Like Tree13Likes
Old 02-19-2015, 06:51 PM   #8086
Magnet Top's Avatar
Earl, try moving the steering rack back. It's quick and easy too. It could make the car turn in a little faster but at the same time, depending on the toe, it can reduce the late oversteer. Also if traction is low / medium try running thicker gear diff oil... like 3000 to 5000 rear diff so the rear won't over rotate. That with less static camber as I mentioned before ( 1 degree in front and 1.5 in rear ) should help.
Also I agree with Hanulec too, remove some shims under the rear toe link to cause a little bit of toe-in during compression.
[edit] But I just remembered you were avoiding bump toe due to a bumpy track.
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 02-20-2015, 03:58 AM   #8087
BardSmith's Avatar
Trader Rating: 61 (98%+)
Does anyone have 2 pairs of AR-19s they want to sell? pm me pls
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 02-21-2015, 10:54 AM   #8088
b20btec's Avatar
Is the carbon upper deck applicable for the new evo 2? What track condition would it be useful for?
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 02-21-2015, 05:36 PM   #8089
geeunit1014's Avatar
Yes, same topdeck as evo 1. Its good for hi grip carpet.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-22-2015, 07:02 AM   #8090
b20btec's Avatar
Thank you. To confirm the part is A700-C21-2?
Soap
Old 02-22-2015, 09:11 AM   #8091
Yes, C21-2.
http://shop.awesomatix.com/index.php?productID=1040
Oleg Babich is online now   Reply With Quote
Old 02-22-2015, 03:30 PM   #8092
b20btec's Avatar
Originally Posted by Oleg Babich View Post
Thank you, I'll have my local track order it!
Soap
Old 02-22-2015, 05:56 PM   #8093
Default Awesome Weekend!
I just got home fron the VTA Carpet Nats in Fort Wayne. I put my Awesomatix cars in the A main in USGT and VTA. Probably had the best weekend of racing that I have had in a long time. Want to thank Mike and everyone else on this thread for the setup help that you have given me that allowed me to BE COMPETETIVE at a event like this. I really enjoyed the cars!
TWILL is offline   Reply With Quote
Old 02-23-2015, 06:34 AM   #8094
Any chance I could see your VTA setup sheet?
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 02-23-2015, 08:24 AM   #8095
Is there a PDF manual for the EVO II somewhere?
Ted Su(TW) is offline   Reply With Quote
Old 02-23-2015, 08:53 AM   #8096
Have a question regarding the steering rack. I see most use the inner steering link hole. What would be the handling characteristics if I tried the outer holes?
malkiy is offline   Reply With Quote
Old 02-23-2015, 10:28 AM   #8097
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Originally Posted by malkiy View Post
Have a question regarding the steering rack. I see most use the inner steering link hole. What would be the handling characteristics be if I tried the outer holes?
I thought of it the same thing
maybe just a clearance over the ball cup from lock to lock steering or make a shorter steering rod.
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 02-24-2015, 02:42 AM   #8098
BardSmith's Avatar
Check out this blog to help you in your build... Link
"Bard"
On-Road Only!
Old 02-24-2015, 10:00 AM   #8099
Default You have PM
I sent over the setup I used and the changes I made.
Old 02-24-2015, 11:58 AM   #8100
WesRaven's Avatar
Thumbs up First Awesomatix car
Hey guys, mainly just wanted to introduce myself, and thank everyone that has contributed to such a great thread. I just finished reading the whole thing, trying to fill my time while I wait for my new A700L2 to get shipped, and there's definitely a ton of great info here.
I'm getting back into the hobby after a 10+ year break (brushed motors, FM radios, and NICADs were all the rage when I last ran). I have only driven Associated cars in all my years of racing (from the introduction of the original RC10 up to the TC3 when I quit, and pretty much everything in between). After reading this thread and the posted manual for the car I can see this is a very different beast from the Associated cars I'm used to. If anyone has any tips or advice they would like to give an old-timer (stuff they wish they knew before attempting their first Awesomatix build) I would love to hear anything you wish to share.
Anyway, can't wait for this masterpiece of a touring car to show up, and start getting back into the fun with you all
-Wes
WesRaven is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
