Like Tree13Likes
Old 09-18-2015, 11:38 AM   #8791
Schwarta's Avatar
Originally Posted by geeunit1014 View Post
Yes, you need set screws in the am49s to hold the ffg rod in place
Thanks. So tight? Or just enough to hold it and be free? And no screw in the centre of the top deck.
I just realised I bought a Carbon FFG to cut in half. Will it make much difference compared to the alloy one?
Cheers.
Schwarta is offline   Reply With Quote
Old 09-18-2015, 03:16 PM   #8792
Trader Rating: 32 (100%+)
Cheers.
No
Monti
Monti is offline   Reply With Quote
Old 09-20-2015, 05:08 AM   #8793
Schwarta's Avatar
Tried Mike's setup (excpet for Am06m, which will be here tomorrow), although not as much as I'd like, as we got rained out.
Was a bit loose mid corner, what will the am06m add to the car?
Old 09-20-2015, 05:25 AM   #8794
geeunit1014's Avatar
Rear grip I tried going back to the am06s on the rear one week and it made the car very loose
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 09-20-2015, 06:52 AM   #8795
hanulec's Avatar
Trader Rating: 27 (100%+)
as Gee said, hubs will help a ton.
additionally, if you're still loose in the mid corner, (not sure of the exact setup but...) you got 3-4 great options in order that i'd use them--
#1 adjust rear toe gain/loss. you'll want more toe-in. remove some shims (~1mm to see a change) at the bottom on the AM23
#2 more static rear toe in
#3 decrease the inner rear camber length height. think of the inner camber links this way --- if you want more grip, lower the link. if you want less grip (and to free the car) raise the link.
#4 adjust rear camber (depending upon what it is currently at). some tires like more camber. others dont. watch the tire -- especially when they are new, you can see the contact patch. somewhere between 1.5mm to 2.25mm in rear camber can be good options.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-20-2015, 07:10 AM   #8796
Xpress's Avatar
Originally Posted by Dan View Post
Lost you as a potential customer because the manufacturer offered you more performance options (which are optional by the way)?
I guess you can always get a cookie-cutter belt touring car. A dime a dozen...
You never know.....it might soon be a dime a baker's dozen.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 09-20-2015, 02:26 PM   #8797
Schwarta's Avatar
Ok, thanks. I thought the hubs added grip, but wasn't positive.
Thanks for that Hanulec, I'll add this to my notes. I was thinking about the rear bump steer and how much effect it has?
Really contemplating getting the RFG, as most tracks we race on are on the med-low grip side. Would raising the bulkheads still work with the RFG, or would it grip it up too much with both?
Old 09-21-2015, 09:42 AM   #8798
Ray k's Avatar
Trader Rating: 46 (98%+)
FJ , When will SPR-02's be instock ?
Ray k is offline   Reply With Quote
Old 09-21-2015, 09:47 AM   #8799
hanulec's Avatar
Hopefully sometime this week
Old 09-21-2015, 01:37 PM   #8800
Schwarta's Avatar
So do people still mount the battery on am69 and cut off the tab so it sits on the chassis. Or just mount it direct to the chassis?
Old 09-21-2015, 04:18 PM   #8801
hanulec's Avatar
Without am69
Old 09-22-2015, 09:45 AM   #8802
Originally Posted by bkspeedo View Post
Great idea, someone should productiz this
If you let me know what chassis you're running I can make one for about $23 shipped with screws
Larrysraceprep is offline   Reply With Quote
Old 09-22-2015, 12:53 PM   #8803
hanulec's Avatar
http://www.awesomatixusa.com/2015/09...-re-stock.html
Old 09-22-2015, 01:15 PM   #8804
Has anyone noticed some up/down play with the AT21S and P03? AT21S seems to have a lot more play than the AT21, 1mm of movement.
malkiy is offline   Reply With Quote
Old 09-22-2015, 01:45 PM   #8805
hanulec's Avatar
is this w/ fresh P03 or re-used P03?
i do see more play -- but 1mm is nothing i've ever seen.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
