Like Tree13Likes
Old 10-27-2015, 01:49 AM   #8941
nexxus's Avatar
Trader Rating: 301 (100%+)
Originally Posted by Schwarta View Post
What the...!!?
I think you can bend the spr02 if you don't set the upstop correctly. Never heard of the spr03 bending. I believe you can bend the spr02 back as a temporary fix.
I've got some spare spr02's if you need them in a hurry.
I had some spare so sorted just as I bought a 2nd handy having a tough time completing a race so I have torn it down completely and it was a train wreck. (Ex carpet car from crux888) Hoping I got most of it done now, then it's a case of upgrade to Evo 2 spec I guess)
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 10-27-2015, 02:20 AM   #8942
Schwarta's Avatar
Yep, no substitute for a nice fresh new car!!
Schwarta is offline   Reply With Quote
Old 10-27-2015, 09:13 AM   #8943
Company Representative
Trader Rating: 15 (100%+)
Originally Posted by Oleg Babich View Post
ST05L longer shock rods are useful against SPR02 bending.
Agree 100%
I am very picky when it comes to SP02's being straight, esp when using the new dampeners. Even with the down stops and up stop set correctly the flex in the graphite arm can cause them to tweak from time to time. Since switching to the "L" shock rods the SP2's have been much better. A Worthwhile upgrade IMHO.
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 10-28-2015, 03:17 AM   #8944
scoyle's Avatar
Hello,
I have ordered an A800 but decided to pick up an A700 as well to see the engineering before my A800 arrives. When I bought it on eBay the guy said it was an original A700 with the FFG. Is there any way to confirm what version I have as it comes with some different things from the original I think including the cuts in the chassis and the different battery holders?
It seems to be in great condition but I just want to make sure I download the right manual and a good starting setup for carpet.
See the attached pictures...
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 10-28-2015, 06:40 AM   #8945
hana166's Avatar
Originally Posted by scoyle View Post
Hello,
Attachment 1325816
Attachment 1325817
Attachment 1325818
I am the original owner of this car.
hana166 is offline   Reply With Quote
Old 10-28-2015, 08:02 AM   #8946
scoyle's Avatar
Guys, I am working my way through the near 600 pages of this thread...
But as I am racing on Saturday with my A700L with FFG on carpet, medium grip, could someone recommend a setup for me to start with please?
Old 10-28-2015, 08:16 PM   #8947
Hi Mike, I'm looking for AM81 but can't find it. Do you have it in stock? Cheer.
_jf__ is offline   Reply With Quote
Old 10-28-2015, 09:02 PM   #8948
bkspeedo's Avatar
This is an older setup for the just he L but give it a try since your running the carbon chassis. This should be a decent starting point.
I'm assuming your running 17.5 or slower? If your running Mod there's other setups that will work better.
File Type: pdf Kyle Klingforth - 5280 - L 17.5 Aug2014-2.pdf (384.0 KB, 130 views)
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-29-2015, 03:01 AM   #8949
scoyle's Avatar
Thank you very much for your help... we run 13.5 boosted on a reasonably large track. I have also been told that I am #3 dampers which I believe are lighter. Would you have any recommended settings for carpet for the #3 dampers?
Old 10-31-2015, 04:02 PM   #8950
scoyle's Avatar
Hello,
I ran my A700L today and it was great...but the car was very noisey under braking to the point where I was afraid to brake. Is there anything that I need to look at or is this just because it us a shaft drive car?
Old 10-31-2015, 04:20 PM   #8951
It should not be noisy under braking. It should sound the same as a belt car, no noise at all. Sounds like the bulkhead gears aren't shimmed properly.
malkiy is offline   Reply With Quote
Old 10-31-2015, 04:23 PM   #8952
scoyle's Avatar
Thank you, I am planning a rebuild so hopefully will get it sorted.
Old 10-31-2015, 04:33 PM   #8953
kgombe's Avatar
i had the same problem, anti was the gear on the spool coming off
Kijana Crichton
kgombe is offline   Reply With Quote
Old 11-01-2015, 03:52 PM   #8954
Schwarta's Avatar
Just doing a rebuild before our nationals. And noticed on my shaft AT04-2 there's a couple of rub marks/gouges. Not sure when it was done, certainly wasn't there before our State titles at the start of October? And I've only raced once since?
Will this be ok to race with? 13.5 Blinky? Could the RFG of been the cause?
If I switch back to my old AT04, will I need to run the bearing support?
Cheers.
Old 11-01-2015, 04:30 PM   #8955
geeunit1014's Avatar
Probably some rub from the am49 tower, look if it's right there. If so, you can try to shim it up with .1 shims.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
