Like Tree22Likes
Old 11-27-2015, 05:19 PM   #9001
nexxus's Avatar
Trader Rating: 302 (100%+)
Originally Posted by hanulec View Post
Outdoors you should run a ltc-r. Can u fill the sheet in electronically so we can see the spring rate right?
Also, im shocked to see front end caster loss. We've only run that at huge tracks with mod motors.
With the Mazda body I run 12 degrees rear caster out (or back) to extend the wheelbase, with the LTC-R body I use the same set up but 0 rear caster.
I have attached a sheet done on the PC but I always get muddled with the camber links on the sheet as to what is on the car with the optional extra bits etc
I think I have it right
I have attached a pic of the car, different motor in, I have noticed a glaring error I have to adjust on the car see if you can see it too.
Awesomatix EP Touring Car (A700 Shaft Drive)-img_3816.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-epson005.jpg
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 11-27-2015, 05:25 PM   #9002
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
12 degrees caster?????
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 11-27-2015, 06:05 PM   #9003
Xpress's Avatar
12 degrees caster or the birds nest of wires?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 11-27-2015, 06:12 PM   #9004
nexxus's Avatar
Don't think that's needed. I explained the rear caster (my reading is that it just affects wheelbase and nothing else) and the wires, well I prefer to have the set up done before I work on it being pretty.
Old 11-27-2015, 06:56 PM   #9005
It doesnt just affect wheelbase. It affects a ton of things.
Old 11-27-2015, 07:34 PM   #9006
nexxus's Avatar
Originally Posted by artwork View Post
It is mostly used to change wheelbase on the car... -4 would be a shorter wheel base!
I was working on the above post going back a year or two which indicated (to me anyway) that +12 caster gave me a longer wheel base, when the question was previously asked what effect rear caster had the discussion seemed to indicate it only impacted wheelbase.
But ok besides the caster issue, how's the rest look?
Old 11-28-2015, 01:30 AM   #9007
Top links are on back to front.
Simon Noton is offline   Reply With Quote
Old 11-29-2015, 05:08 PM   #9008
nexxus's Avatar
Default Updated but this is doing my head in
Ok thanks for the feedback I have altered what I had and it does feel better but the back still feels stiffer than the front, I pulled the shock units out of the holder and the shaft feels noticably tighter than those on the front. Both are L6/R6 units but I can't see any reason for it.
How are we looking now?
Old 11-29-2015, 05:52 PM   #9009
hanulec's Avatar
Trader Rating: 27 (100%+)
nexxus - the d2.0/d2.1 shocks were made on purpose to allow re-filling. this keeps them consistent over time. the d6 and d3 dampers could leak out. depending upon air / track temp, this occurred more if the track was super hot.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-30-2015, 05:20 PM   #9010
jdawg81's Avatar
I have an A700L that I race in 17.5 TC stock on indoor carpet. I was wondering if there's any advantage in switching to an alloy chassis such as the C01AL-S2 or am I better off with the stock carbon chassis?
jdawg81 is offline   Reply With Quote
Old 11-30-2015, 05:31 PM   #9011
hanulec's Avatar
Car will be quicker when grip gets high. Chassis flexes less
Old 11-30-2015, 05:36 PM   #9012
daktulos's Avatar
I run a upgraded A700l equivalent of a A700L2 and on high grip carpet the aluminum chassis really wake up the car. With the brace you have the possibility to alter the flex on low traction days.
It depends really of your budget you may start with some D2.1 shocks if your #6 shocks are old and upgrade to an aluminum S2 and MM2 motor mount later...
The issue with upgrading a "L" is that for the same price you may find an used EVO that is technically more easy to drive consistently...
My two cents
daktulos is offline   Reply With Quote
Old 11-30-2015, 06:05 PM   #9013
nexxus's Avatar
For carpet Alloy for Asphalt Carbon is the way I work it anyway. First upgrade I'd do is MM2 as it makes life a lot easier, and get some spares particularly P04, and a could of arms.
Old 11-30-2015, 06:12 PM   #9014
jdawg81's Avatar
My two cents
Alright good to know that the alloy chassis is better as I assumed it was only good for outdoors. I've already installed the D2.1 dampers and I was just thinking of what to upgrade next to improve the car a little more. Yes I realize that I might be able to find a used Evo with an alloy chassis but not many come up for sale locally. And when one does come up for sale it's still much more expensive than buying just the chassis and the MM2 motor mount together.
Old 11-30-2015, 06:29 PM   #9015
daktulos's Avatar
If you go that way PM me I can share you a Gee inspired setup that work well for me and some parts or modification that are needed to convert a L to an aluminum chassis.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 09:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
