Like Tree13Likes
Old 09-28-2015, 05:41 AM   #8851
Originally Posted by nexxus View Post
Any ideas where to get the arms from? Phillipines awesomatix store is out of stock, and the USA store checkout quotd $58.50 usd std post for 3 arms and a set of caster doodads!
Philippines? As I know we don't have a store there.
Two versions are available from Taiwan store:
http://shop.awesomatix.com/index.php?productID=1073
http://shop.awesomatix.com/index.php?productID=1045
Oleg Babich is offline   Reply With Quote
Old 09-28-2015, 06:35 AM   #8852
nexxus's Avatar
Trader Rating: 301 (100%+)
Thats the one I meant lol! Is the alloy one any "stronger"?
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 09-28-2015, 06:36 AM   #8853
nexxus's Avatar
Originally Posted by XCELL View Post
Paul from Bezerk Rc can make you some. You can contact on Facebook, he is located in Melbourne I believe.
Patrick
Thanks for that, ordered 5! (Just in case!)
Old 09-28-2015, 11:29 AM   #8854
Trader Rating: 18 (100%+)
I had a chance to run the EVO2 IIC car with the RFG in Mod and Stock. The car seems to have more rear traction mid corner and corner exit! The balance is near perfect now.
I ran the stock car with 48 pitch and no SD[x] without problems. Generally I would strip a gear on a hard hit, but this wasn't the case with the RFG. The Mod car was run with SD2.
If you want to view my mod run have a look here at 1:43.
http://livestream.com/tvtruck/events/4372900
Wayne Mah
Sponsors: Avid Racing -- ORCA -- Kyosho -- Awesomatix -- Pro-line -- Protoform -- Team Great Hobbies
SkaterX is offline   Reply With Quote
Old 09-28-2015, 12:01 PM   #8855
Nice run Wayne, any chance you can post your setup as well?
AL
www.carcar.ca / www.karz.ca
ALBOP is offline   Reply With Quote
Old 09-28-2015, 01:40 PM   #8856
Schwarta's Avatar
Can he do the current arm? The C04M? How much for them?
Also, am I able to use the AT12M without the o'ring?
Schwarta is offline   Reply With Quote
Old 09-28-2015, 01:45 PM   #8857
Patrick
I use them on my car, They're very well made and I haven't broken one yet. They also make adjusting the droop easy as the screws are in the arms.
Does anyone use the alloy chassis on their cars? I'm thinking of buy one as I like running my car with a stiff chassis
danielc3009 is offline   Reply With Quote
Old 09-28-2015, 02:01 PM   #8858
Schwarta's Avatar
I'm currently running the alloy chassis, the good thing with the awesomatix is you can alter the stiffness with how many screws you use in the stiffener.
Old 09-28-2015, 02:18 PM   #8859
Trader Rating: 32 (100%+)
The current alloy chassis is not stiffer.
Monti
Monti is offline   Reply With Quote
Old 09-28-2015, 03:17 PM   #8860
I believe it will be uploaded to the awesomatixusa.com site in the near future. I don't have a way to upload the file and RCtech attachment limit is too low.
Wayne Mah
Old 09-28-2015, 04:11 PM   #8861
hanulec's Avatar
Trader Rating: 27 (100%+)
uploaded. great job again Wayne.. lets keep it up!
http://www.awesomatixusa.com/p/setup-sheets.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-28-2015, 06:00 PM   #8862
nexxus's Avatar
Looking at the alloy chassis myself. On the arms, I decided to go with normal style for now, as I don't know if any of the others are usable, and I'm working on the usual teething issues you get running a new chassis (particularly one bought 2nd hand that ran carpet), I think some of the issues may have been due to pre-existing damage I hadn't noted.
Old 09-28-2015, 07:49 PM   #8863
hanulec's Avatar
Nexxus-- I've never seen a bent alloy arm-- just saying...
Old 09-29-2015, 12:55 PM   #8864
Monti
So what's the advantage of the alloy chassis?
I doubt it would make much difference to the centre of gravity as it already lower than a regular touring car.
Also how much heavier is the alloy chassis and brace than the carbon one?
Old 09-29-2015, 02:24 PM   #8865
Magnet Top's Avatar
Alloy has different flex characteristics compared to the carbon weaves.
And lowering the CG is really important. The awesomatix has an advantage over other cars with regard to this but why not gain an even further advantage by lowering the CG by .5 mm further by using the thin alloy version over the carbon version. At the big high grip races on carpet I've benefitted from not traction rolling or getting "tippy" while other cars struggle. That .5 mm across the entire chassis isn't trivial, imho.
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
