Like Tree22Likes
Old 04-29-2015, 07:33 AM   #8386
Originally Posted by S.Stew View Post
I have been using the Easy-Lube. I'm not sure how the clean lube would work, but It's easy enough to clean and re-apply the Easy-Lube as is.
Thanks, I appreciate the feedback on that. The local bike shop only had the Clean-Lube in stock.
Aquaracer is offline   Reply With Quote
Old 04-29-2015, 08:11 AM   #8387
S.Stew's Avatar
Wal-mart should carry it. That's where I got mine!
- Steven Stewart -
S.Stew is offline   Reply With Quote
Old 04-29-2015, 08:55 AM   #8388
I will check there.. Thanks again..
Old 04-29-2015, 09:29 AM   #8389
JayL's Avatar
Bicycle wax chain lube for the gears
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 04-29-2015, 04:40 PM   #8390
Trader Rating: 29 (100%+)
I got my evo2 out for some more practice today. Only the second time out with it and I can't express how happy I am with the car. As I start to get familiar with it everything is starting to make sense. I've got a ways to go though for sure.
I started with mike gee's setup and have adjusted slightly from there but it was pretty solid on a medium bite track that's about 2/3 the size of Horsham.
I finally received the used 700l I bought on rc tech but haven't had a chance to get electronics in yet. What's the consensus on the differences in the two cars? Am I going to notice/ be disappointed in the lack of the FFG? The 700l I got has the new aluminum chassis and new mm2 motor mount.
branover is offline   Reply With Quote
Old 04-29-2015, 05:20 PM   #8391
WesRaven's Avatar
What class are you planning on running? From what I was told when deciding between the Evo and L car is the FFG's advantage is more apparent when running a more powerful mod motor. People (like me) running 17.5 or slower probably won't notice the difference.
Now, I ended up getting the Evo anyway, but that's just because I plan on running mod next season.
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 04-29-2015, 05:34 PM   #8392
For now I'm going to stick with 17.5 also. Seems that one of the tracks near me has been running 13.5 as well so I might use the Evo2 for that.
Old 04-29-2015, 05:47 PM   #8393
geeunit1014's Avatar
The L is a more aggresive driving car than the evo. It can be fast but it is definitely a more steer happy car.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 05-01-2015, 04:05 AM   #8394
hana166's Avatar
Thought I'd share this for fun. Thought I'd clean up and rebuild it but ended up going much further than planned.. milled and drilled AM30-5 to accept the new tower.
Awesomatix EP Touring Car (A700 Shaft Drive)-20150430_095431%7E02.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-20150430_121609%7E01.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-20150430_121632%7E01.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-20150430_121645%7E01.jpg
hana166 is offline   Reply With Quote
Old 05-01-2015, 04:15 AM   #8395
hanulec's Avatar
Trader Rating: 27 (100%+)
did u polish the metal pieces too? looks like a mirror finish...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-01-2015, 04:23 AM   #8396
hanulec's Avatar
best of luck to the team out at ETS this weekend!
Old 05-01-2015, 04:58 AM   #8397
hanulec's Avatar
sorry for somewhat dated news -- congrats to the Awesomatix USA team at 2015 Mile High Champs -- http://www.awesomatixusa.com/2015/05...2015-mile.html
Old 05-01-2015, 10:25 AM   #8398
WesRaven's Avatar
Wow, it looks incredible! Well done! I really want to steal your idea and polish my car now. What method did you use to get those impressive results?
Congrats Awesomatix USA team! So proud of you guys!
Now how can I get one of those groovy shirts so I can represent at Reedy?
Old 05-01-2015, 11:01 AM   #8399
hana166's Avatar
I de-anodised in a plastic tub with a light solution of caustic soda then some sanding with 1200 grit paper wet and a block where necessary to remove milling marks then a 4 inch buffing wheel. I did the smaller parts with dremel polishing wheel. The really tight areas I used a cotton bud dipped in Autosol in a dremel. Reminds me a bit of the SMP Slide Chrome now.
On a completely different subject I think I might have found a solution for leaks in the D2 damper. I don't know if silicone is the best material perhaps someone could advise on whether nitrile would be better but so far the results have been very encouraging. Although quoted at the correct size they are ever, ever so slightly bigger than the originals. I ran four packs today and the seal has held really well. For the price its certainly worth a try. Less than a week to England.
http://www.oringsandmore.com/silicon...ce-for-25-pcs/
Old 05-01-2015, 11:15 AM   #8400
For the dampers i have used the dow 55 grease someone else suggested. It has worked great, going on 5 weeks on one set and they still feel fresh
Mike Gee
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 09:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
