Like Tree13Likes
Old 04-17-2015, 06:15 AM   #8326
Trader Rating: 29 (100%+)
The new manual came out at the perfect time for me. I started the build yesterday and made nice progress. So far it's been a very enjoyable and rewarding build, it's just a cool car.
Thanks to Jerry P for getting me through some Diff troubles, easy fix. Unfortunately I think I'm going to rebuild it tonight anyway, the manual calls for 7000wt oil and after seeing a couple setup sheets it seems people are running 2000-4000 range.
branover is offline   Reply With Quote
Old 04-17-2015, 07:18 AM   #8327
hanulec's Avatar
Trader Rating: 27 (100%+)
the new manual does make everything else easier. still happy we got cars before the manual came out. now everything is just a bit more civilized, but still fun.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-17-2015, 08:09 AM   #8328
b20btec's Avatar
Has anyone tried running the SD2 spur damper without a heavier shaft AT04-2? The larger shaft is giving me some clearance issues but I would like to keep the damper with the factory standard shaft AT04.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 04-17-2015, 08:14 AM   #8329
hanulec's Avatar
SD2 and AT04-2 are meant to go together. the thought is the AT04-2 being stiff will act like a stiff belt/high tension.
I've been starting to run the cars w/o the AM49/AM49-3 brace (fixes clearance issues, and drops a little weight). My cars always have a top deck...
Old 04-17-2015, 09:06 AM   #8330
kartermdb's Avatar
Trader Rating: 15 (100%+)
I have not been running the center support for a while. All my cars run topdecks also.
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 04-17-2015, 12:52 PM   #8331
chiefj48's Avatar
Doesn't the drive shaft start to wip without the center brace for the bearings??
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, Serpent USA, Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is online now   Reply With Quote
Old 04-17-2015, 02:59 PM   #8332
geeunit1014's Avatar
They are talking about not using the ffg support, not the driveshaft support. Although you can run without the driveshaft support for spec classes like 17.5
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 04-17-2015, 05:14 PM   #8333
koopal's Avatar
Evo II or Evo IIC for outdoor?
my A700L need a big brother...lol
koopal is offline   Reply With Quote
Old 04-18-2015, 12:56 AM   #8334
hanulec's Avatar
if using the thin (AT04) drive shaft -- you can get away without the support in 17.5 or slower.
the new AT04-2 thick shaft doesn't need the support.
Old 04-18-2015, 12:57 AM   #8335
hanulec's Avatar
Hi Ramil-
You've always asked for an alloy chassis car. The A700 Evo II is that car.
If you want a carbon chassis car -- get the A700 Evo IIC.
I'm going to start with an alloy chassis car in stock at Jackson -- we will see how it goes.
Old 04-18-2015, 07:25 AM   #8336
koopal's Avatar
Originally Posted by hanulec View Post
Hi Ramil-
Thanx Mike, I'm still clueless on alloy chassis specially for outdoor use.
Cant wait to know which chassis ( alloy or carbon ) is best suited
for Mod TC on asphalt. See you at Jackson soon.
Old 04-18-2015, 08:19 AM   #8337
hanulec's Avatar
we ran the A700-C01AL-S chassis in mod tc at the end of the summer. it was so good. the A700 Evo 2 comes with the A700-C01AL-S2 --- which is very similar, just skinnier, than last year's alloy chassis.
we had the A700-AM30-5 brace installed (short than what Evo 2 has -- and what is included in Evo 2C).
i believe Mike Gee is running at John's Mobile today -- one of each chassis. hopefully he can report back.
Old 04-18-2015, 08:33 AM   #8338
Thanks to Arno for editable setup sheet for Evo II/IIC!
Suspension rate for S springs was corrected already in this setup sheet version.
http://www.petitrc.com/reglages/awes...SetupSheet.pdf
Oleg Babich is offline   Reply With Quote
Old 04-18-2015, 12:14 PM   #8339
Got my evo2 almost done. Just have to clean up some wiring and paint a body. Need some wheel nuts as well, first car I've ever built that doesn't come with them. Build was fantastic, every piece is machined perfectly. Only minor complaint would be a lack of some labeling on the hardware, namely the ball studs. With a little help I realized there were 4.75 and 4.95 studs, only real mistake I made. Thank you to Hanulec and Jerry P for the help throughout the process.
Old 04-18-2015, 01:25 PM   #8340
!Mad Max!'s Avatar
Send a message via ICQ to !Mad Max! Send a message via Skype™ to !Mad Max!
Hey Guys,
last week Team Awesomatix Europe attend at the ETS Rnd.3 in Riccione Italy.
We tested and learned a lot with the new Car on Asphalt during the weekend.
Finaly we found a very good setup which I was able to finish 6th overall in ProStock class.
Viljami had bad luck this weekend in Modified but we are looking forward to ETS Rnd.4 in Mattsee Austria in 2 weeks.
Here you can find my final setup:
http://awesomatix.info/wp-content/up...-ETS-Italy.pdf
Best Regards Max Mächler
Team Manager Awesomatix Europe
Sponsored by: Awesomatix / LRP / FUTABA / LEESPEED / PROTOform / Wild Turbo Fan / MMP / APaint / MPE Stickers
!Mad Max! is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
