Like Tree25Likes
Old 11-10-2015, 03:41 AM   #8986
josecarlo1129's Avatar
Same here, been using the TOP balls and ends from the start with no problems. Still 'feels' sturdy and tight.
*my battle-car (for asphalt)
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 11-16-2015, 11:43 AM   #8987
hana166's Avatar
If anyone has a set of d2 dampers, not d2.1, I'd be OK with just the vanes and top caps, please give me a shout.
hana166 is offline   Reply With Quote
Old 11-16-2015, 12:59 PM   #8988
WesRaven's Avatar
Just to be clear, you're talking about the version that uses the smaller OR15, correct? If so I believe I have a set of these (vanes and caps). I'll make sure when I get home from work tonight.
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 11-20-2015, 11:24 PM   #8989
My Evo II is all set for the indoor series/season!
Old 11-22-2015, 10:26 PM   #8990
I have been running UB-1's on my 17.5 car and seem to be chewing up the bearings at an alarming rate. Is there anyway/anywhere i can buy a couple bearing sets? im to the point that ive used up 2 full sets of bearings and have a bunch of pins in my parts box and have had to start running the bushings again.
Doug Smith
Cheers.
Doug Smith
RC America - X-ray - Hudy - Motive
doug smith is offline   Reply With Quote
Old 11-23-2015, 04:48 AM   #8991
hanulec's Avatar
Trader Rating: 27 (100%+)
Bearing don't wear. That is their point.
Something else -- spool/diff drive cup and or bent axle are causing this issue.
The main amtx site should have these small bearings for sale..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-23-2015, 08:28 AM   #8992
Perfect thank you very much, and that is exactly what my thought process was with trying them, I will have to take a closer look at my car when i get home. I am thinking a new set of ST-37's will be a good place to start.
Doug Smith
Cheers.
Doug Smith
Old 11-26-2015, 01:31 AM   #8993
Trader Rating: 32 (100%+)
Got a A700 EvoII.
Really like the handling & feel, but have a 2 issues here.
Dampers & gear diff are leaking all times.
What is your leak proof method???
hobbs is offline   Reply With Quote
Old 11-26-2015, 07:59 AM   #8994
howardcano's Avatar
Trader Rating: 35 (100%+)
Does anyone have a good way of removing the ST07 outdrives from the AT23/AT24 diff case halves? As near as I can tell from the manual, the outdrives are only held in by an O-ring; there are no pins or C-clips to remove. If that is correct, then these O-rings must be made from some super-secret-high-strength rubber. I have tried pulling on the outdrives, and even tapping them from the opposite side with a pin and hammer, but they refuse to budge. What am I missing?
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 11-26-2015, 08:03 AM   #8995
hanulec's Avatar
Originally Posted by hobbs View Post
Got a A700 EvoII.
Use Dow 55 on orings
If you diff has orings on the outdrives then you have st23/26 and not st07. The oring is hiding a pin02
Old 11-26-2015, 08:19 AM   #8996
howardcano's Avatar
NOW I know what those O-rings are for. Thanks!
Howard Cano
Old 11-26-2015, 08:41 AM   #8997
I did apply AE green slime on all orings, not good enough???
Frankly, no question about my building skill.
I have tried many times to build the damper & gear diff, but they still leak.
Old 11-26-2015, 10:14 AM   #8998
hanulec's Avatar
DOW55 is simply just better.
The A800 is also now using a P45 down the center of the new D2.1 dampers. People seem to be happy w/ them...
Old 11-27-2015, 12:30 AM   #8999
nexxus's Avatar
Trader Rating: 302 (100%+)
Well I have rebuilt my car and settled on a new starting set up and would appreciate a bit of feedback. It is a large outdoor flowing track with a tight chicane area, so I find for my driving style the longer the wheelbase the better. I am running 21.5 Blinky and track is usually low - medium traction.
Laptimes for 21.5 are around 20 seconds a lap.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 11-27-2015, 05:59 AM   #9000
hanulec's Avatar
Outdoors you should run a ltc-r. Can u fill the sheet in electronically so we can see the spring rate right?
Also, im shocked to see front end caster loss. We've only run that at huge tracks with mod motors.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
