Like Tree13Likes
Old 02-13-2015, 11:41 AM   #8041
FFG dampening ? Take a pic to show us 😉
Manu_05' is offline   Reply With Quote
Old 02-13-2015, 12:44 PM   #8042
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Originally Posted by johnsonthai View Post
want to say....this car is AWESOME!!! had the car for 6 months.. had the chance to race it at our 2015 Roar Region carpet... at TQ race way.... this past weekend...i ran super stock 13.5... took Tq and 1st overall in the tripe Amains..love this car!!!
https://www.youtube.com/watch?v=tBKt-N064TI ......A2
https://www.youtube.com/watch?v=eoDcdf0XZa8 ....A3
what bodies shell were you running in SS?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 02-13-2015, 01:11 PM   #8043
Trader Rating: 55 (100%+)
Originally Posted by Manu_05' View Post
FFG dampening ? Take a pic to show us ��
Its to stop FFG from moving in excess. I saw something similar at snowbirds. I was told if you have the bearing or FFG1.1 you don't need it. If you have the plastic tab then this helps. The body posts are overdoing it imo
Jamison R is offline   Reply With Quote
Old 02-13-2015, 02:26 PM   #8044
Lw Mazda6
Team Integy .. Speedtechrc.com .. Gridworksracing .. .. Tq raceway ..Roudrunner raceway
AE6.1wc and 6.2
Awesomatix
johnsonthai is offline   Reply With Quote
Old 02-13-2015, 03:50 PM   #8045
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
I would like to flip my dampers and run asymmetric for a bumpy track, just wanted to confirm the proper location for this.
LF=R6
RF=L6
LR=L6
RR=R6
Correct?
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 02-13-2015, 03:56 PM   #8046
hanulec's Avatar
Trader Rating: 27 (100%+)
LF=R6
RF=L6
LR=L6
RR=R6
Correct?
for asymmetric that is right. you do the opposite for reverse asymmetric
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-13-2015, 05:14 PM   #8047
Thanks, I did figure it out, I could not remember how it was as per the manual, then I looked at the manual, LOL.
Earl Towson
Old 02-13-2015, 05:32 PM   #8048
hanulec's Avatar
and for asym you must install set screws .... just as the manual says . its easier to do that when the shocks are out of the car. otherwise you might have to loosen up the arm near the end of the chassis.
Old 02-13-2015, 06:40 PM   #8049
Done and done.
I'm going to try a hybrid set-up, a combo of Jake's and Josh's. Been pretty much running Josh's set-up on my L, works really well, car is fast, carries great corner speed, but is a bit unpredictable on a bumpy track. Plus, our traction levels are mid at best, so firmed up the suspension as per Jake's set-up, with reverse asym. See how it goes.
Earl Towson
Old 02-13-2015, 10:54 PM   #8050
Magnet Top's Avatar
Done and done.
Try using significantly less static camber than what my setup says. Generally, I think I've been using too much. Also (rear) bump toe can be evil on bumpy tracks if you over use it.
Jake
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 02-14-2015, 07:49 AM   #8051
Jake
Thanks for the advice Jake.
I have also found rear bump toe to be evil for me, I don't like how it causes the car to rotate on corner exit on power, I tend to do better with a car that has a bit of on power push from the apex out.
Will try running less camber as well, see how that reacts.
For the most part, the car is fantastic, I can keep it on pace with the fast guys at club races, and some of these guys were in the A with you at Victoria. Just gotta figure out why I suck soooo much when I go to the big races, LOL.
Earl Towson
Old 02-14-2015, 09:02 AM   #8052
RC Professor's Avatar
Originally Posted by Ted Su(TW) View Post
Is there any tips to prevent diff oil from leaking through the hole inside the outdrive cups?
Thank you.
I've found 2 things that help with diff leaking -
1. Replace the stock o-rings with some silicone P4 o-rings. I use the Kyosho P4 silicone o-rings sold at A main hobbies, but I think any P4 silicone will work.
2. Use blue loctite on the two set screws that screw into each ST31 part.
RC Professor is offline   Reply With Quote
Old 02-14-2015, 05:43 PM   #8053
bornox's Avatar
Trader Rating: 26 (100%+)
whats the difference between short and long linkage. the big problem is how to set it for long and short. need help pls.
bornox is online now   Reply With Quote
Old 02-14-2015, 06:02 PM   #8054
geeunit1014's Avatar
If you are talking about camber links, the kit turnbuckles are for long links, and you need optional ones for short liklinks. I like the lunsford 1-1/8 inch long ones awesomatix usa sells
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-14-2015, 06:24 PM   #8055
bornox's Avatar
are there any difference?
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17214 07-12-2017 05:33 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
