Like Tree13Likes
Old 02-06-2015, 06:49 PM   #8011
geeunit1014's Avatar
Originally Posted by Swampracer View Post
Hi guys,
What is everyone using for shock fluid (weights) in the new dampers.
Also is there an instruction sheet or tips for assembling the new dampers?
Thanks Greg G
I ran AE 50wt (650cst) at snowbirds. What you use depe ds on what car you are using. The stock 500 could be ok on an older evo where you can use the full range of A gap (4+). On the newer evo2 chassis you cant go over 3.6 so you need a heavier oil. I ran a 1mm gap with the 50wt oil.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-06-2015, 07:49 PM   #8012
hanulec's Avatar
Trader Rating: 27 (100%+)
snowbirds setup from Mike Gee and Mark Burt now online--
http://www.awesomatixusa.com/p/setup-sheets.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-07-2015, 07:33 AM   #8013
b20btec's Avatar
I'm thinking of buying a evo 2 to run on asphalt also, will the aluminum chassis setup be okay for this?
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 02-08-2015, 01:53 PM   #8014
hanulec's Avatar
The C01AL-S2 should be great outdoors -- just like the C01AL-S was.
Old 02-08-2015, 01:57 PM   #8015
b20btec's Avatar
Thanks! I contacted my local track to get me this kit!
Soap
Old 02-08-2015, 04:50 PM   #8016
Default Need help!
I am running 700L in VTA and USGT, the VTA car is HOOKED UP but the USGT car won't turn in. I have to slow the car down too much to get it to turn around. Is there something to do to put more steering in the car. THANKS (running on carpet)
TWILL is offline   Reply With Quote
Old 02-08-2015, 05:34 PM   #8017
hanulec's Avatar
heavier rear spring
harder front bar
softer front spring and/or damper
less rear toe
front toe out
Old 02-09-2015, 11:36 AM   #8018
!Mad Max!'s Avatar
Send a message via ICQ to !Mad Max! Send a message via Skype™ to !Mad Max!
Default ETS Rnd.2
Hi,
last weekend Team Awesomatix attend at the ETS Rnd.2 in Germany.
It was nearly the biggest event in Europe with over 400 racers in 3 classes !!!
My A700 Evo II worked perfect again and i managed pretty good result in the ProStock class. I started from position 4 into the A-Main, but had a bit bad luck in A1 and A3. A2 was pretty good and i finished second and could also close the gape a bit to Marek Cerny at the end of the run.
You can watch the video at RedRC:
https://www.youtube.com/watch?v=9tT7OcCTTwY
Overall i finished 4th from 209 drivers in ProStock 13,5T class.
I used nearly same setup which i used 2 weeks ago at LRP TCM with VTEC CPX Tires. Only did some small adjustmenst on the setup like droop , geardiff oil and changed only little bit the damper / spring stiffenes.
Please take note that i used 10.000 oil in my rear diff
Awesomatix EP Touring Car (A700 Shaft Drive)-a700evoii-ets-mk-fileminimizer-.jpg
Best Regards Max Mächler
Team Manager Awesomatix Europe
Sponsored by: Awesomatix / LRP / FUTABA / LEESPEED / PROTOform / Wild Turbo Fan / MMP / APaint / MPE Stickers
!Mad Max! is offline   Reply With Quote
Old 02-09-2015, 07:46 PM   #8019
Congrats Max!
Ted Su(TW) is offline   Reply With Quote
Old 02-10-2015, 03:29 AM   #8020
hanulec's Avatar
Max - great result in A2. i see you tried the Dart body this time. what do you think about it?
from the video, you were either over driving the corner entrances trying to keep Jan behind, or you car had a slight entry push.
Old 02-10-2015, 07:10 AM   #8021
Over driving - for sure
kind regards
Marcel
Team Awesomatix Germany
powered by LRP electronic
Marcel is offline   Reply With Quote
Old 02-10-2015, 09:48 AM   #8022
!Mad Max!'s Avatar
Thanks hanulec. In practice i comapred LTC-R and Dart shell and i choosed the Dart because it was more easy to drive for me. I had more consisten lap times over 5 minutes. The LTC-R was more nervouse and aggressive on entry of the corner. Lap times were pretty same for booth shells but the more easy handling let me choose for the Dart
And on video you can see i over driving the car a bit like Marcel already wrote.
Will work on this in future hehehe
Old 02-10-2015, 09:58 AM   #8023
hanulec's Avatar
well you certainly drove well -- especially under pressure. Jan beat us all up (i.e. American's) at Snowbirds at the beginning of the month.
many of us have found to Dart to really help with mid-exit corner rotation. did you try the mazda speed 6 at all?
Old 02-10-2015, 01:26 PM   #8024
!Mad Max!'s Avatar
Yeah i know about Jan's Snowbird wins ;-)
I didn't test Speed6 at the ETS. But like we all know a Speed6 works everytime hehe.
I tested a lot with shells at my hometrack where we have same carpet like ETS.
All 3 PF Shells (Speed6 / LTC-R / Dart) were at same speed. Only consistence over 5 minutes was different. I had best result and feeling with LTC and Dart shell and during the less practice runs at ETS (only 3 to setup car) my plan was to compare only these 2 shells there.
I belive at the end its a personal feeling and driving style opinion which bodyshell you should choose.
Old 02-10-2015, 01:57 PM   #8025
hanulec's Avatar
its amazing that ETS is so popular with only three practice runs... wow!
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17214 07-12-2017 05:33 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
