Like Tree13Likes
Old 03-18-2015, 10:24 AM   #8221
Moderator
Clegg's Avatar
Having just bent the front of an aluminum chassis (due to losing the bushings on a front dog bone going into a chicane causing the car to pull hard under power square into a board), I was wondering... is there any thoughts on making a brace like Xray has for the top of the bumper?
Where the Xray T4's have a brace that goes to the top of the bulkheads from the bumper to give top and bottom bracing for heavy impacts, reducing the likelihood of delaminating a carbon chassis or bending an aluminum one.
Given that chassis get rev'd for the Awesomatix at a rate that means you potentially cant replace the chassis you just bent like-for-like (example - I am using the first version of the Evo Aluminum chassis the CO1AL, and they are like unicorns to find these days), anything that can be done to protect the front area would be nice.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 03-18-2015, 12:25 PM   #8222
The brace from a xray t4 works perfectly, just add 2mm of shims
Team Trinity/ReVtech - Awesomatix USA- Wild Turbo Fans-TQ wire-MRH Racing
sg1735 is offline   Reply With Quote
Old 03-18-2015, 12:29 PM   #8223
Moderator
Clegg's Avatar
Ohh good to know! Thanks
Old 03-18-2015, 06:08 PM   #8224
rdracer's Avatar
I am thinking about buying the evo2 kit, I have been running the evo 1 carbon chassis for a while. I run asphalt 99% of the time with the exception of IIC every year. Trying to figure out if I should get the aluninum or carbon fiber chassis?
rdracer is offline   Reply With Quote
Old 03-18-2015, 06:11 PM   #8225
hanulec's Avatar
Trader Rating: 27 (100%+)
i think the alloy chassis w/ less screws in the brace and no top deck will perform very similar to carbon chassis and top deck (at least it did last year, w/ the Evo kits)
the new carbon chassis is untested in the USA .. so its a good question. i'll be doing what i usually do -- take my prior "season" cars into the next season and tune around the handling while taking feedback in from the rest of the team...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-18-2015, 07:31 PM   #8226
Ask kyle at hobbytown gilbert
tbamsey is offline   Reply With Quote
Old 03-18-2015, 08:59 PM   #8227
BJR
Trader Rating: 16 (100%+)
Hi
What would cause my GD2 to leak from the out drives?
The diff that came with my kit is fine but I bought a back out diff and have had endless leaking problems with it. I'm not over filling the diff, I've replaced the Orings also tried using green slime on the Orings. Any help would be much appreciated.
Blen
BJR is offline   Reply With Quote
Old 03-18-2015, 09:08 PM   #8228
rdracer's Avatar
Thanks Hanulec
Looks like Ill try the alum chassis, never ran alum before, just wanted some input before I make the jump
Tbamsey
Kyle's been running the alum chassis so far and is super hooked up, but I'm pretty sure he hasn't run the new carbon chassis yes. I just haven't had any luck trying to track down any info on the new carbon chassis....
Thanks for the input!
Craig
Old 03-19-2015, 01:10 AM   #8229
hana166's Avatar
Originally Posted by BJR View Post
Hi
Blen
I fitted Kyosho Orange orings, I think they were P4 size. Can't quite remember. Not a drop has leaked out since though.
hana166 is offline   Reply With Quote
Old 03-19-2015, 01:35 AM   #8230
Blen
Please don't forget to screw the SS3X4-1 DIN915 set screws tighter.
I know the guys who forget to install these set screws into ST31 Output Axles.
Oleg Babich is online now   Reply With Quote
Old 03-19-2015, 02:49 AM   #8231
hana166's Avatar
If anyone wants to get rid of their old, used good condition D6 dampers, please PM me.
Old 03-19-2015, 05:08 AM   #8232
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
I have been playing with the carbon chassis for a couple weeks now. Top brace definatly made it feel better. Never tried the top brace on the alloy car.
So far I can say I like it. But I do not know that I can say it is better then the alloy. here is a qual from last night. http://youtu.be/ZuuhdWf8X-c. white nose blue tail.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 03-19-2015, 06:16 AM   #8233
b20btec's Avatar
Have you guys try using dow33 and dow55. I use it on all of my orings and it works perfect. I know this because thats all I ever used when I was avid paintballer and have since transferred the use to RC. I haven't had my evo running yet but during the build I went ahead and used dow55 on the diff and damper.
Dow33 was original designed for bearings but is widely used for orings, it does not swell orings.
Dow55 is designed for orings and does swell them slightly while softening them up.
Anyways thought I'll chime in, a small tube is inexpensive and worth the try.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 03-19-2015, 09:37 AM   #8234
Trader Rating: 55 (100%+)
Any idea of eta on CO1L2?
Jamison R is offline   Reply With Quote
Old 03-19-2015, 10:49 AM   #8235
geeunit1014's Avatar
b20btec, where do you find that stuff?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 Yesterday 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
