Like Tree22Likes
Old 08-23-2015, 05:58 PM   #8731
nexxus's Avatar
Trader Rating: 302 (100%+)
Got impatient and decided to give this thing a go in 21.5 blinky with whatever setup was on it from the guy I bought it from, besides an issue with the centre shaft coming loose (fixed by putting it in the other way) the car felt good. Laptimes were down as I was running a Tekin RS Gen 2 ESC with my R1 Wurks motor, and the experience I have had previously with Tekin Blinky ESC (gen 1 RS Pro) hasn't changed, still slower than other brands. Lap times were 20.2-20.7 with the Tekin, after racing put my Hobbywing V3.1 in and was in the 19.4-19.8 range.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 08-24-2015, 10:13 AM   #8732
Default Part number differences
What is the difference between part number C04 and C04M?
Is C04 still available or is C04M the replacement for C04?
Thanks..
Brian
Aquaracer is offline   Reply With Quote
Old 08-24-2015, 10:30 AM   #8733
geeunit1014's Avatar
C04M is a slightly different shape to clear the sway bar mounts on the newer chassis which is narrower. You can run them on older cars no problem, but are required for evo2/L2 cars, or cars upgraded with ALS2/L2 chassis
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 08-24-2015, 10:38 AM   #8734
hanulec's Avatar
Trader Rating: 27 (100%+)
C04 is EOL
C04m is the carbon replacement.
C04al is an alloy alternative.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-24-2015, 10:39 AM   #8735
Thank you Mike for the clarification. I am running an A700L. What a great car this is!!!!! You can just keep pushing, pushing and pushing the chassis and it takes it and asks for more.. It truly lives up to its name Awesomatix.
Old 08-24-2015, 10:40 AM   #8736
Magnet Top's Avatar
Thumbs up RFG
Running Mod I ran the new RFG parts on low grip asphalt yesterday.
A very significant increase in rear on power stability and yet maintained steering.
Jake
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 08-24-2015, 10:43 AM   #8737
WesRaven's Avatar
Originally Posted by hana166 View Post
The advice from fellow posters is all correct, but you are not completely wrong. You lose grip with a stiffer car, therefore response and initial steering is less but when fully transitioned in the middle of the corner there will be less (rear) grip - therefore more cornerspeed.
A softer (baseplate) car will turn harder initially but settle on the rear when fully transitioned so you lose steering in the middle of the corner. Feels planted but might actually be slow. Its more obvious in long fast sweepers but still noticeable in slow corners where the car settles or grips up more at the apex. Can be useful in modified as it helps getting on the power.
Also if you are using the inner position on the steering arm there is more ackermann and this, while making the car feel great, slows the corner speed by taking away midcorner steering because the outer wheel has less lock and also there is a bigger scrub angle between the two front wheels, and this robs speed. Often you can't even see it on the track, only in the laptime.
Thank you very much, this makes a lot of sense and really helps it all click together.
Fortunately I was able to hit the track armed with a lap timer (which I don't usually have during practice) and was really able to see the subtle differences. Ultimately I found using the outer holes on the steering arms helped the most. I think I'm starting to grasp this whole setup thing; I tried this before I read your post because it seemed like the outside wheel having more lock would help. So it's nice to have confirmation on this both from you and lap times. I know others have recommended this setting, I just wasn't sure why until now.
I was able to TQ with my car on Sunday, so all of the changes were definitely in the right direction. Unfortunately I didn't finish the main, but that was due to my own unfortunate driving decisions, definitely wasn't the car. I can't thank you guys enough for the level of support I get on this thread.
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 08-25-2015, 09:07 AM   #8738
waltss2k's Avatar
Question, in order to change the rear bearings that are on the diff does that mean I will have to charge the diff fluid as it looks in the manual the outdrives are held in with O rings ? Plus the outdrives seem to be hard to get out.
waltss2k is offline   Reply With Quote
Old 08-25-2015, 10:02 AM   #8739
RC Professor's Avatar
To change the diff bearings, all you have to do is remove the outdrives. The O ring on the outdrive only serves to hold a small pin in place which holds the outdrive on. Just remove the O ring, then the pin, then outdrive, and the bearing will slide off. No need to open the diff at all to change bearings.
Edit - I assume you are referring to the 2 bearings on the outside of the diff that the diff rides on, and not the 2 bearings inside the diff. Obviously, those you would need to disassemble the whole diff to get to.
RC Professor is offline   Reply With Quote
Old 08-25-2015, 01:37 PM   #8740
waltss2k's Avatar
Yes the bearings on the outside of the diff. Thanks for your help.
Old 08-26-2015, 02:14 AM   #8741
John Doucakis's Avatar
Hi guys
I have a kit for sale.
See details here or click on the photo:
JD & RACING Blog - Kit for sale
John Doucakis is offline   Reply With Quote
Old 08-26-2015, 05:37 AM   #8742
kgombe's Avatar
nice ride for sure.. ^^^^
Kijana Crichton
kgombe is offline   Reply With Quote
Old 08-26-2015, 12:56 PM   #8743
waltss2k's Avatar
Got it. Had to go to the back of the manual to find it. Bought 2 used chassis and both are a little different. Thanks again
Old 08-30-2015, 08:26 AM   #8744
Tof
Hello,
No pictures of the Viljami car to the euro?
Tof is offline   Reply With Quote
Old 08-30-2015, 10:57 AM   #8745
hanulec's Avatar
Originally Posted by Tof View Post
Hello,
He ran an Evo2 / alloy chassis / production RFG.
No top deck to help increase overall chassis grip
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 09:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
