Like Tree22Likes
Old 12-05-2015, 10:39 PM   #9046
nexxus's Avatar
Trader Rating: 302 (100%+)
Originally Posted by DamageNZ View Post
Hi all,
I have put my A700 Evo together, set it up and put it on the track and it goes really well! My only complaint is the steering. It has a wide turning circle - even at low speed, and just doesnt have the aggressive turn-in I like. I do not have a caster doodle, so the caster will be off slightly (set as best I can for the mean time).
Does anyone have any ideas on what I could do to increase the turn-in and make the turn radius smaller? I'm currently running 2k in the rear diff, spool front. 1.5 camber Front, 2.5 rear. 1deg front toe, 3deg rear.
Cheers,
Glen
I'm at that stage too, same class (21.5) the car tended to push on corner exit particularly on a sharp right hander just didn't bring itself around enough and was clipping the left hand wall on exit.
A lot of different opinions on set up and to be honest I feel like the dumb kid in the class asking all the questions that I have, but what did help me was removing the swaybars altogether and giving the front a little more caster (4 degrees or so)
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 12-06-2015, 06:16 AM   #9047
hanulec's Avatar
Trader Rating: 27 (100%+)
?? Not enough turn in. That is either 1) physical servo/steering setup issue. How many degrees of throw do you have on setup gauges? 2) a setup problem with not running the front end softer than rear end
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-06-2015, 08:03 AM   #9048
Oh wow, i run 21.5 and 17.5 on A700s and no car in my club can turn like or has a smaller turn radius than the awesomatix. Mike is right, should just be the setup.
Awesomatix Sanwa Trinity Tamiya
voodoo is offline   Reply With Quote
Old 12-06-2015, 03:20 PM   #9049
Cadman1981's Avatar
I have to ask, now that the A800 has been released, is there still development on the A700 series?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 12-06-2015, 05:19 PM   #9050
josecarlo1129's Avatar
Have you tried yet the, RFG, MM2, SD2?
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 12-07-2015, 07:19 AM   #9051
Cadman1981's Avatar
I have the MM2, and SD2 installed, no FFG or RFG, but that doesn't really answer my question.
I'm just curious, as going belt drive removes the need for FFG and RFG development, as the belt has "slack" that the shaft drive doesn't, making the car "softer" when accelerating due to the torque transfers, which has already been discussed many times
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 12-07-2015, 10:14 AM   #9052
Hey guys I have a FFG kit with top deck listed in the forsale thread and I also have a original COAL alloy chassis listed. Thanks
Team Trinity/ReVtech - Awesomatix USA- Wild Turbo Fans-TQ wire-MRH Racing
sg1735 is offline   Reply With Quote
Old 12-09-2015, 06:01 AM   #9053
If anyone is looking to sell their a700 let me know
missouri racer is offline   Reply With Quote
Old 12-09-2015, 06:18 AM   #9054
flionbrian's Avatar
Massouri Racer, I sent you a PM.
flionbrian is offline   Reply With Quote
Old 12-09-2015, 12:14 PM   #9055
Trader Rating: 44 (100%+)
Anyone with an evo 2 or a well modded older shaft version looking to sell send me a pm as well please.
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 12-09-2015, 12:16 PM   #9056
Oleg said he would continue to develop both cars. Post 194 in the A800 thread.
malkiy is offline   Reply With Quote
Old 12-09-2015, 12:44 PM   #9057
DS Motorsport's Avatar
Send you both a PM.
My car is still for available:
Awesomatix A700 Evo, full options, almost new!!
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-09-2015, 01:19 PM   #9058
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
http://www.rctech.net/forum/r-c-item...ew-spares.html
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 12-10-2015, 01:49 AM   #9059
blarks's Avatar
Trader Rating: 29 (100%+)
What is the life expectancy of the original a700 dampers, will they perform as the day they were made forever or will they deteriorate?
blarks is online now   Reply With Quote
Old 12-10-2015, 05:29 AM   #9060
They deteriorate over time, one will leak a little and then the feel corner to corner will not be the same. You can feel the difference if you remove them and rotate then in your hand. The d2 dampers are probaly the single best improvement to the car
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 09:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
