Like Tree13Likes
Old 02-05-2015, 11:57 AM   #7996
bornox's Avatar
Trader Rating: 26 (100%+)
Originally Posted by kerry View Post
i dont know the exact mathimatical calculation, but download the pdf setup sheet and enter the data into the boxes and it will give you the number, if you are trying to match up a previous setup to the new evo 2 then make you you have the std spring box checked not the soft as you will get different results. when switching to the new evo 2 from the first one i played with the numbers ( top and bottom or A and B ) to get a good starting position, in relation to cf/mm
hope this helps
thank you!
bornox is offline   Reply With Quote
Old 02-05-2015, 12:40 PM   #7997
Stogie's Avatar
Originally Posted by geeunit1014 View Post
Finally coherent again after a long week at snowbirds. My Evo 2 in 17.5 was plain awesome. Super fast all week, as well as easy to drive. I qualified 2nd, and finished 3rd after a couple mistakes in the main. In 13.5 I ran an Evo car and qualified 9th, but switched to an Evo 2 for the main with my 17.5 setup and was able to climb up to 4th in the main. Not too bad for my first trip to birds. I can't thank Hanulec enough for all the support, I know things arent perfect sometimes but he puts in a ton of effort to help us all be able to run the car, and im extremely grateful for what he does. On to the next one!
Congrats on a great showing at the 'Birds, Mike. Could you please provide setup sheets to Hanulec to post up to the AwesomatixUSA site? I'd really like to see what you were running (especially because of the spec tire for the event).
☆☆☆ Chad Stowe ☆ ready to run some Mod TC again, finally ☆☆☆
Stogie is offline   Reply With Quote
Old 02-05-2015, 06:48 PM   #7998
geeunit1014's Avatar
Already did It was jaco tires for birds. my setup was actually extremely similar to my setup from my home track we run jacos at, that setup is online already I believe
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-05-2015, 08:18 PM   #7999
bkspeedo's Avatar
Attached is a new version of the Suspension Stiffness Calculator i creator. We found out a few weeks ago the Soft spring values were off by 20%. This includes the charts in the manuals and all current setup sheets. The soft spring is actual 20% stiffer. If you have my previous spreadsheet delete and start using this one.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 02-05-2015, 08:41 PM   #8000
bornox's Avatar
is this only for evo2? if it is, may i ask for a calculator for an evo?
Thanks!
Old 02-05-2015, 08:57 PM   #8001
bkspeedo's Avatar
Thanks!
This is for all cars.
Brent Klingforth
Old 02-06-2015, 12:12 AM   #8002
hana166's Avatar
You measured the stiffness and these results are the true values? So it is now possible to substitute hard springs for soft and vice versa and achieve the desired correct stiffness?
hana166 is offline   Reply With Quote
Old 02-06-2015, 08:11 AM   #8003
RC Professor's Avatar
Based on Brent's re-work of the spreadsheet, I've revised some quick reference charts. Charts are for both soft and hard springs and SRS1 and SRS2. Soft spring numbers have been updated for the 20% increased spring rate.
RC Professor is offline   Reply With Quote
Old 02-06-2015, 10:42 AM   #8004
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Nice work
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 02-06-2015, 02:18 PM   #8005
bornox's Avatar
Is it possible that you can replicate some other brand spring from a conventional TC using the chart?
Old 02-06-2015, 06:02 PM   #8006
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default New dampers
Hi guys,
What is everyone using for shock fluid (weights) in the new dampers.
Also is there an instruction sheet or tips for assembling the new dampers?
Thanks Greg G
Swampracer is offline   Reply With Quote
Old 02-06-2015, 06:10 PM   #8007
OVA
OVA's Avatar
Originally Posted by Swampracer View Post
Hi guys,
Thanks Greg G
Hi Greg
So far the 500cst is working very well...-Franko-
TIP : first fill the shock oil to the top ( rim) with the four blades piston in the damper housing, don't spin the piston , screw on the shock cap ,without the rubber O-ring;
then install the O ring and the bearing ,washer
Old 02-06-2015, 06:13 PM   #8008
Trader Rating: 23 (100%+)
Hi all,
Installed sd2 and it doesnt lock in the bevel gear anymore with a screw so im getting a lot of movement front and back. is this right?
thanks!
poop is offline   Reply With Quote
Old 02-06-2015, 06:14 PM   #8009
Magnet Top's Avatar
Hi guys,
Thanks Greg G
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is online now   Reply With Quote
Old 02-06-2015, 06:17 PM   #8010
Magnet Top's Avatar
Originally Posted by poop View Post
Hi all,
thanks!
Did you install SPR06 on the Bevel Gear ? You should, then the assembly will snap together.
There will be some front to back movement but it doesn't appear to be an issue.
Jake D.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17214 07-12-2017 05:33 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
