Like Tree13Likes
Old 09-23-2015, 04:22 AM   #8821
Schwarta's Avatar
Originally Posted by hanulec View Post
Nexxus - the same advise from last page applies to your problem...
Awesomatix EP Touring Car (A700 Shaft Drive)
Was just about to post this.
Also, with not using am69 do I need to use mode 3 or 4 on the motor mount? Currently have mode 1.
The st03 are a larger diameter than the at24 aren't they? As for some reason, I had at24's installed in the hubs (on the bottom), not sure why the previous owner did that? As there were some spare st03's in the box.
Schwarta is offline   Reply With Quote
Old 09-25-2015, 05:13 AM   #8822
Schwarta's Avatar
So, got my RFG and installed it today. Is there any videos of how much movement there should be? As I've got a little movement, but not much. When it does move, it's smooth, but feels tight, but not sure if that's just because it's only a small bit of play?
Old 09-25-2015, 05:45 AM   #8823
hanulec's Avatar
Trader Rating: 27 (100%+)
No video
The movement is very small.. Yet effective on the track. Generates more grip in rear than we've ever had within the A700 platform
hanulec is offline   Reply With Quote
Old 09-25-2015, 07:33 AM   #8824
nexxus's Avatar
Trader Rating: 301 (100%+)
Trying to set my car up again, I can't get the front ride height any more than 6mm no matter how much I tighten the ride height screws down. Usually we run 6.5-7mm height on the large outdoor track
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 09-25-2015, 08:24 AM   #8825
Magnet Top's Avatar
Make sure your droop screws ( down stop ) aren't limiting your ride height. ( loosen droop screws )
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 09-25-2015, 08:27 AM   #8826
nexxus's Avatar
Droop is fine I can get the car to raise to 10mm before the tyres lift
Old 09-25-2015, 08:31 AM   #8827
Check your plastic blocks. The screw holes strip very easily.
malkiy is offline   Reply With Quote
Old 09-25-2015, 08:33 AM   #8828
Magnet Top's Avatar
How thick are the shims under the front A arms ?
What tires / rim combo ?
Is it possible you don't have the correct ride height screws installed ( too short ) ?
Old 09-26-2015, 08:34 PM   #8829
waltss2k's Avatar
Is there a good set up for a Low bite carpet. I'm running a 700L with FFG.
waltss2k is offline   Reply With Quote
Old 09-27-2015, 05:59 AM   #8830
hanulec's Avatar
A700L + FFG is an A700 Evo
Please look at the Fairtrace setup from Snowbirds. That year the tires were harder than usual (although my preference) .. And that setup works very well on low grip
http://www.awesomatixusa.com/p/setup-sheets.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
Old 09-27-2015, 07:09 AM   #8831
nexxus's Avatar
So had my first race meet, 21.5 Blinky, large flowing outdoor asphalt.
Q1 Ran into lapped cars, got t boned, left a nasty crack in the CF chassis, sealed with CA Glue, front hub came adrift, replaced a P04
Q2 Qualified well set track record in 21.5 with 19.16 second lap
Q3 Overcooked it heading onto the front straight and clipped the wall with the front left. Broke a P01 and P02, replaced, found the driveshaft had lost ST10 and ST11, did not have spares so tried to rig some wire to tie the CVD to the outdrive for the finals.
F1 - Forgot to retighten RH screw from front left, bailed on final.
F2 - Going well, car felt loose front left, bit of wire gave way, shunting me into the back left wall, Suspect damage to P04 on front left, back left spring popped out from P04 there also CF hub on front came loose (P06-1 popped off AT21, P07 was still in place)
So there it is, car felt good but some niggly issues, not sure if this is a durability issue or an unlucky day, regardless I need to order some bits. Any ideas?
Old 09-27-2015, 07:13 AM   #8832
hanulec's Avatar
If hubs are popping out of p04 please check the arm too. Often the circle becomes an oval.
P01/02 issues can be resolved with a zip tie or a little glue in the cross joint.
Other spares to have-- st05.
Old 09-27-2015, 07:40 AM   #8833
waltss2k's Avatar
I neededto add that I am running a 21.5 usgt class as well. If it matters. And by the way thanks for the help Hanulec
Old 09-27-2015, 08:42 AM   #8834
hanulec's Avatar
Setup is great for 13.5 too
Not the low pro balls -- at21s
Old 09-27-2015, 02:00 PM   #8835
waltss2k's Avatar
What is the low pro balls -- at 21's?
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
