Like Tree25Likes
Old 04-27-2015, 06:38 PM   #8371
Trader Rating: 29 (100%+)
Originally Posted by WesRaven View Post
Not sure if I'm doing something special, or if I simply haven't put enough runs on them. I've put 3 solid race days (and 3 accompanying practice days) on a Robinson spur with Trinity pinions without any noticeable signs of wear.
That being said, I'm always looking for something better than what I currently like. Is this a good place to buy the Xenon gears? http://xenon.ocnk.net
I really like the xenon gears for my pan cars. They usually have them at both TQ rc and Reflex Racing
branover is offline   Reply With Quote
Old 04-27-2015, 07:04 PM   #8372
hanulec's Avatar
Trader Rating: 27 (100%+)
AwesomatixUSA will be adding xenon gears back to the store shortly
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-27-2015, 07:06 PM   #8373
b20btec's Avatar
I must of got a bad batch, I don't feel like getting burned again.
http://www.reflexracing.net/Xenon-VS...2T_p_2331.html
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 04-27-2015, 07:11 PM   #8374
Glad to hear it. I prefer one stop shopping.
Old 04-27-2015, 07:13 PM   #8375
WesRaven's Avatar
Thanks guys, going to try them out. I need something super small for my 1/12 pan car as well, and the Robinson definitely doesn't work well in that department. Sharing the same spurs between my cars sure would be nice.
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 04-27-2015, 07:19 PM   #8376
b20btec's Avatar
Panaracer/xenon is a no brainer. I went with a Robinson to get a odd size but besides that it doesn't come close to the xenon vss. If you're not running the pinions from pananracer I suggest you give it a go, perfect mesh.
Soap
Old 04-27-2015, 11:43 PM   #8377
rdracer's Avatar
Does anyone know how to get rid of the slop with the sto5L(shock rod) i'm not sure if anything is bent to create this but it didnt exist when I built the car and and for week following, but now all 4 corners of the car suspension have it. Some people say its from have too much droop, but I am running 5mm up from chassis on set up board and it wasnt in the car before. Please help me, I really want to remove the slop..
It happens with the tires off and you lift the arm upward it feels like slop before you feel the shock and spring give tension. Hope this makes sense
rdracer is offline   Reply With Quote
Old 04-28-2015, 01:41 AM   #8378
Trader Rating: 55 (100%+)
Droop setting.
Jamison R is offline   Reply With Quote
Old 04-28-2015, 03:54 AM   #8379
hanulec's Avatar
Could be--
Not enough spring tension (low ride height)
Or
Simply loosen the damper in the am17 holder and then compress the suspension. Does it then feel tight? If so tighten the screw back.
Old 04-28-2015, 07:51 AM   #8380
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Originally Posted by DesertRat View Post
Anybody know when the Evo 2's will be back in stock at Awesomatix USA? I think I just might have to invest in one.
A700 Evo II with Carbon chassis
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-28-2015, 10:50 AM   #8381
b20btec's Avatar
Hanulec,
Do you have any AM01-1 in stock?
Soap
Old 04-28-2015, 03:44 PM   #8382
hanulec's Avatar
Arriving before Friday
Old 04-28-2015, 04:57 PM   #8383
b20btec's Avatar
Sweet thanks.
Soap
Old 04-28-2015, 09:39 PM   #8384
What is everyone using to lubricate the metal to metal gears on the spool and diff?? I understand that they are steel to steel but I still think some type of lubricant is needed. Earlier in the thread someone mentioned dry bicycle chain lubricant. Is this what they were talking about??
http://www.whitelightningco.com/products/
The clean ride of products is what I was referring to. It sounds like it would work from the reading I have done. Interested to hear what others are using.
Thanks!!
Aquaracer is offline   Reply With Quote
Old 04-29-2015, 07:37 AM   #8385
S.Stew's Avatar
Thanks!!
I have been using the Easy-Lube. I'm not sure how the clean lube would work, but It's easy enough to clean and re-apply the Easy-Lube as is.
- Steven Stewart -
S.Stew is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
