Like Tree22Likes
Old 09-22-2015, 01:51 PM   #8806
Originally Posted by hanulec View Post
is this w/ fresh P03 or re-used P03?
i do see more play -- but 1mm is nothing i've ever seen.
With new P03.
Maybe 1mm is a bit much but it's at least .05-.07mm. It's definitely noticeable when you compare it with AT21 which has almost no play.
Any way to remove the play or do you just live with it?
malkiy is offline   Reply With Quote
Old 09-22-2015, 02:49 PM   #8807
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by malkiy View Post
With new P03.
i see about 1/2mm. everyone i know just lives with it. hasn't been holding anyone back
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-22-2015, 02:51 PM   #8808
That's exactly the amount of play (.5-.75mm) i have now when i changed over to new at21s' s and p03's. The lower balls seemed to make the play between the st05 into the spr01/02 slightly worse. I was thinking to use a little heat shrink tubing over part of the spr02 to help shim up st05 tighter.
Also, what mode is recommended for the mm2 with rfg? Right now, it's in mode 3 but the rfg seems tight. If i loosen the screw, it moves smooth like the ffg. Do i have this right?
vapourtrail is offline   Reply With Quote
Old 09-22-2015, 02:53 PM   #8809
hanulec's Avatar
RFG instructions show mode 4
Old 09-22-2015, 03:06 PM   #8810
geeunit1014's Avatar
There should be 0 play between the st05/spr02 under any circumstances. Check that the spr02 are not bent and the travel in the damper is set properly. Also if the ride height or droop are severely off it can cause play there
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 09-22-2015, 03:32 PM   #8811
hanulec's Avatar
loosening the dampers within the holders, and then bottoming out the suspension is a great way to get the ST05 + SPR02 mesh right.
Old 09-22-2015, 04:10 PM   #8812
Mode 4, got it. Thanks!
I agree there shouldn't be any play. Spr02's don't appear bent. When i assembled my evo2 earlier this year, i did see how the d2 vane and the spr02 stop (on the damper mount) needed to bottom out simultaneously and it's set there.
I'll try resetting the dampers. Thanks guys!
Old 09-22-2015, 04:14 PM   #8813
Schwarta's Avatar
I found that if the downstop setting is around 4-5 on droop blocks I get play between spr02 and st05, but that measures 4-5mm+ over ride height.
Schwarta is offline   Reply With Quote
Old 09-22-2015, 05:08 PM   #8814
hanulec's Avatar
D2 (new) or old dampers?
Old 09-22-2015, 05:38 PM   #8815
Schwarta's Avatar
New ones.
Old 09-22-2015, 05:56 PM   #8816
hanulec's Avatar
New ones.
Yeah your problem is because of the position of the damper in relation to everything else. Loosen the cylinders in the damper holders. Setup the car. Compress the suspension a few items and then retighten.
Using a 14.5 to 15mm upstop is also recommend
Old 09-22-2015, 06:08 PM   #8817
nexxus's Avatar
Trader Rating: 302 (100%+)
...all this talk about rfg and V2 shocks, alloy chassis etc is doing my head in guys! All I know is my A700 is just a V1 with FFG and MM2, shocks and springs are set up but I haven't touched roll centres or even looked at camber yet but already it feels better to drive than my T4 15', on a large outdoor track it's far more forgiving and if you get it a bit loose (silly me ran Solaris Hard's on a 22c day) it's a lot easier to recover. On a large outdoor fast flowing track, should I be dropping the roll centre shims from 3mm and 2mm (front and back on upper arm) to something lower? Ideally I want to use the efficiency of the shaft drive to my advantage running 21.5 spec, so the response out of a corner and off a dead start is where I want to have the most traction.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 09-22-2015, 07:23 PM   #8818
hanulec's Avatar
nexxus - is there something wrong with your car's handling?? you're going to have to vocalize what is not good for us to help you.
the best drivers i know "tinker" -- they try different settings. use the lap counter + feel to find what you want...
Old 09-22-2015, 07:41 PM   #8819
nexxus's Avatar
Sorry I should have been clearer, I'm chasing a bit more stability mid corner, at the moment if I take things a bit too aggressively it tends to step out. I am not running sway bars at the moment as they seemed to make things worse. Would removing shims from the top roll centre links on the bulkhead help there?
Old 09-23-2015, 03:45 AM   #8820
hanulec's Avatar
Nexxus - the same advise from last page applies to your problem...
Awesomatix EP Touring Car (A700 Shaft Drive)
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 09:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
