Like Tree13Likes
Old 09-13-2015, 05:42 PM   #8776
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Aquaracer View Post
I currently have an A700L with a carbon chassis and run it in USGT.
The tracks I drive on are low-medium grip carpet.
I have a couple of questions:
1. If I am to change the chassis to the Aluminum Chassis (C01-AL) is the center support for the drive shaft that has 2 bearings necessary to have if converting?
2. If it is necessary, what part number is it?
3. What kind/ type of handling characteristic changes would I see going from carbon to aluminum?
Thanks,
Brian
C01AL are no longer available.
C01AL-S or C01AL-S2 (if you have MM2, or upgrade to it) would be options along w/ the AM30-5 or AM33-5 brace.
The -S and -S2 alloy chassis along w/ the brace allow you to tune the flex characteristics of the chassis. An alloy chassis in general will excel as grip raises.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-13-2015, 06:43 PM   #8777
nexxus's Avatar
Trader Rating: 301 (100%+)
I was always told Alloy chassis is for carpet, Carbon is for asphalt?
Getting my A700 times within 0.3 a second per lap of my T4 15, and thats only setting the shocks and springs etc, haven't touched sway bars, camber etc yet. Did lunch a spur though (oops)
This is running blinky 21.5
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 09-13-2015, 07:48 PM   #8778
hanulec's Avatar
the awesomatix C01AL-S and C01AL-S2 chassis are different than your every other manufacture alloy chassis. the stiffness can be adjusted. we ran the alloy chassis outdoor all summer..
Old 09-13-2015, 08:15 PM   #8779
Yesterday an Awesomatix A700 with aluminum chassis TQ'd at our local outdoor asphalt track.
The track is fairly big and we ran modified.
The car was dialed!!
Ted Su(TW) is offline   Reply With Quote
Old 09-14-2015, 01:01 AM   #8780
nexxus's Avatar
How do you stick down the electrics though? Almost nothing to stick to with the large cut outs!
Old 09-14-2015, 04:30 AM   #8781
hanulec's Avatar
Good servo tape
I'd recommend the stuff from TOP Racing.. Or similar
Old 09-15-2015, 06:42 PM   #8782
Schwarta's Avatar
What's the consensus on the RFG? We tend to have low grips surfaces here in Oz. I'm only running 13.5 at the moment, but will probably eventually move up to mod?
Schwarta is offline   Reply With Quote
Old 09-16-2015, 12:45 AM   #8783
I actually made carbon fiber plates the hold all the electronics floating above the chassis they Attach with two screw holes down the centerline of the car works great and easy to change out your electronics
Larrysraceprep is offline   Reply With Quote
Old 09-16-2015, 12:47 AM   #8784
Here's one of the different car
Old 09-16-2015, 05:51 AM   #8785
hanulec's Avatar
hi - i've probably run the car on the lowest grip surface w/ the RFG. the car ran a bit more consistent w/ the RFG -- but i wasn't in a big horsepower class -- but may folks do think my 17.5 motors are quick.
next for me is to try the RFG indoors on carpet as my outdoor season is done...
Old 09-16-2015, 03:22 PM   #8786
WesRaven's Avatar
The bearing support is mainly needed when running the older and thinner AT04 drive shaft. The upgraded thicker AT04-2 shouldn't need it. Basically it keeps the drive shaft from wobbling at high speed. I would personally rather upgrade to the thicker drive shaft rather than run the old bearing support.
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 09-16-2015, 07:53 PM   #8787
bkspeedo's Avatar
Great idea, someone should productiz this
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-17-2015, 04:39 AM   #8788
Thank you for that info, I have got one on order now.
Aquaracer is offline   Reply With Quote
Old 09-18-2015, 05:58 AM   #8789
Schwarta's Avatar
Originally Posted by geeunit1014 View Post
Front bulkhead is +1mm, rear is +2mm. You will need to add 2mm to the shims that connect the motor mount to the rear bulkhead to keep the motor mount in the correct spot.
pic of ffg setup
Going to try this setup tomorrow. Do you need to make sure the screws in the top deck go through to the FFG rod slightly, to hold it in place?
Old 09-18-2015, 06:27 AM   #8790
geeunit1014's Avatar
Yes, you need set screws in the am49s to hold the ffg rod in place
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
