Like Tree13Likes
Old 11-01-2015, 04:45 PM   #8956
Schwarta's Avatar
Originally Posted by geeunit1014 View Post
Probably some rub from the am49 tower, look if it's right there. If so, you can try to shim it up with .1 shims.
Yeah, I just saw the rub mark, do you think it will cause me trouble though? In 13.5 Blinky? Not sure if they're solid or hollow?
Schwarta is offline   Reply With Quote
Old 11-01-2015, 04:53 PM   #8957
It's a solid drive shaft, i wouldn't worry.
malkiy is offline   Reply With Quote
Old 11-01-2015, 04:54 PM   #8958
Schwarta's Avatar
Sweet, thanks.
Old 11-01-2015, 10:48 PM   #8959
Default Correct rear steering arm?
Hey guys, can someone confirm if this is the correct rear steering arm for the EvoII? I'm following the instructions on building the upper rear arms, 10.3mm and 12.4mm for the links. I'm not getting anywhere near the 1.5 degree camber, -4 degree caster, 3 degree toe in that is listed in the instructions.
AL
www.carcar.ca / www.karz.ca
ALBOP is offline   Reply With Quote
Old 11-01-2015, 11:09 PM   #8960
never trust the link measurements. just adjust them to get the caster, camber and toe you need.
Awesomatix Sanwa Trinity Tamiya
voodoo is offline   Reply With Quote
Old 11-02-2015, 06:01 AM   #8961
blarks's Avatar
Trader Rating: 29 (100%+)
Long time admirer of this car, now finally was able to pick up a 2nd had a700l from an rctech member. I would like to know if anyone has had any experience/purchasing from the main awesomatix site not the USA site and if their purchases went smoothly? I have placed/paid for an order with them 2 days ago and haven't had any communication from them yet. I guess I will leave it for another day and email them if nothing by tomorrow.
blarks is offline   Reply With Quote
Old 11-02-2015, 06:32 AM   #8962
Schwarta's Avatar
I've ordered from there quite a few times. Never had a problem.
Old 11-02-2015, 06:38 AM   #8963
daktulos's Avatar
Like Voodoo says for the length of the links but at least check the link symmetry it can be off a tad because of slope on car and setup station but higher will mean something is wrong...
The AM23 you show it's the old style arm the AM23-1 (one position) is the proper EVOII arm. It's longer probably to conserve the geometry of the shorter wheelbase of the newer chassis (Aluminum S1, S2 and Carbon L2).
Personally I always used the inside (shorter) position. Experts can explain you the real effect of the position
AM23 on top of AM23-1
AM23 vs AM23-1
Personally I would use the more inside position and call it a day for now and on your next order buy the AM23-1 arm.
daktulos is offline   Reply With Quote
Old 11-02-2015, 06:42 AM   #8964
blarks's Avatar
Thanks Schwarta, I will wait a little longer.
Old 11-02-2015, 07:17 AM   #8965
daktulos's Avatar
Hi ALBOP,
You wont like me but when I look again at your picture I remark a few things.
On your next order I advise you to buy the long shock rod (ST05L) to prevent the binding of the shock rod guide (SPR02) and damaging the shock shaft.
At the same time you may also buy some sway bar stopper (P42) to prevent extreme side to side movement of the sway bars.
Sway bar is of the older type also (colored one vs black with white marks) but if they are straight I don't think it's worth to buy new ones.
Nothing very urgent but trust me the long shock rods will pay for themselves in the long run.
My two cents
Old 11-02-2015, 11:23 AM   #8966
WesRaven's Avatar
I have ordered from the main site a few times when the USA site was out of stock with 100% success, so you can definitely trust them. The payment process was a little unorthodox from what I'm used to though; Rather than paying immediately on the site they sent me an invoice to pay through PayPal. The first time I made an order through them this invoice email went into my Junk folder, so I thought I was being ignored as well. Once I paid the invoice they were very responsive.
So moral of the story is if you haven't actually paid yet, check your junk box for an email from "support@awesomatix.com".
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 11-02-2015, 02:01 PM   #8967
i replaced the chassis on my Evo2 since it was pretty beat up from some asphalt use. In my spare time I decided to sand the finish off it, thought I'd share. It's kinda cool actually, might end up using it at some point.
branover is offline   Reply With Quote
Old 11-02-2015, 03:39 PM   #8968
bkspeedo's Avatar
It would be interesting to see if you feel a difference in chassis flex running with and without the ano. Anodizing can actually add some lateral and torsional flex stiffness.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 11-02-2015, 03:45 PM   #8969
nexxus's Avatar
Trader Rating: 301 (100%+)
Has anyone else noticed that when using MM2 and a 37t pinion it hits the top of the brace on the spur gear? I put 1mm spacers under it last race meet but not sure if this is viable long term. Need to get down to a FDR around 2.9 for 21.5 blinky and the smallest gearing I can do is 37/50 which is just in the ballpark.
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 11-02-2015, 04:22 PM   #8970
Originally Posted by daktulos View Post
Hi ALBOP,
My two cents
Cool thanks daktulos! I appreciate the info
AL
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17214 07-12-2017 05:33 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
