Like Tree25Likes
Old 05-04-2015, 06:41 PM   #8416
Trader Rating: 29 (100%+)
What, if any, advantage is there to running the A700-MG gears in the GD2 diff? Is this necessary if you want to run only 2 satellite gears? I have the stock gears in the new evo2 I bought and metal gears in an older 700L I bought. The 700L diff with only 2 satellite gears seems substantially smoother.
I'm running 17.5, are the metal gears more suited for modified?
branover is offline   Reply With Quote
Old 05-04-2015, 07:05 PM   #8417
hanulec's Avatar
Trader Rating: 27 (100%+)
Metal gears where popular/maintenance free with gd1. Two gears + 5k was very popular...
When gd2 came out people tried many options. Metal shephard gears allowed for more forward bite. The new amtx gears are pretty std in our setups now...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-05-2015, 04:31 AM   #8418
Default Best motor for A700EVO
Anyone can tell which Turn of motor is the best fit for running on the A700EVO?
loman15 is offline   Reply With Quote
Old 05-06-2015, 11:19 AM   #8419
bornox's Avatar
Trader Rating: 26 (100%+)
Originally Posted by WesRaven View Post
Not sure if I'm doing something special, or if I simply haven't put enough runs on them. I've put 3 solid race days (and 3 accompanying practice days) on a Robinson spur with Trinity pinions without any noticeable signs of wear.
That being said, I'm always looking for something better than what I currently like. Is this a good place to buy the Xenon gears? http://xenon.ocnk.net
ebay. xenon ultimate machine cut spur.
bornox is online now   Reply With Quote
Old 05-06-2015, 12:30 PM   #8420
b20btec's Avatar
AM01-1, can that be used with C21-2 on the EVO II?
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is online now   Reply With Quote
Old 05-06-2015, 01:16 PM   #8421
geeunit1014's Avatar
If you are using it in the front to turn the car back into an L, then no, you will need an L topdeck as well
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 05-06-2015, 01:47 PM   #8422
b20btec's Avatar
On one of my EVO II i'm using a AM18-01 up front with a C02-2, was looking to setup up another EVOII into an L. Thanks for the clarification.
The new manual for the A700L2 is published with using C21-2 upper deck,
Soap
Old 05-06-2015, 04:38 PM   #8423
I see in most pictures that people don't have the diff covers on so I'm assuming that is the way you run them? I have only run with the covers on so far. Do people tend to leave just the bottom cover on? Can't imagine there's any advantage other than it looks cooler without them?
Old 05-06-2015, 04:48 PM   #8424
Trader Rating: 55 (100%+)
Originally Posted by branover View Post
I see in most pictures that people don't have the diff covers on so I'm assuming that is the way you run them? I have only run with the covers on so far. Do people tend to leave just the bottom cover on? Can't imagine there's any advantage other than it looks cooler without the them?
I use them outdoors. For carpet racing I take them off.
Jamison R is offline   Reply With Quote
Old 05-06-2015, 04:56 PM   #8425
Thanks. Top and bottom? Just wasn't sure if the bottom one would stay in place without the top? Thanks again
Old 05-06-2015, 06:04 PM   #8426
WesRaven's Avatar
I run with my diff covers on (even though I'd really like to run with them off, the gears look so beautiful) mainly because they help the FFG move properly and return to the correct position. If I didn't have the FFG I would probably considering running without them.
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 05-06-2015, 06:46 PM   #8427
S.Stew's Avatar
Correct me if I'm wrong, but I also think with the first version (or early versions) of the FFG you have to run the covers in order to limit the movement. Otherwise the axles will fall out of the out-drives.
S.Stew is offline   Reply With Quote
Old 05-06-2015, 09:57 PM   #8428
can you give me a quick hint on what's the differences between an A700L and A700 EVO??
Ted Su(TW) is offline   Reply With Quote
Old 05-06-2015, 10:05 PM   #8429
hanulec's Avatar
http://www.awesomatixusa.com/p/kits.html
Old 05-06-2015, 10:11 PM   #8430
Ive read that page, but am still not cleared.
The A700L is without the FFG? But it can be upgraded with FFG?
Apart from that, is there other differences?
Thank you.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
