Like Tree25Likes
Old 03-04-2015, 05:22 PM   #8161
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by WesRaven View Post
I'd love to have something like this as well. Even when just considering the basic stuff, there's simply too much to remember (for me at least).
Fortunately for the most part suspension geometry doesn't really change, and the same concepts can be applied to all cars. I still reference my old TC3 tuning guide at the track and find it helpful to remind me of the fundamentals.
For more in-depth understanding I have been reading this site a lot and found it extremely helpful: http://users.telenet.be/elvo/
-Wes
those are good options. i've also been using the XXX Main book, and then the Setup Workbench app(s) from Martin Crisp. the theories are *mostly* right w/in the book/app -- but you'll always want to test the specific settings for yourself.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-05-2015, 10:35 AM   #8162
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
After a couple weeks of working on the cars we have found a nice baseline setup that feels good, is fast, and most of the drivers can get there head around. If it works for anyone that is great..
http://youtu.be/zOexqCdY3SA
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 03-05-2015, 11:27 AM   #8163
RC Professor's Avatar
I can't seem to read the downstop and comments sections as the text is small, but other than that, it looks good. Mind listing those? Thanks.
RC Professor is offline   Reply With Quote
Old 03-05-2015, 12:09 PM   #8164
b20btec's Avatar
I have a question in regards to setting the dampers, in your experience is this normal for the awesomatix to have more rate in the rear?
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 03-05-2015, 12:27 PM   #8165
ammdrew's Avatar
6 on hudy blocks measured at the end of the arm on the carbon flat bottom
Old 03-05-2015, 12:35 PM   #8166
ammdrew's Avatar
From what I have seen and from how the car is working I have to say yes that seems to be the case. I know on Gee, and Burt's setups from the birds they both tend to be similar. Not sure if the calculation is correct as the pdf does that automatically.
Old 03-05-2015, 12:45 PM   #8167
b20btec's Avatar
Ok, thanks for responding.
Soap
Old 03-05-2015, 12:54 PM   #8168
geeunit1014's Avatar
This looks suspiciously a lot like my snowbirds setup
Yes. Pretty much all touring cars are softer in the front than the rear. Some guys run a softer rear than the front, but I think you need a very particular driving style for that.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 03-05-2015, 01:08 PM   #8169
b20btec's Avatar
Man i'm all messed up. All of my TC setups with other brands I usually like more dampening up front. To be honest I've never tried it any other way, maybe that's why i'm slightly slower than everyone else. Never too old to learn I suppose.
Soap
Old 03-05-2015, 01:13 PM   #8170
JayL's Avatar
I understand there will be some gap, which is why I'm wondering what offset of wheel people are running to compensate. I'm probably going with 6mm all the way around, but curious what other people's experience is before I place the order. Thanks guys.
You probably never took into account the leverage difference, front and rear, shock mounting point on arm and angle. I bet if you measured your setups they would be softer in front, just thicker fluid and or spring
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 03-05-2015, 01:20 PM   #8171
b20btec's Avatar
I do, I generally aim for a stiffer front setup. This is good information because it really did never occur to me to go the other way.
Soap
Old 03-05-2015, 02:21 PM   #8172
ammdrew's Avatar
It should that was the best start point of the setups I could find. I needed a little more linear rear of the car for a base. And having some more camber gain and toe with less caster helped that a lot. I was not really any faster or slower just more neutral which makes for me a much better base setup to work from.
Having a base neutral setup was the hardest part I found about the coming to the Evo from other chassis. Unlike most others we don't have a book setup to start from. So from the outside looking in everybody is drastically in different directions. Hell we don't even really have a manual to build it from. lol
Old 03-05-2015, 02:40 PM   #8173
The thing to realize is that just because the shocks were the same front to rear on a typical car did not mean the damping and spring rates were the same, due to the cars geometry. The same oil and spring f/r on a typical car would have less spring and damping in the front. With our car being the same geometry f/r, the front requires a softer setup to make the same feeling. You would have to run significantly stiffer in the front than the rear on a typical car to even make the front stiffness close to the rear.
Mike Gee
Old 03-05-2015, 03:13 PM   #8174
hanulec's Avatar
+1
Old 03-05-2015, 03:21 PM   #8175
jamminjim's Avatar
So with all this setup talk, has anyone found a setup guide for this car? It would be a handy document to have at the track. If there isn't one maybe you should all create one as a sticky here. It would do all of us a lot of good.
Know racing, know life. No racing, no life.
jamminjim is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
