Like Tree13Likes
Old 01-23-2015, 06:18 AM   #7906
Trader Rating: 55 (100%+)
Originally Posted by OVA View Post
Must be an English or typing Class Thread
Does the guy own an awesomatix car? No English class. I failed that miserably. Just read what you typed thinking about it both ways. It was/is a serious question.
Jamison R is offline   Reply With Quote
Old 01-23-2015, 06:33 AM   #7907
jamminjim's Avatar
Hey Guys, what parts would be good to have in case of breakage or wear?
Know racing, know life. No racing, no life.
jamminjim is offline   Reply With Quote
Old 01-23-2015, 08:00 AM   #7908
OVA
OVA's Avatar
Trader Rating: 75 (100%+)
He only drive the Tamiya..
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-23-2015, 08:56 AM   #7909
Awesomatix USA has a pretty good list of recommended spares on their site:
http://www.awesomatixusa.com/p/parts.html
Scroll down to the recommended spares, you may need to update the part numbers to newer revisions but the list is still good.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 01-23-2015, 10:35 AM   #7910
jamminjim's Avatar
Thanks I will scope it out.
Old 01-26-2015, 06:26 AM   #7911
kgombe's Avatar
looking for p14 bumper set.. I'm in Toronto, not a factor but just thought i would let people know of my location.
if anyone knows a store that has them in stock please let me know
http://shop.awesomatixusa.com/awesom.../a700-p14.html
thanks
Kijana Crichton
kgombe is offline   Reply With Quote
Old 01-26-2015, 07:48 AM   #7912
daktulos's Avatar
thanks
Hi, if you don't find the Awesomatix the Tamiya part number 51253 fit well on the front of an Awesomatix... Probably other manufacturer also fit.
daktulos is offline   Reply With Quote
Old 01-26-2015, 07:55 AM   #7913
So I took the car out for its first day on Friday. With the help of someone at the track, I was able to get things tuned and turning some decent laps (for me). Little things kept happening that prevented a full pack run so that is yet to come. After a long bout with thread lock not drying on the front out drive (st17-1-s), screws not adjusted on the battery holder (p23) allowing my battery to come free, I noticed some wobble on my spur. The track was closing so it was time to shut it down anyhow. Well, it turns out, the motor mount collar (DT-03) is required in the motor mount bulkhead plate (am73-4). I searched the new motor mount instructions as well as the ffg instructions and couldn't find anywhere it was indicated as needed. I haven't run it yet with this collar in there but am making the assumption based off of its use in the previous motor mount. This car definitely has a different feel than my ARC so it'll take some getting used to. Fun though.
damo is offline   Reply With Quote
Old 01-26-2015, 08:07 AM   #7914
BardSmith's Avatar
Trader Rating: 61 (98%+)
Does anyone know when the A700 L2 will be available here in the US? Hanulec?
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 01-26-2015, 08:11 AM   #7915
daktulos's Avatar
Hi, until Oleg found the time to "update" the manual read John Doucakis presentation to have an overall idea how parts go together
Awesomatix EP Touring Car (A700 Shaft Drive)
Personally I use the DT03 in the "no flex" position (the recess on the side of the spur) to act as a bearing spacer.
Old 01-26-2015, 08:17 AM   #7916
Default Need help
NEED HELP!!!
Hey guys, I dont even have a clue how to say this in my first language, but I hope you may understand what I need to know. So, does anyone know:
1. How to balance the car?
2. How to tweak?
3. How to adjust or evenly distribute Wheel load?
I hope you guys have an idea what I'm on about :-)
Thanks for your help!!
olli68 is offline   Reply With Quote
Old 01-26-2015, 09:58 AM   #7917
Hi,
last weekend we raced the LRP Touring Car Masters in Rüsselsheim and Viljami managed to finish 3rd behind Ronald and Marc, a very good result, especially because he was so close to catch them
He used the new A700 EVO2, the options we used were SD-2, AM-19 (we used short links) and ST17-1-S.
Attached you can find his setup using LRP CPX tires on the "ETS" carpet, a very hard and thin carpet.
You can find a picture of the track here
kind regards
Marcel
Awesomatix EP Touring Car (A700 Shaft Drive)-25-01-2015_tcm_viljami_cpx.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-imag0416_k.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-imag0421_k.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-imag0423_k.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-imag0426_k.jpg
Marcel is offline   Reply With Quote
Old 01-26-2015, 11:47 AM   #7918
Stogie's Avatar
Thanks for posting these, Marcel - any setup information on the newer spec stuff (especially the rebuildable dampers) is much appreciated!
That track looks incredible... really makes the carpet racing we do here in the US look like a clown show (except for maybe what Scotty does at the IIC). If only we could have setups like that to race on for club racing, maybe more folks would embrace Mod.
☆☆☆ Chad Stowe ☆ ready to run some Mod TC again, finally ☆☆☆
Stogie is offline   Reply With Quote
Old 01-26-2015, 11:53 AM   #7919
Congratulations for Viljami and Max Mächler with LRP TCM 2015 results!
http://www.myrcm.ch/myrcm/report/ru/17913/140872
http://www.myrcm.ch/myrcm/report/ru/17913/140871
You can see how close battle was between Viljami, Marc and Ronald in all runs.
Max also was one of the 2-3 fastest drivers in 10,5T Stock class. Hope that the fortune will be more favorable to Max next time.
Big "Thanks!" to Marcel Geiger for preparing of the car for Viljami.
Oleg Babich is offline   Reply With Quote
Old 01-26-2015, 12:57 PM   #7920
Hi Stogie,
we've been using the new shocks now since a few weeks, so far there are no "special tweaks" about them.
We testet with different oil's from 350cst up to 800cst with the standard AT41 vanes. For the TCM, we use the dampers out of the box, no changes, no rebuild over the weekend
For Ride tires (next ETS is up in 2 weeks) i think we'll start with heavier oil (> 600cst).
You can try the setup from Viljami also for Club Racing, maybe longer wheelbase and thinner diff if you're running blinky stock. Please note the CPX tires don't have as much grip as the Ride, so maybe you have to adapt the setup if your track has a lot of traction (maybe less shims under at21S or reduce the shims for the upper arm on am06s/m). You can also leave away the small amount of kickup in front, we just added this to improve the handling on the slightly bumpy section on the right side of the track.
kind regards
Marcel
Team Awesomatix Germany
powered by LRP electronic
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17214 07-12-2017 05:33 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
