Like Tree13Likes
Old 02-26-2015, 02:46 PM   #8131
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by WesRaven View Post
I understand there will be some gap, which is why I'm wondering what offset of wheel people are running to compensate. I'm probably going with 6mm all the way around, but curious what other people's experience is before I place the order. Thanks guys.
+0 offset IMO and people that are faster then me in USGT, do not run anything different. You could do is add some wheel spacers shims and I don't think you can go more then a couple MM this way. I don't think there is any 6mm offset rims in 24mm and I would NOT recommend 26mm rims with the 24mm tires. The tires do not round out on 26mm rims. I only know of Tamiya rims with + offset and maybe 4mm tops in 24mm rims.
Last edited by Travis S; 02-26-2015 at 02:50 PM. Reason: Thought that was hexes not offset so editing post.
Travis S is offline   Reply With Quote
Old 02-26-2015, 03:06 PM   #8132
WesRaven's Avatar
Fortunately my local club isn't too strict and allow us to run any 26mm wheel and tire as long as they are spoked.
Do you think these will fit the Evo2?
www rcplanet com/HPI_Wheel_Offset_p/hpi3845.htm (Sorry, can't properly post links yet, not enough posts)
If not, what brand of wheels are people running on these Awesomatix cars?
I already have a bunch of 0 offset wheels. Mainly wanted at least one set that will look good, and was a little curious about the handling differences (although, as you have pointed out, it may hinder me).
WesRaven is offline   Reply With Quote
Old 02-26-2015, 03:17 PM   #8133
Travis S's Avatar
They should fit fine. Not sure how good they will work though vs the spec tires that we are running USGT, but they won't make the car un-drivable or anything.
Most people run these: (all but the dish type)
http://www.teamgravityrc.com/store1/...=0&sort=normal
Old 02-26-2015, 03:55 PM   #8134
JayL's Avatar
offset wheels are for looks, they hurt handling. Most guys run 200mm with zero offset to be fast
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 02-26-2015, 03:59 PM   #8135
DS Motorsport's Avatar
Anyone running a 200mm body on their A700? I'm going to be running my Evo 2 in USGT with a HPI Ford GT body. HPI's website says to use 3mm wheels, but everywhere else online says 6mm which seems to make more sense mathematically.
Exactly how wide is the Evo 2? Unfortunately I don't have my kit quite yet to measure myself, so was hoping someone has experience getting the right wheel for a 200mm GT body.
I had new lower wishbones made to run the car at 200mm width with foam tires and a 200mm nitro touring body.
If there is interest I can have a small series made.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-26-2015, 04:22 PM   #8136
WesRaven's Avatar
Thanks for your input on the offset wheels guys. I wasn't really considering the chance of hindering performance that much (shows how much I know). Appreciate you guys chiming in.
Definitely sounds intriguing. Did you find this impact the handling of the car at all?
Old 02-27-2015, 11:23 AM   #8137
-jacob-'s Avatar
lots run a 200mm LFA and is the fastest body GT class we run here in Seattle.
I currently run a EVO 1 which ill be selling both of them next month to but 2 evo II's.
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 02-27-2015, 02:28 PM   #8138
Default 3MM OFFSET/ 6MM OFFSET
I have run the Protoform LFA, and the HPI McLaren (both 200mm) and used HPI 26mm wheels with 3mm offsets in the front and 6mm offsets in the rear. I still have two McLaren bodies that I plan to use and have two sets of tires and wheels already mounted. I do know at the VTA Nationals in Tenn. there were people running these bodies with the standard wheel and tire and the cars worked fine.
TWILL is offline   Reply With Quote
Old 02-27-2015, 03:05 PM   #8139
WesRaven's Avatar
Did you find the offset wheels negatively impact your handling? Did you happen to try the same car/body setup with 0 offset to see the difference?
I'm planning on trying a few different offsets on the track, just curious what others have already found.
Old 02-28-2015, 02:13 AM   #8140
Hi Wes,
To answer your prior question, the evo2 is 185mm hub to hub, front and rear. To stance a 200mm body, it needs between 7-9mm +offset wheels. This is alot of scrub radius for the front wheels! It's only good for high grip scenarios to tame a nervous front end. Luckily, 25.5 and 21.5 are slow enough that you won't notice a huge difference.
If you're open to a suggestion: consider a 190mm gt body and the Ride USGT spec tire with 0 offset wheels. The transition to 17.5 with be smoother.
vapourtrail is offline   Reply With Quote
Old 02-28-2015, 02:40 AM   #8141
Double post
Old 02-28-2015, 08:40 PM   #8142
WesRaven's Avatar
Originally Posted by vapourtrail View Post
Hi Wes,
Thank you very much for the information and suggestion, extremely helpful.
Old 03-02-2015, 05:47 AM   #8143
jamminjim's Avatar
Does anyone know of a tuning guide for the Evo? I am looking for something I can bring to the track. Thanks
Know racing, know life. No racing, no life.
jamminjim is offline   Reply With Quote
Old 03-02-2015, 06:02 AM   #8144
Default MM2
Has anybody tried the new motor mount on the soft raceberry chassis? I am curious to hear others opinions. I know I'd either have to dremel the chassis or not use all the flex options. I have the template so I wouldn't mind dremeling it out, but only if it would be beneficial..
Bgilli26 is offline   Reply With Quote
Old 03-03-2015, 09:01 AM   #8145
area52's Avatar
Send a message via MSN to area52 Send a message via Skype™ to area52
Fellow A700 EvoII drivers,
is there any change to get hold of the "default link length" values that work with the A700 EvoII/IIC kit? The settings mentioned in the standard A700 manual of course don't work anymore with the new ballcups etc. I do have a setup station but I cannot adjust the castor angles properly due to not having the dongles. Any chance someone can shoot me over the some basic setup?
The length of the exposed part of the turnbuckles would do best.
Muchas gracias!
Sebastian
www.area52.cc
area52 is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
