Like Tree13Likes
Old 09-27-2015, 02:02 PM   #8836
erchn's Avatar
Originally Posted by waltss2k View Post
What is the low pro balls -- at 21's?
http://shop.awesomatix.com/index.php?productID=880
Lower roll centers.
erchn is offline   Reply With Quote
Old 09-27-2015, 05:12 PM   #8837
Schwarta's Avatar
Sounds brutal Nexxus.
So had a race the other night with the RFG. Certainly didn't feel like grip had increased to start with. Tried removing shims in the upper links on the rear. Increased rear toe. But the biggest change seemed to be when I shortened the wheelbase with the rear caster setting and removed the top deck. That really locked the back end in. The next race I put the top deck back on which freed it a bit, but still plenty of grip.
Also, when I was changing a rear setting with the caster doodles on, I noticed the caster changed under travel even though I had the same height spacers under both mounts. It went from 0 to 2* long under full travel. But I'll double check this arvo.
Schwarta is offline   Reply With Quote
Old 09-27-2015, 05:21 PM   #8838
hanulec's Avatar
Trader Rating: 27 (100%+)
toe in/out changes with the RFG-- as the pickup location is different. you'll need to adjust the shims on the am23 to compensate.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-27-2015, 06:05 PM   #8839
Schwarta's Avatar
I'll double check when I get home, but it was the caster changing. Not the toe in. Like reactive caster, but the shims were the same size.
Old 09-27-2015, 06:51 PM   #8840
nexxus's Avatar
Trader Rating: 301 (100%+)
..Brutal is one word for it! Are these cars inherently fragile or am I just lucky (unlucky?) Seems that my T4 took harder hits and just kept going, this is only in 21.5, so I shudder to think of the potential carnage in Mod TC!
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 09-27-2015, 06:59 PM   #8841
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Its not going to be as tough as an X-Ray, but it is more durable than my TRF418.
Dan is offline   Reply With Quote
Old 09-27-2015, 07:22 PM   #8842
hanulec's Avatar
Rear caster changes effect the rear toe change too.
4degrees is similar to adding 1.75mm
Old 09-27-2015, 07:23 PM   #8843
hanulec's Avatar
The amtx is probably the 2nd strongest car (behind xray)
You must put a real bumper on the car if your prone to hitting things. Other common/simple things like cutting Your axles must be done.
Old 09-27-2015, 07:33 PM   #8844
Magnet Top's Avatar
When you change the rear caster the static toe changes but also the bump toe ( through suspension travel. ) So you MUST adjust the shims to keep the toe from changing as it moves. Or you can use bump toe as an advantage, especially on smooth surfaces.
I believe Hanulec was also referring to the different pickup point of the inner toe link being different when using the RFG option , so setups from non RFG cars have a different shim thickness than what is listed on a particular setup.
Jake
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 09-27-2015, 11:04 PM   #8845
nexxus's Avatar
Some pictures of the carnage:
.these suspension arms should be straight right?
..and this is in 21.5!
Awesomatix EP Touring Car (A700 Shaft Drive)-img_3550.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-img_3551.jpg
Old 09-28-2015, 12:51 AM   #8846
Nexxus, you got a heat gun? put the arm on a flat surface (preferably something that wont melt like glass) and heat it, it'll be back to straight like new in seconds.
i find my kit tougher than expected.
Awesomatix Sanwa Trinity Tamiya
voodoo is offline   Reply With Quote
Old 09-28-2015, 01:05 AM   #8847
nexxus's Avatar
Just found the other side is like that too so maybe they're not meant to be dead straight?
Old 09-28-2015, 02:42 AM   #8848
Trader Rating: 55 (100%+)
They are bent. Replace and check all suspension parts.
Jamison R is offline   Reply With Quote
Old 09-28-2015, 02:44 AM   #8849
nexxus's Avatar
Any ideas where to get the arms from? Phillipines awesomatix store is out of stock, and the USA store checkout quotd $58.50 usd std post for 3 arms and a set of caster doodads!
Old 09-28-2015, 02:53 AM   #8850
Paul from Bezerk Rc can make you some. You can contact on Facebook, he is located in Melbourne I believe.
Patrick
XCELL is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 Yesterday 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
