Like Tree13Likes
Old 02-14-2015, 07:12 PM   #8056
alainchan's Avatar
alainchan is offline   Reply With Quote
Old 02-14-2015, 07:59 PM   #8057
geeunit1014's Avatar
Originally Posted by bornox View Post
are there any difference?
Between short and long links? Yes. Short links make the car more responsive, and have more Camber gain. Generally they feel like you have more grip. You will also need the am19 plate for the rear for short camber links, and the front as well if you do not have a ffg (ffg geabox has short link mounts built in)
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-15-2015, 03:52 PM   #8058
cmunro's Avatar
Originally Posted by hanulec View Post
for asymmetric that is right. you do the opposite for reverse asymmetric
So for asymmetric set up you will end up with softer compression in the rear and faster rebound in the front ? What is the theory of this I know it is good for bumpy tracks but how does it change the feel of the car . I always thought that you just change the screws and leave dampers in the normal location
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 02-15-2015, 04:50 PM   #8059
with the dampers in the kit locations, all of them will have softer bump than rebound. The reverse asymmetric hanulec is talking about requires swapping the rear dampers left and right and running asymmetric, and then the bump will be stiffer than the rebound.
Reverse asymmetric in the rear is good for making grip in low grip situations, it can help lock the car down.
Mike Gee
Old 02-15-2015, 04:52 PM   #8060
Trader Rating: 25 (100%+)
If you swap the dampers left to right and change the screw, it makes the compression harder and rebound softer.
Gtr r34 m-spec is offline   Reply With Quote
Old 02-15-2015, 05:16 PM   #8061
cmunro's Avatar
Mike what would you suggest for a bumpy carpet track?
Old 02-15-2015, 05:30 PM   #8062
I actually experienced this at the US indoor champs this year. Very bumpy. What I did was run prodive and prosquat, ie angle the arms like you would with an offroad car. I didnt want to make the damping soft, in fact I made it harder because if you move the d6 dampers quickly the fluid can shear and you lose damping. The dive and squat makes more weight trasnfer go thru the shocks instead of the chassis which helped with bumps. I dont know if hanulec ever posted my setup from that race, if not pm me your email and I can send it to you.
Mike Gee
Old 02-15-2015, 09:05 PM   #8063
kerry's Avatar
Can someone confirm for me if the c01-L2 carbon chassis is the same one that came with the evo 1 kit
the chassis split and I want to replace it on the test car
kerry is offline   Reply With Quote
Old 02-16-2015, 01:23 AM   #8064
hanulec's Avatar
Trader Rating: 27 (100%+)
It is NOT
A700 Evo comes with A700-C01L
A700 Evo IIC comes with A700-C01L2 (which I hear just got manufactured this past week)
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-16-2015, 04:18 PM   #8065
bornox's Avatar
Trader Rating: 26 (100%+)
thanks!
bornox is offline   Reply With Quote
Old 02-16-2015, 06:04 PM   #8066
ThrottleKing's Avatar
Trader Rating: 16 (100%+)
I need ST07. old style outdrive. I have one that has started to crack. Can anyone check for a spare that you can sell to me?
Acts 2:21- And it shall come to pass, that whosoever shall call on the name of the Lord shall be saved.
ThrottleKing is online now   Reply With Quote
Old 02-17-2015, 04:33 AM   #8067
Default Short front camber links?
Will shorter front camber links give me more initial turn in? I have my USGT car running well but I am looking to get the car to turn in a tighter line. I am close to the car being GREAT for ME but I would like to run LESS drag brake so the car can roll through the corners faster. I will be running them at the VTA Carpet Nationals this weekend and hope to do well. Any help will be appreciated.
TWILL is offline   Reply With Quote
Old 02-17-2015, 07:04 AM   #8068
hanulec's Avatar
Tony- short links will make the car overall more aggressive.
Without short links-- options for more turn in include-
1. Toe out
2. Moving steering rack back
3. Decrease front inner camberlink ball stud height
4. Slightly less front dampening
5. Thicker front bar
Old 02-17-2015, 08:44 AM   #8069
Default Thanks.
1. Toe out
I already added the toe out, didn't know witch way to go on the ackerman but now I do, I will make small adjustments to the car during practice this week in Fort Wayne.... Thanks
Old 02-17-2015, 09:14 AM   #8070
Got it covered.
Travis
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
