Old 01-12-2015, 02:40 PM   #7801
Originally Posted by Shock Tower View Post
Need some help.
I had a big race this weekend, and I had problems with my steering all weekend. The issue is, that if I set up the steering on the setup up bench, and everything is stright, then if I just hit a disc on the track, then my steering is off by some degrees ???
First I thought it was my servo allluminium horn, that was the problem, but changing it didn't make any diffrent. Changing the servo also didn't help anything.
I looked very careful at the link between the servo horn and the steering rack, but this does not change lenght at all. (I measured it, and checked it several times)
So my own thought goes to the floating servo mount. I think that it moves a little when the car has a small impact. I have tried to tighten the 2 screws in the chassie, but It seems that I can't get the so tight, so the servo mount is completly fixed.
On my previus Xray, there was a smalle guiding pin located in between the 2 fixing screws, just to hold it in place, but on the EVO700, there is only the 2 screws.
Does any has some other idears, or has anyone had the same issue with the floating servo mount.
Thanks in advance.
Are you using a solid aluminum servo horn? I would suggest the xray 4 spring servo saver if you're on a track that uses clik-trak barriers or you hit things.
malkiy is offline   Reply With Quote
Old 01-12-2015, 04:03 PM   #7802
JayL's Avatar
the actual servo moves because the holes in the servo case are bigger than a screw. Square and KO make some collars that are the size of the hole in the servo case that really help.
Of course best of all is the all in one, no mount needed awesomatix servo.....
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 01-12-2015, 04:17 PM   #7803
I had the same issue and it was the floating servo mount. With the narrow chassis the mount hangs over more, so if you hit a dot or something else it will move a little. I Went back to the standard L chassis, no more issues.
Patrick
XCELL is offline   Reply With Quote
Old 01-12-2015, 04:25 PM   #7804
AwesomatixUSA's Avatar
Originally Posted by AwesomatixUSA View Post
10 kits should be awaiting pickup at the PO. If the order is complete then 4 are unspoken for...
Guess I spoke too soon. Only 5 kits arrived
Originally Posted by Xpress View Post
Mike,
Will there be parts available in Florida?
In Florida
At Snowbirds - yes! Every part in the stable will be there...
At SuperiorHobbies - maybe. Start asking them!
Official North American Distributor of Awesomatix, Wild Turbo Fan & Mon-Tech Racing
shop.awesomatixusa.com / www.awesomatixusa.com
#winning - 6x ROAR Nationals, 2x Reedy Race, 2x Snowbirds, 1x IIC, 5x Halloween Classic, 4x US Indoor Champs, 2x Mile High Champs
AwesomatixUSA is offline   Reply With Quote
Old 01-12-2015, 04:28 PM   #7805
Xpress's Avatar
In Florida
Just wanted to check...... I see a certain orange catch-fence in my near future!
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 01-12-2015, 04:30 PM   #7806
hanulec's Avatar
Trader Rating: 23 (100%+)
catch fence are good. chicanes too...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-12-2015, 05:39 PM   #7807
imprsme's Avatar
Trader Rating: 70 (99%+)
Originally Posted by hanulec View Post
Anthony - pls share you setup...
I will get that up in the next day or two for sure.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 01-12-2015, 05:57 PM   #7808
Trader Rating: 54 (100%+)
That sucks. Was looking forward to getting evo2. Guess next round of kits I'll get one.
Jamison R is offline   Reply With Quote
Old 01-13-2015, 12:25 AM   #7809
It's not the servo there are moving in the floating servo mount i'am sure. It's more likely the servomount there are moving on the chassie.
Shock Tower is offline   Reply With Quote
Old 01-13-2015, 02:21 AM   #7810
Please do not hesitate to tighten the mounting screws for AM24 more tighter.
Our team drivers have destroyed a lot of the heavy duty plastic servo arms at crashes but didn't had the problem of the servo mount moving at the proper AM24 screwing.
We use the extra strong 7075 T6 alloy for AM24 and all others our alloy parts and this material allows much more tight screwing compare to the softer alloy parts of others brands.
Oleg Babich is offline   Reply With Quote
Old 01-13-2015, 02:43 AM   #7811
John Doucakis's Avatar
A trick proposed by Oleg, is to scratch a bit the surface of the chassis and the servo holder where they attach. You substantially increase the friction between the two parts and I swear the servo will not move one bit.
John
John Doucakis is offline   Reply With Quote
Old 01-13-2015, 03:04 AM   #7812
Thank you, I have been hesitating to over tighten the screws as I was afraid to strip something.
I will tighten harder, and see if the screw then brake
Old 01-13-2015, 03:05 AM   #7813
John
I think I will this trick to with my dremmel, and then see if this an Oleg's advice should not do the trick.
Old 01-13-2015, 05:33 AM   #7814
Mikkel_R's Avatar
On the Standard EVO can I run the alloy chassis without the long centre line brace? I think its called the AM30
Thanks Michael
Mikkel_R is offline   Reply With Quote
Old 01-13-2015, 06:27 AM   #7815
Thanks Michael
I think Oleg had said not to run any of the alloy chassis without an AM3x brace installed. You'll end up bending the chassis.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17197 Today 02:20 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 Yesterday 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
helltank
SEO by vBSEO 3.5.0
