Like Tree13Likes
Old 07-26-2015, 06:05 PM   #8581
AwesomatixUSA's Avatar
Originally Posted by howardcano View Post
]Do you have an ETA for suspension arms in the online store?
Originally Posted by wstuart View Post
Any idea when the d2.1 s will be back in stock in the US. I want to update my evo1 a little
both should be in less than 2 weeks..
Official North American Distributor of Awesomatix, Wild Turbo Fan & Mon-Tech Racing
shop.awesomatixusa.com / www.awesomatixusa.com
#winning - 6x ROAR Nationals, 2x Reedy Race, 2x Snowbirds, 1x IIC, 5x Halloween Classic, 4x US Indoor Champs, 2x Mile High Champs
AwesomatixUSA is offline   Reply With Quote
Old 07-27-2015, 01:39 AM   #8582
Trader Rating: 32 (100%+)
Quick question.
What brand of alu servo horn is best fit for A700 EvoII???
hobbs is offline   Reply With Quote
Old 07-27-2015, 04:39 PM   #8583
jdawg81's Avatar
Originally Posted by hobbs View Post
Quick question.
I use an Xray servo saver on my A700L but I am sure it should also work on the Evo.
Edit: I just noticed u wanted an aluminum servo horn. At one point I used a Tamiya servo horn temporarily after the plastic horn got stripped. I am sure any aluminum horn will work as long as its long enough to give the proper turning radius.
jdawg81 is offline   Reply With Quote
Old 07-27-2015, 05:56 PM   #8584
WesRaven's Avatar
If anyone finds one, I'd like to know as well. I have only tried the Yokomo and ProTek, and that did not work at all. I'm currently sticking with the stock plastic unit since it has absolute perfect dimensions to get over the drive shaft while staying under the AM46. The distance from the servo is perfect as well keeping your steering link nice and straight to the rack. Unless you find one that has the exact dimensions as the stock unit, I probably wouldn't recommend it.
Originally Posted by hanulec View Post
Ah- yes/no. I found some new orings and I will be rebuilding my 2.0 shocks after 1m this weekend... If they are better these new orings will be available for sale.
Any word on the new o-rings? I have one damper that insists on leaking, and I've run out of things to try.
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 07-27-2015, 06:21 PM   #8585
hanulec's Avatar
Trader Rating: 27 (100%+)
Wes- the alt. Orings work well in the d2.0. I'll work up a pn#
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-28-2015, 01:50 AM   #8586
Schwarta's Avatar
I'm going to upgrade my shocks to 2.1's. If I purchase the parts separately, do they come as single pieces or in a set? Mainly the AT41-1 and AT40-1? As if they're single, it would be cheaper to buy a whole damper.
Thanks,
Iain
Schwarta is offline   Reply With Quote
Old 07-28-2015, 03:44 AM   #8587
hanulec's Avatar
Single pieces
Don't forget the or155 too
Old 07-29-2015, 07:53 PM   #8588
jdawg81's Avatar
Default Question about adjusting downstop
I've been trying to figure this out for a while now but I'm still a bit confused. When I read a setup sheet and it says 2mm over ride height, how exactly do I measure this? Do I put the car down on a flat surface and adjust the screw until the distance from the end of the suspension arm and the surface is 2mm when measured with a ruler or ride height gauge?
I tried doing this on my car using the above method but I get a lot of droop. Is this normal or am I doing something wrong?
Old 07-29-2015, 07:59 PM   #8589
geeunit1014's Avatar
Droop over ride height. Set the car to the specified ride height. Lift chassis until arms hit droop screws (tires ahould stay on the board). Measure chassis height again. The difference is the droop over ride height.
I prefer this way since it eliminates the influence of all other chassis settings on the droop reading
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-29-2015, 09:13 PM   #8590
jdawg81's Avatar
Thanks, that really helped a lot to clear up the confusion I had to measuring droop over height.
Old 08-01-2015, 08:33 AM   #8591
waltss2k's Avatar
I recently bought a used 700L from a fellow a fellow racer. I went through the car and had to replace a few parts nothing major and got to practice and race with it for the first time last night. Pretty amazing car, I now know what the hype is all about. I kept making changes and learning more about the car all night from fellow Awesomatix owners. Can't wait for more.
waltss2k is offline   Reply With Quote
Old 08-03-2015, 09:08 AM   #8592
JayL's Avatar
Hanulec: The Jackson RC setups work well as a baseline on my track in 17.5, Looking for evo2c setup from you there, I assume you don't have one?
Thank you
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 08-03-2015, 09:47 AM   #8593
hanulec's Avatar
Evo2 vs evo2c setups will be close. I just scraped around my alloy chassis this summer.
I'd really make sure to have a top deck ... And then work on different spline (am33/am30) adjustments for flex.
Old 08-03-2015, 10:12 PM   #8594
WesRaven's Avatar
Quick question.
Finally found one that works nearly perfectly from Integy. Their 18mm machined alloy horn has the perfect amount of throw and clears everything using the existing shims and ball cups I used with the stock plastic horn. They have other colors too, just make sure you get the same 18mm model.
Important note: The only thing I had to do was shim it out 1mm away from the servo to keep the steering rod perfectly straight and to keep the horn from binding on the housing of the Awesomatix servo. A SH10 works if you file down the diameter a bit to fit inside the splined collar of the horn.
Old 08-03-2015, 10:24 PM   #8595
Schwarta's Avatar
Thanks Wes, I bought that one with a plan to use it but it bound against the case on my 9550. Might try the shim inside filed down.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
