared to the TC6's etc
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 12-14-2015, 07:59 AM   #9063
Trader Rating: 45 (100%+)
Default T.O.P. Racing Ballcups and Ballstuds
Morning Guys,
I picked up a like new EVO 2 and am trying to build up my spares/upgrade supplies. I seen the Awesomatix Wiki and the recommended spares there.
I was going to upgrade with the TOP Racing ballcups and studs and was wondering if you guys can point me in the right direction:
There are two TOP ballcups that I know of shown here in the picture, do I need to use the longer or shorter ones?
Is the picture above the correct ballstuds I need? These replace the ballstuds correct?
These components replace only the upper inner link ballstuds ST-24 correct? Trying to figure out quantities required of each.
Last: Besides the awesomatix wiki spares listed, are there any other spares for the Evo 2 that are good to have around?
Thanks,
Aaron
Pro-Line/Protoform, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 12-14-2015, 08:14 AM   #9064
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
If you have an EVO 2 the top upgrade really isn't necessary.. Tht upgrade was for the earlier cars .. The newer ball cups work fine spend your money on other spares
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 12-14-2015, 08:20 AM   #9065
Sal Amato's Avatar
I'd say in my short experience these are a must in spares
PO3-arm ball cap
P04-arm hasp
P05-sway bar joint
P07- arm clip
Spr02- shock rod guide
Spro5l- shock rod
B106RS- wheel bearings
P01-outer turnbuckle end
P02-outer turnbuckle end
P13-4- inner turnbuckle end
p-14 front bumper
Option parts are
Hard front bumper
Titanium turnbuckles
At21s lower roll center balls for arm
ST24L longer shank ball studs for adding extra shims for adjustments
I would also get some of the ECS parts
360 RC SPEEDWAY 2.0
Old 12-15-2015, 10:29 AM   #9066
josecarlo1129's Avatar
Originally Posted by Antimullet View Post
Morning Guys,
Attachment 1335009
Attachment 1335008
Thanks,
Aaron
TOP ballcups (short & long) is a must have + the 5mm studs, for me. It is robust.
The combination of the TOP 4.8mm ballstuds and P03 is amazing as well. the P03 floats and rotates freely (no need of pinching) and you won't be needing the SH 1.0 spacers at all.
I will try to take photos of these for your reference.
JC
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 12-15-2015, 10:58 AM   #9067
Thanks for the input guys looking
forward to running this exotic machine!
Old 12-18-2015, 10:43 AM   #9068
As said earlier, herewith is the photo of TOPS 4.8 studs combined with P03.
I am rebuilding my 2nd A700 (for carpet use) with the RFG. I'll post soon about the TOPS Short and Long Ballcups + TOPS 5mm studs.
Cheers and happy holidays!
JC
Old 12-18-2015, 11:44 AM   #9069
Magnet Top's Avatar
JC
Sort of looks like you are building a trebuchet !
Happy Holidays to you too !
https://en.wikipedia.org/wiki/Trebuchet
.... The trebuchet is a compound machine—a combination of simple machines. The trebuchet makes use of the mechanical advantage of a lever......
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is online now   Reply With Quote
Old 12-20-2015, 06:51 PM   #9070
nexxus's Avatar
Ran my older A700EX on the weekend, after all sorts of issues with the spur coming loose (and the nut having a damaged thread) we ended up gluing it down and that worked, ended up using a Traxxas motor mount screw on the pulley as it has a large flanged head so I could lock it down without binding it up. Car was f.. loud lol! And I can say that the Mazda GX6 shell is a dog on our track, particularly on the right hand hairpins it just wanted to kick the back end out.
Waiting on parts (shocks) to get my Evo up to Evo 2 spec as I have already done the MM2
I have a spare FFG set what can I use on this to go to RFG (ie would it work out cheaper than buying the full RFG kit)
Old 12-20-2015, 08:25 PM   #9071
Interesting!
Well, back to my build, I found out that everything can float in A700 Evo II.
Since I got the RFG, I made use of the now-spare AM19 and AMA40 to create a floating flatform for the ESC and Receiver with single screw from the lower deck.
I think, I am all set for the forthcoming carpet season.
Picture attached for reference.
Cheers!
Old 12-21-2015, 05:34 PM   #9072
nexxus's Avatar
So it seems that all the Awesomatix gurus are in the A800 thread, does noone support the lowly A700 now?
Is anyone else having issues when ordering ex Taiwan?
Oleg advised they were closed for "some reasons" 15-18 Dec but nothing has updated since, and emails are unanswered. The order was placed Dec 13 and I paid for EMS freight as I wanted the items before Xmas to do a rebuild over the vacation period.
Old 12-21-2015, 06:43 PM   #9073
Default MM2
Can the new Motor Mount MM2 be used with the C01-AL chassis plate?
Thanks,
Brian
Aquaracer is offline   Reply With Quote
Old 12-21-2015, 08:40 PM   #9074
howardcano's Avatar
Trader Rating: 35 (100%+)
Interesting!
Cheers!
Which way do you want your diff facing?
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 12-21-2015, 09:55 PM   #9075
blarks's Avatar
maybe you need to open a paypal claim? Might be a bit harsh but if your not getting any response then you can either continue to wait or go to paypal. Frustrating when you pay for ems.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
