Like Tree22Likes
Old 05-06-2015, 10:06 PM   #8431
hanulec's Avatar
Trader Rating: 27 (100%+)
Upgrade to ffg.. Yes
Chassis - alloy vs carbon
Chassis brace/top deck designs
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-07-2015, 02:53 AM   #8432
Default Springs
I have been looking at some of the recent set-up sheets from Europe and noticed in the remarks that the springs are bent 100% and 110%. Anybody care to elaborate on this modification and the benefits?
Thank you,
Patrick
XCELL is offline   Reply With Quote
Old 05-07-2015, 07:08 AM   #8433
Thank you,
Patrick
This is not % .
This is angle of bending.
Our standard springs have ~90 deg bending but you can change this with pliers.
The standard 90 deg kit's springs are the noticeable progressive in our suspension.
~100 deg bent springs provide almost linear characteristics.
Picture of 100 deg bent spring:
Oleg Babich is offline   Reply With Quote
Old 05-11-2015, 12:16 PM   #8434
WesRaven's Avatar
Default tie-rod end recommendations
I'm looking for some tie-rod end recommendations from anyone that has upgraded theirs or tried anything different. I've yet to really break anything on my Evo 2, but when the inevitable wreck does happen the only issue I run into is the camber links popping off. I've had both the inside and outside come off more often than I feel comfortable with considering how infrequently I hit the boards.
It's a little frustrating watching novice and sportsman bash their cars all day with seemingly no consequence, and the first time I touch a wall in a close race I'm out. (Can you tell what happened to me over the weekend? )
I want to replace all of my ball joints before the Reedy race, so before I just buy stock replacement parts figured I'd check in with you more experienced Awesomatix people. Any input will be appreciated.
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 05-11-2015, 12:52 PM   #8435
I've experimented with 4 different ball ends. Stock, Kyosho Grey, Top and Xray. Xray is by far the best option as far as holding strength and longevity. Very little slop after almost two years of racing. Expect to spend over $100 if you go the xray route (you have to replace the ball ends and balls).
malkiy is offline   Reply With Quote
Old 05-11-2015, 01:05 PM   #8436
Magnet Top's Avatar
In the past I've used the associated ti balls and cups. Very little slop, and take some hard hits without coming off. That being said, there aren't many things to hit at the Tamiya / Reedy race track....just rolling over berms...
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 05-11-2015, 01:34 PM   #8437
hanulec's Avatar
I only ran top "inner" ball ends until the new p13-4 came out. I love these ball ends now! All of my Evo2 cars only run with ST24/M/L and p13-4
For the p01/p02 fly apart -- zip tie or CA will fix things.
Old 05-11-2015, 01:36 PM   #8438
WesRaven's Avatar
That's very comforting. I think I'm just dealing with some PTSD from our club race yesterday; extremely fast with dots EVERYwhere... so, if someone bumped you into a dot going down one of the many straights, your car went flying end over end rather than just sliding against a wall.
Thanks for the recommendations and personal experience with the inner ends guys; that gives me some things to try with less experimentation.
Has anyone found anything that works better for the outer cups? or tried these? http://shop.awesomatixusa.com/awesom.../a700-fcb.html
edit:
Thanks. I completely forgot to CA mine together; I will give this a try.
Old 05-11-2015, 01:42 PM   #8439
Magnet Top's Avatar
I have to agree... P13-4 and ST24/M/L are great and every bit as good as the Xray cups and ball studs.
Old 05-11-2015, 11:14 PM   #8440
WesRaven's Avatar
After looking at the more detailed diagram of the FCB, I see that it uses a P13-4:
I have had my outer ends pop off far more often than the inner, and if the P13-4 (which I'm currently using) is as good as the Xray, I think I'm going to give the FCB a try. It's an expensive fix front and back, but if it can keep me in a race it will be worth every penny.
Old 05-12-2015, 09:09 AM   #8441
Magnet Top's Avatar
Unfortunately it looks like they are out of stock at Awesomatix USA. If I order tonight (Monday) what do you think the odds are of me getting them before the Reedy race?
Follow Hanulecs advice above.. CA P01 and P02 together. It's the best and most cost effective solution. Maybe start with a new set so they are tight and avoid removing them too many times. Although initially I have had to pop the unit ( p01+p02 ) off and on ST03 a few times to free it up slightly so the suspension travels freely.
Old 05-12-2015, 09:23 AM   #8442
dizzy1's Avatar
Trader Rating: 24 (100%+)
Hanulec,
I saw your signed up for Reedy, will you be bringing parts to sell like IIC and other races? Need some ST24 that just came in stock but was hoping your bringing some spares like in the past.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 05-12-2015, 10:09 AM   #8443
WesRaven's Avatar
Unfortunately I already ordered the FCB sets in my panic last night, but fortunately I do have some new P01/2 that I will try again per your recommendation.
Out of curiosity, aside from the obvious cost difference, what are the downsides of the FCB? I've asked around about these, but having a hard time finding any feedback at all. Seems like they are probably heavier with their extra complexity. Has anyone experience any durability issues?
Old 05-12-2015, 10:20 AM   #8444
hanulec's Avatar
Originally Posted by dizzy1 View Post
Hanulec,
A parts box will be with the team drivers, but if you need something I wouldn't only depend upon that. I unfortunately won't be able to attend.... I haven't even run outdoors yet
Old 05-18-2015, 03:11 PM   #8445
jdawg81's Avatar
I have an A700L that I was thinking of upgrading with parts from the A700L2. The biggest difference I can see with the A700L2 is that it has a new C01L2 chassis, GD2-S gear diff, and MM2 motor mount. Is it a straight forward swapping of parts to mount the new parts to my car? Or are there other pieces I'm missing that I'll need to fit the new parts?
jdawg81 is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 09:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
